ZOTAC stays on the carpet with the power supply design of the RTX 5060 Ti series and shows itself to be unexpectedly conservative. Anyone who thought that after the 12VHPWR debacle, all board partners would march towards new power specifications will be proven wrong. Because: All leaked models of the ZOTAC RTX 5060 Ti – whether AMP, Twin Edge or OC – come with a simple, familiar 8-pin PCIe connector. Without any adapter circus and melting potential.
Return to reason – no 12VHPWR in sight
What initially seems like a side note should be a small exclamation mark for many attentive observers of the RTX 5000 series. While the RTX 5080 and 5090 continue to labor over thermal design experiments with the new 12VHPWR connector – including regularly documented connection problems, scorching and clear application errors by users and manufacturers alike – ZOTAC seems to be deliberately taking a step back. Or rather: not taking a step. According to leaked images and specifications, even the factory overclocked models such as the Twin Edge OC with its 2602 MHz boost rely on the tried and tested 8-pin variant. This not only keeps the connector pleasantly robust, but also keeps the thermal risk manageable. Anyone who has ever inserted an 8-pin connector incorrectly will have to make an effort – in contrast to the 12VHPWR, where even a slightly crooked fit can mean the end.
Technically speaking: 180 watts, no cause for panic
The RTX 5060 Ti is specified with a TDP of 180 watts. If you add the 75 watts from the PCIe slot and correctly factor in the usual 150 watts from an 8-pin, a theoretical power budget of 225 watts remains. This is enough to operate even slightly overclocked cards stably without having to resort to additional connections. There is still room for OC as long as you don’t go to extremes – which hardly anyone does in this class anyway. In direct comparison to the RTX 4060 Ti (also 8-pin, similar TDP), the new 5060 Ti is more of an evolution than a revolution. The fact that ZOTAC is not relying on the “new hot thing” from the NVIDIA ecosystem here is probably also a question of cost and risk. In any case, the feedback on the last 12VHPWR generation was probably not insignificant. Anyone who has seen customer pictures of scorched connectors in forums knows what is meant.
Design decisions with a signal effect
The leaked variants show a total of six models: three with 8 GB and three with 16 GB VRAM. Here too, ZOTAC remains true to the line – no dual power connection, no modular power supply, no adapter overkill. You can call this lazy or efficient. Or simply practical. The AMP version, otherwise often blessed with eye-catching cooling solutions and slightly higher power limits, also sticks to the single 8-pin. This could be an indication that ZOTAC would rather see the card positioned in the mid-range segment – without any ambitions to artificially raise it into higher classes. It remains to be seen what the other manufacturers will do. MSI, ASUS, Gigabyte and Co. could decide to add 8-pin connectors in individual cases, provided the VRM equipment or OC target group allows it. But 12VHPWR on a 5060 Ti? Hopefully this will remain a theoretical thought experiment with no practical relevance.
Conclusion: ZOTAC remains pragmatic – and that’s a good thing
While others are knitting new design concepts with hot needles, ZOTAC remains down to earth. A single 8-pin connector for all models, including OC variants – this is not a technological indictment, but a sign of learning ability. And also a silent commentary on the state of NVIDIA’s reference designs in recent years. So if you’re looking for an RTX 5060 Ti that doesn’t require thermal gambling, you might find it at ZOTAC. At least, as long as you don’t let RGB blinding and power overkill get in the way.
Source: Videocardz
5 Antworten
