Noctua
NF-A14 FLX
Silent Wings 3
210 g
137 g
900 U/min
150 U/min
1200 U/min
1450 U/min
68.0 CFM
50.5 CFM
115.5 m³/h
85.8 m³/h
1.51 mmH2O
1.79 mmH2O
19.2 dBA
16.4 dBA
Beige
Braun
Braun
4.6 V
4.1 V
4.2 V
3.9 V
381 U/min
469 U/min
206 U/min
244 U/min
1199 U/min
1411 U/min
53.5 CFM
+137.4 %
22.5 CFM
33.0 CFM
+65.7 %
19.9 CFM
31.7 CFM
+83.7 %
17.2 CFM
30.1 CFM
+79.7 %
16.8 CFM
90.9 m³/h
+137.3 %
38.3 m³/h
56.0 m³/h
+65.7 %
33.8 m³/h
53.8 m³/h
+83.6 %
29.3 m³/h
51.2 m³/h
+79.6 %
28.5 m³/h
0.91 mmH2O
+11.0 %
1.01 mmH2O
0.91 mmH2O
+28.2 %
+42.0 %
0.30 mmH2O
+66.7 %
0.09 hPa
+10.0 %
0.09 hPa
+29.3 %
+39.3 %
0.03 hPa
+63.4 %
34.2
-7.1 %
36.8
42.6
-1.9 %
41.8
40.8
-0.7 %
40.5
39.9
-1.7 %
40.6
