Basics Cooling Reviews Thermal grease and pads
Misleading with false data – EKL Alpenföhn Blitzeis thermal compound review – A paste for waste
The Alpenföhn Blitzeis thermal compound is advertised by the manufacturer with a supposedly extreme thermal conductivity of 15.2 W/m-K. This impressive figure is of course intended to suggest that it is the ideal choice for anyone looking for maximum performance. However, as is so often the case, there is once again a wide gap between claim and reality. In practice, it turns out that the paste has two faces in terms of thermal conductivity and even tends to release various gases when heated (outgassing), which leads to the formation of bubbles in the applied layer. This bubble formation significantly impairs durability and can also have a negative impact on the cooling performance of the entire system in the long term. The supposedly high-performance product quickly becomes a risk factor for system stability. And this is exactly what I have to write about today, because this paste is currently being hyped in various forums. You simply have to act.
Especially as the prices starting at 12 euros (including shipping) for just two grams border on hucksterism if you look at the solid competitors in the mid-range performance field. Because there are much cheaper and better options. Forum influencing is always one of those things. One person gets one out and everyone follows…
Violations of legal regulations
Actually, I should preface this paragraph with almost all pastes, but it’s just about time again, as this is a German supplier: The marketing of thermal compound in Germany and the EU requires compliance with strict legal requirements, especially within the framework of the REACH Regulation (EC No. 1907/2006). One of the central requirements is the provision of safety data sheets, which must contain detailed information on the chemical properties, potential hazards and safety measures of a product. The lack of such safety data sheets is not only a violation of the legal requirements, but also harbors potential dangers due to improper handling.
According to the CLP Regulation (EC No. 1272/2008), clear labeling of chemical products is required to provide users with information on hazard classes and precautionary measures at a glance. The lack of labelling makes it difficult for users to recognize the potential risks and react appropriately, which jeopardizes both safety and legal certainty. The registration of substances and mixtures in relevant databases, such as the European Chemicals Register (ECHA database), is also mandatory. This database enables the tracking of chemical substances, their classification and compliance with REACH requirements. The Federal Institute for Occupational Safety and Health (BAuA) is the competent authority in Germany to which companies must register chemicals and submit information. A lack of registration or incomplete information in these systems can not only lead to severe penalties, but can also make it legally impossible to sell a product.
In addition, there is a fake CE mark on the packaging. The imprint with the recycling… I hope that the packaging has also been properly registered. A common feature of an incorrect CE mark is a deviation in the design, particularly in the proportions and spacing of the letters “C” and “E”. According to the official EU specifications, the letters are defined by specific geometric requirements. Here, the horizontal bar in the E is flush on the outside and the letters are further apart. It probably stands for “China Export”, which looks confusingly similar.
Nice accessories such as spatulas, alcohol pads for cleaning or even foils for pasting are also available and they look very similar to those of a paste that has already been tested. But you can happily do without such trinkets, which cost almost nothing to buy, if at least the performance and durability are right. Here, however, there is a lot of gimmickry for almost nothing. This is exactly what we have to find out and prove today, even if I have already spoiled a certain limitation above.
The operating temperature range is specified as between -20 and 130 °C, which seems rather atypical, as silicone oil, as used in heat-conducting pastes, typically has a maximum temperature resistance of up to around 250 °C and, with very high-quality formulations, even up to a maximum of 300 °C, depending on the chemical composition and the specific additives. But we will never reach that anyway. The data on thermal conductivity was measured in a bucket, if at all, or just thrown out.
Well, that’s enough of an introduction, because I already had a pretty thick neck during the test. Not just anatomically speaking…
Test setup and methods Material analysis and microscopy Basic knowledge
Here you can find out why effective thermal conductivity and bulk thermal conductivity can be completely different in practice, what role the contact resistance between the surfaces and the paste plays and how thermal paste can be measured precisely. There is also a detailed description of the equipment, the methodology and the error tolerances. You will learn how laser-induced plasma spectroscopy works and the advantages and limitations of the measurements. There is also high-resolution digital microscopy and analysis of particle sizes. This information is also used to estimate the long-term stability of a paste. Anyone who has always wanted to know what is or is not in a paste and how these pastes are produced will find what they are looking for here. The basic article provides a better understanding of what is often sold for far too much money and sometimes with adventurous promises.
