Thermaltake
Cooler Master
Masterfan MF120 Halo
212 g
180 g
500 U/min
650 U/min
1800 U/min
58.4 CFM
47.2 CFM
99.1 m³/h
2.41 mmH2O
22.3 dBA
30.0 dBA
Grau
Grau
Halbtransparent
3.3 V
391 U/min
166 U/min
413 U/min
590 U/min
1950 U/min
1792 U/min
33.2 CFM
+34.0 %
24.8 CFM
25.2 CFM
+26.6 %
19.9 CFM
24.5 CFM
+20.9 %
20.2 CFM
20.8 CFM
+20.8 %
17.2 CFM
56.4 m³/h
+33.9 %
42.1 m³/h
42.8 m³/h
+26.6 %
33.8 m³/h
41.6 m³/h
+32.5 %
31.4 m³/h
35.4 m³/h
+20.8 %
29.3 m³/h
1.84 mmH2O
+360.0 %
0.40 mmH2O
0.81
0.81
+25.0 %
0.40 mmH2O
0.4
0.4
0.18 hPa
+351.1 %
+0.7 %
+22.6 %
+2.0 %
37.4
-1.1 %
37.8
36.5
-0.3 %
36.4
36
-1.4 %
36.5
36.2
-1.7 %
35.6
