Thermaltake
Lian Li
UNI FAN SL120 ARGB
212 g
232 g
500 U/min
800 U/min
1900 U/min
58.4 CFM
58.5 CFM
99.1 m³/h
99.5 m³/h
2.41 mmH2O
1.67 mmH2O
22.3 dBA
31.0 dBA
Grau
Silber
2.4 V
391 U/min
412 U/min
413 U/min
98 U/min
1950 U/min
1828 U/min
33.2 CFM
+42.8 %
23.2 CFM
25.2 CFM
+42.2 %
17.7 CFM
24.5 CFM
+54.6 %
15.8 CFM
20.8 CFM
+36.1 %
15.3 CFM
56.4 m³/h
+42.8 %
39.5 m³/h
42.8 m³/h
+42.2 %
30.1 m³/h
41.6 m³/h
+54.6 %
26.9 m³/h
35.4 m³/h
+36.1 %
26.0 m³/h
1.84 mmH2O
+360.0 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.4
0.4
0.18 hPa
+351.1 %
+98.6 %
+22.6 %
+2.0 %
37.4
-3.6 %
38.8
36.5
-0.5 %
36.7
36
-0.3 %
36.1
36.2
-4.4 %
34.6