Alpenföhn Blitzeis Wärmeleitpaste, 2g (84000000216)
Procooling1-3 Werktage8,90 €*Stand: 12.02.25 15:59
nullprozentshop.deSofort ab Lager8,90 €*Stand: 12.02.25 20:46
notebooksbilliger.deOnlineshop: lagernd, 24-h Service möglich, Lieferung 2-3 WerktageHannover/Laatzen: lagernd (keine Online-Reservierung möglich)Berlin, Dortmund, Düsseldorf, Hamburg, München, Stuttgart: nicht lagerndStand: 12.02.25 20:298,90 €*Stand: 12.02.25 20:31
*Alle Preise inkl. gesetzl. MwSt zzgl. Versandkosten und ggf. Nachnahmegebühren, wenn nicht anders beschriebenmit freundlicher Unterstützung von geizhals.de
GamePat96
31 Kommentare 6 Likes
Finde die Tests immer sehr interessant, auch hier wieder gerne durchgelesen.
Was eine Enttäuschung, gut das ich bis vor dem Test noch nie von der Paste gehört habe😅 Wird es eigentlich auch einen Test zur neuen Thermal Grizzly Paste (Duronaut) geben? Suche grade nach einer geeigneten Paste für meine CPU, die so an die 2 Jahre ihren Job macht, ohne direkt nen Abflug Richtung Feierabend/Rente zu machen. Aber bin mir maximal unsicher welche ich nehmen soll, muss keine Weltrekorde brechen, da sowieso Custom WaKü, aber schon gerne was Ordentliches fürs Geld.
11,668 Kommentare 22,600 Likes
Duronaut gabs hier mal als Paste X. War aber nur ein Prototyp :)
Ich warte auf Retail-Warte.
Antwort 4 Likes
GamePat96
Verständlich, hoffe mal die kommt bald an :)
Freue mich schon auf den Test, und hoffe die taugt was. Danke für die schnelle Antwort
F
Fortuba
10 Kommentare 5 Likes
Ahh die Bekannte Paste X ist also die Duronaut. Dann bin ich mal auf den zweiten Test gespannt ob die gemessenen Werte von damals mit der Duronaut übereinstimmen
RedF
5,270 Kommentare 3,067 Likes
Irgendwie habe ich Alpenföhn als schlechten Billigheimer im Hinterkopf, da wundert mich das Ergebnis nicht.
Die sind bei mir auf der nicht kaufen liste.
konkretor
352 Kommentare 365 Likes
Gefälschtes CE Zeichen? Abmahnung in 123....
Tronado
4,682 Kommentare 2,566 Likes
Nach dem Alpenföhn Olymp und dem Himalaya 2 (sehr guter hoher 140mm Singletower) ging es abwärts.
Miese Lüfter, laut und ineffizient und die Kühler seit 2014 nicht mehr weiterentwickelt.
2,200 Kommentare 1,405 Likes
Wenn "Blitzeis" aufs Glatteis führt 😜! Und, der hohe Preis ist geschickt gemacht, denn so denken einige mögliche Opfer (Kunden), daß das Zeug eben doch was besonderes ist. Was auch stimmt - allerdings besonders schlecht!
Und, Frage an @Igor Wallossek : haben denn jetzt schon die eine oder andere Seite einen Link auf Deine Datenbank eingerichtet? Denn sie ist in der Form doch einmalig.
Steffdeff
936 Kommentare 887 Likes
Vielleicht sollte Alpenföhn über das beimischen geringer Mengen von Streusalz nachdenken, damit die Marketingabteilung nicht ausrutscht.😉😃
Antwort 4 Likes
z
zwerg05
75 Kommentare 8 Likes
Ich nutze im Moment die polartherm x10 warte bis die Dow paste in de verfügbar sind hoffe das ist bald eventuell hölle ich mir die neue duronout aber da warte ich noch auf guten test
Nein, die Kollegen sind da sicher (noch) futterneidisch :D
h
hellm
718 Kommentare 952 Likes
OMG :eek:
..wobei ich mir nicht mehr sicher bin ob am Ende nun Blitzeis oder TFX auf meiner GPU gelandet ist. Wie auch immer, der Hub beträgt nur 20-30 Kelvin, Wasserkühlung. Nach einem Jahr, OK, ich hab kaum Games gezockt welche die GPU belasten, aber im Moment ist noch alles fit.
