Thermaltake
Blacknoise
NB-eLoop X PWM B12xP ARGB
212 g
120 g
500 U/min
400 U/min
58.4 CFM
77.9 CFM
99.1 m³/h
132.4 m³/h
2.41 mmH2O
3.02 mmH2O
22.3 dBA
28.4 dBA
Grau
Grau
3.4 V
391 U/min
294 U/min
413 U/min
138 U/min
1950 U/min
2002 U/min
33.2 CFM
+22.2 %
40.5 CFM
25.2 CFM
+1.2 %
24.9 CFM
24.5 CFM
+6.4 %
23.0 CFM
20.8 CFM
+0.9 %
21.0 CFM
56.4 m³/h
+22.2 %
68.9 m³/h
42.8 m³/h
+1.2 %
42.3 m³/h
41.6 m³/h
+6.4 %
39.1 m³/h
35.4 m³/h
+0.9 %
35.7 m³/h
1.84 mmH2O
+28.7 %
1.43 mmH2O
0.81
0.81
+22.0 %
0.40 mmH2O
+25.0 %
0.18 hPa
+28.9 %
0.14 hPa
+0.7 %
+22.4 %
+27.5 %
37.4
-8.0 %
34.4
36.5
36.5
36
-0.3 %
35.9
36.2
-0.3 %
36.1
