Noctua
Cooler Master
NF-A14 FLX
Sickleflow 140 ARGB
210 g
195 g
900 U/min
650 U/min
1200 U/min
1400 U/min
68.0 CFM
67.0 CFM
115.5 m³/h
113.8 m³/h
1.51 mmH2O
2.25 mmH2O
19.2 dBA
27.0 dBA
Beige
Braun
Braun
Halbtransparent
4.6 V
5.5 V
4.2 V
2.9 V
381 U/min
599 U/min
469 U/min
495 U/min
1199 U/min
1374 U/min
53.5 CFM
+18.1 %
45.3 CFM
33.0 CFM
+17.4 %
28.1 CFM
31.7 CFM
+21.5 %
26.1 CFM
30.1 CFM
+11.6 %
27.0 CFM
90.9 m³/h
+18.1 %
77.0 m³/h
56.0 m³/h
+17.4 %
47.7 m³/h
53.8 m³/h
+21.4 %
44.3 m³/h
51.2 m³/h
+11.5 %
45.9 m³/h
0.91 mmH2O
+82.0 %
0.91 mmH2O
+82.0 %
0.5
0.5
0.30 mmH2O
+66.7 %
0.09 hPa
+80.0 %
0.09 hPa
+80.0 %
0.05
0.05
0.03 hPa
+66.7 %
34.2
-3.7 %
35.5
42.6
-12.7 %
37.2
40.8
-19.6 %
32.8
39.9
-16.0 %
33.5
