Thermaltake
Arctic
P14 PWM
212 g
194 g
500 U/min
200 U/min
1700 U/min
58.4 CFM
72.8 CFM
99.1 m³/h
123.8 m³/h
2.41 mmH2O
2.40 mmH2O
22.3 dBA
Grau
3.8 V
391 U/min
395 U/min
413 U/min
481 U/min
1950 U/min
1733 U/min
33.2 CFM
+37.6 %
45.7 CFM
25.2 CFM
+7.5 %
27.1 CFM
24.5 CFM
+5.3 %
25.8 CFM
20.8 CFM
+29.7 %
27.0 CFM
56.4 m³/h
+37.6 %
77.6 m³/h
42.8 m³/h
+7.5 %
46.0 m³/h
41.6 m³/h
+5.3 %
43.8 m³/h
35.4 m³/h
+29.7 %
45.9 m³/h
1.84 mmH2O
+206.7 %
0.60 mmH2O
+102.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.4
0.4
0.18 hPa
+200.7 %
+98.6 %
+22.6 %
+2.0 %
37.4
-17.9 %
30.7
36.5
-16.7 %
30.4
36
-16.7 %
30
36.2
-15.5 %
30.6
