Thermaltake
MSI
MEG Silent Gale P12
27.5 mm
212 g
209 g
500 U/min
0.7 W
1.4 W
58.4 CFM
56.2 CFM
99.1 m³/h
95.5 m³/h
2.41 mmH2O
2.21 mmH2O
22.3 dBA
22.7 dBA
Grau
5.5 V
4.3 V
391 U/min
906 U/min
413 U/min
742 U/min
194 U/min
186 U/min
1950 U/min
1980 U/min
512 U/min
33.2 CFM
+6.6 %
31.1 CFM
25.2 CFM
+16.9 %
21.5 CFM
24.5 CFM
+10.9 %
22.1 CFM
20.8 CFM
+5.8 %
19.7 CFM
56.4 m³/h
+6.6 %
52.9 m³/h
42.8 m³/h
+16.9 %
36.6 m³/h
41.6 m³/h
+10.9 %
37.5 m³/h
35.4 m³/h
+6.0 %
33.4 m³/h
1.84 mmH2O
+102.2 %
0.91 mmH2O
0.81
0.81
+62.0 %
0.40 mmH2O
+102.5 %
0.18 hPa
+100.5 %
0.09 hPa
+0.7 %
+63.2 %
+103.9 %
37.4
-16.6 %
31.2
36.5
-4.7 %
34.8
36
-3.9 %
34.6
36.2
-8.6 %
33.1