Wann kommt nun diese Duronaut? Honeywell und 5888 weiß ich nachher eh nicht ob ich auch bekommen hab was bestellt wurde, wenn ich mir von irgendwo her etwas bestelle, also wie war das noch mit den Geschmacksrichtungen bei TG?
Dragokar
40 Kommentare 20 Likes
Das ist wieder sehr aufschlussreich.
Gab es hier auf der Seite nicht auch mal einen Vergleich über die Vorgehensweise beim Auftragen der WLP? Gibt da ja regelrecht Religionen die X, versus Klecks versus verstreichen debattieren.
B
Besterino
7,257 Kommentare 3,806 Likes
Steht wahrscheinlich schon irgendwo, aber ich erinnere es nicht mehr: was sind denn so die typischen Abstände zwischen CPU/GPU und Kühler? Reden wir da von eher 25, 50, 100, 150 oder noch mehr µm?
Martin Gut
8,489 Kommentare 4,104 Likes
Wenn ich das richtig im Kopf habe, hat Igor früher die Wurstmethode empfohlen. Heute verstreicht er die Pasten aber.
Mit weicheren Pasten kann man eigentlich alles machen. Bei viskoseren muss man aber fast verstreichen und wenn nötig auch etwas erwärmen. Nur durch den Druck verteilen sich zähe Pasten zu wenig. Dazu kann sich eine Paste die unter Druck zur Seite gequetscht wird auch teilweise entmischen.
Grob gesagt: Je viskoser eine Paste um so grösser der Aufwand sie aufzutragen aber dafür ist sie auch langlebiger weil sie dann so bleibt.
Marketing-Bubbles:
Antwort 4 Likes
p
passivecool
67 Kommentare 37 Likes
Im Bayern habe einst die Schönwetterlage 'Föhn', also von Süden über den Alpen schwappenden Winden - die hier als wohl unerträgliches, schönes Wetter ankommt - betörend und verwirrend gar als mildernden Umstand in Mordprozesse gegolten haben. Ob dies heute noch bei der betrügerischen Werbung von Wärmeleitpasten gilt, entgeht leider meine Kenntnisse. ABER! Die Idee, die CPU-Paste mit dem Jahres-Skipass glattzustreichen ... das hat schon was, das muss ich zugeben. ;)
D
Daves085
11 Kommentare 14 Likes
Hm wenn ich mir jetzt nur die kurz die Anmerkung und Empfehlung anschaue denke ich mir joa kann man nutzen ist ja grün bei CPU.
Wenn ich mir den Test durchlese denke ich nur Finger weg.
Klar , in der Anmerkung steh dass es mit der Zeit an Leistung verliert aber so ganz passt das noch nicht zusammen. Evtl noch ein farbiges Feld für Haltbarkeit?
_
_roman_
157 Kommentare 47 Likes
Schön - man sieht verschiedene Auftragunsstärken zwischen Hitzequelle und Kühlkörper verändert massiv das Ergebnis
Da wird der Hersteller es massiv mechanisch mit einer Aperatur zusammengequetscht haben für sagenhafte Werte. Ich bezweifle diese Schichtstärken sind nur irgendwie relatitätsnah so wie ich es vermutlich in Verwendung habe.
Die Paste wird nur für 5 Minuten benutzt und schneidet immer Super ab. Im Langzeittest zu Hause nach Wochen kommt dann die große Enttäuschung. Oh Wunder - Oh Wunder. Ein systemmatischen Messfehler von den vielen Webseiten die irgendwelche Wärmeleitpasten testen.
Die Hersteller sollen ehrlich sein und irgendetwas drauf schreiben wie: Lagerdauer 12 Monate. Alle 3 Monate Wärmeleitpaste ersetzen bei üblicher Nutzung des PCs von 2 Stunden am Tag.
Follow Igor:
