Noctua
Alphacool
NF-A14 FLX
Eiszyklon Aurora Lux Pro ARGB
210 g
200 g
900 U/min
600 U/min
1200 U/min
1500 U/min
68.0 CFM
58.3 CFM
115.5 m³/h
99.3 m³/h
1.51 mmH2O
1.60 mmH2O
19.2 dBA
38.0 dBA
Beige
Braun
Braun
4.6 V
3.3 V
4.2 V
2.9 V
381 U/min
316 U/min
469 U/min
393 U/min
1199 U/min
1499 U/min
53.5 CFM
+16.4 %
46.0 CFM
33.0 CFM
+33.1 %
24.8 CFM
31.7 CFM
+49.5 %
21.2 CFM
30.1 CFM
+24.9 %
24.1 CFM
90.9 m³/h
+16.4 %
78.1 m³/h
56.0 m³/h
+33.0 %
42.1 m³/h
53.8 m³/h
+49.4 %
36.0 m³/h
51.2 m³/h
+24.9 %
41.0 m³/h
0.91 mmH2O
+28.2 %
0.91 mmH2O
+127.5 %
0.40 mmH2O
0.5
0.5
0.30 mmH2O
+33.3 %
0.40 mmH2O
0.09 hPa
+28.6 %
0.09 hPa
+125.0 %
0.05
0.05
0.03 hPa
+33.3 %
34.2
-0.6 %
34.4
42.6
-20.0 %
34.1
40.8
-18.9 %
33.1
39.9
-18.5 %
32.5
