Thermaltake
Lian Li
UNI FAN SL-INF 120
212 g
210 g
500 U/min
2100 U/min
3.0 W
58.4 CFM
61.3 CFM
99.1 m³/h
104.1 m³/h
2.41 mmH2O
2.66 mmH2O
22.3 dBA
29.0 dBA
Grau
3.5 V
391 U/min
913 U/min
413 U/min
742 U/min
290 U/min
298 U/min
1950 U/min
2134 U/min
886 U/min
33.2 CFM
+10.8 %
30.0 CFM
25.2 CFM
+5.7 %
23.8 CFM
24.5 CFM
+13.6 %
21.5 CFM
20.8 CFM
+7.1 %
22.3 CFM
56.4 m³/h
+10.8 %
50.9 m³/h
42.8 m³/h
+5.7 %
40.5 m³/h
41.6 m³/h
+13.6 %
36.6 m³/h
35.4 m³/h
+7.1 %
37.9 m³/h
1.84 mmH2O
+159.2 %
+14.1 %
+2.0 %
0.51 mmH2O
0.40 mmH2O
+27.5 %
0.51 mmH2O
0.18 hPa
+159.2 %
+14.1 %
+2.0 %
+27.5 %
37.4
-12.8 %
32.6
36.5
-8.2 %
33.5
36
-9.4 %
32.6
36.2
-7.5 %
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
