GPUs Latest news
Unreleased NVIDIA GeForce RTX 4090 Ti once again causes a stir.
The NVIDIA GeForce RTX 4090 Ti, a GPU that was originally planned as the flagship of the Ada-Lovelace architecture, has once again surfaced in images. The card was found by a Reddit user who claims to have salvaged it from a dumpster. This confirms once again the existence of this model, which NVIDIA has not officially released. But it also raises questions about its credibility.
The suspected RTX 4090 Ti features a design that differs from previous NVIDIA cards. It is equipped with a quad-slot cooler, which makes the card significantly larger than the current models in the RTX 40 series. The card could cover the entire lower half of an ATX motherboard as well as all PCI-E slots. It is worth noting that the power connector is located on the side and rotated 90 degrees, presumably to solve space problems. In addition, the display connectors are not directly on the motherboard, but on a side-mounted PCB.
NVIDIA had set itself the goal of getting the maximum possible performance out of the Ada architecture with the RTX 4090 Ti. According to reports, however, this failed due to the high performance requirements and design challenges. The RTX 4090, the current top model in the series, is already approaching its technical limits in terms of power consumption. The larger RTX 4090 Ti would probably have increased these requirements even further.
Souce: This_Explanation_514
There were also rumors that the card was originally planned as part of the TITAN series, a product line from NVIDIA that traditionally offers high-performance models with extensive technical specifications. The exact memory configuration of the card is not known, but previous leaks suggest that it could have been equipped with 24 GB or 48 GB GDDR6X memory. The unusual design and the high technical requirements may have been the main reasons why NVIDIA discontinued the project. In view of the fact that there is no direct competition to the RTX 4090, an additional Ti variant does not appear to have been necessary from a business perspective. In addition, the massive cooler design with its weight and space requirements may have been considered impractical for the end user.
The card was last discussed about a month ago when a picture of its I/O panel circulated on the net. At that time, everything indicated that it was a 3-slot design. The model that has now surfaced with a 4-slot heat sink could either be a later version or an alternative design. The Reddit user who found the card has not yet posted any information about whether it is functional. However, the PCB appears to be complete, suggesting that it could be a final or near-final test model.
It is unclear how the card ended up in the trash and why it was disposed of. The RTX 4090 Ti remains an example of the technical and practical limitations that even leading manufacturers like NVIDIA face. The discovery of the card raises questions about development decisions and the limits of current GPU technologies. Whether NVIDIA will bring back such a card in any form in the future is uncertain. However, the current find shows that the RTX 4090 Ti did in fact exist and was probably developed until shortly before its release.
B
Besterino
7,152 Kommentare 3,735 Likes
Nö, eher würden Fragen beantwortet, nämlich in Richtung Grenze „Macht zumindest mit dieser Architektur eher keinen Sinn“.
Ich hätte mehr Fragen in Richtung Glaubwürdigkeit der Quelle. Im Müll gefunden, is klar…
11,316 Kommentare 21,484 Likes
Oder in einer Bar auf dem Tresen vergessen. iRTX :D
Aber ich spoilere auch mal was: die 5090 FE wird definitiv lustig. Hat nicht nur eine Platine, also gaaanz schlecht für Wasserblöcke.. :D
Dr4x
125 Kommentare 104 Likes
Wieso durchsucht ihr meinen Müll?
Die Stadt wollte Ding zudem nicht als BHKW anerkennen...
Alter.Zocker
221 Kommentare 164 Likes
Ja ich kenn sowas, in meiner allmorgendlichen Kaffeesatzlesung steht auch andauernd was von Weltherrschaft und unermesslichem Reichtum...
R
RAWW_94X
7 Kommentare 2 Likes
Die Befürchtung hatte ich schon, als die ersten Gerüchte zu dieser mehrteiligen Platine aufgekommen sind.
Für mein Build darf die 5090 mit Alphacool Core maximal. 27cm lang sein. (Slotblende bis Ende Platine).
Die 4090 war ja mit dem Core unter 25cm...
Ich hoffe, dass zumindest die Referenz Platine für die AIB's sich von den Maßen an der 4090 Platine orientiert oder ist das unwahrscheinlich?
Gruß
big-maec
998 Kommentare 604 Likes
Oha, ist die Karte so klein geworden, dass die mit den Platinen in die Höhe gehen?
Oder wird da mit einer Basekarte gearbeitet, wo man mehrere MXM Module draufstecken kann??:unsure:
S
SpotNic
1,204 Kommentare 538 Likes
Wenn da n Luftkühler mit Kontakt zu den zu kühlenden Elementen draufpasst, warum soll da kein Wasserkühler draufpassen?....
T
Techniker Freak
60 Kommentare 9 Likes
@SpotNic
Wegen der Kühlung, ich vermute das sie die Spannungsversorgung auf eine seitlich montierte Zusatzplatine verlegen.
Für Luftkühler sind die Änderungen nicht so schwerwiegend. Da wird an die Seite eine zusätzliche Kuperplatte montiert und mit den Kühlfinnen verbunden. Bei einem Wasserkühler kann man das nicht so einfach machen, da ist ein vollkommen neues Design erforderlich mit erhöhten Zeit- und Materialaufwendungen in Produktion.
@Igor Wallossek oder liege ich vollkommen daneben?
big-maec
@Techniker Freak
Kann auch sein, dass Bauteile auf der Zusatzplatine im Luftstrom liegen und dadurch besser gekühlt werden, das geht bei einer Wasserkühlung nicht so ohne weiteres.
S
SpotNic
Hab ja nix gegenteiliges behauptet, wird aber schon entsprechende Anbieter geben.
NamaNatranius
39 Kommentare 20 Likes
@igor spoiler mal ob führ bordpartner das selbe gilt.(Hab leider mein gehäuse so konstruiert das die grafikarte auf wasserläuft sieht sonst echt blöd aus)?
H
Headyman
122 Kommentare 58 Likes
Hybridkühlung, vorne Wasserkühlung hinten Luftkühler...
OldMan
215 Kommentare 85 Likes
Was im RZ geht sollte doch auch für den PC klappen:
Gehäuse abdichten, komplett mit nichtleitender Kühlflüssigkeit fluten und außen einen MoRa hinstellen. Da spart man sich dann auch die ekeligen Pads oder Pasten :cool:
p
pintie
202 Kommentare 140 Likes
jo des wird dann sicher nicht funktionieren. bzw wird die Wärmeübertragung von GPU zu Flüssigkeit sicher herrvoragend sein
T
Techniker Freak
@pintie
Mit einigen Modifikationen ist das machbar.
B
Besterino
M.E. leider nicht wirklich für den Privatmenschen alltagstauglich darstellbar.
T
Techniker Freak
Auf gar keinen Fall. Habe mir das ganze mal angesehen und der Preis ist für die damalige Zeit angemessen. Alleine für die Menge Novec 7100 muss man mindestens 3.000€, eher 4.000€ rechnen.
p
pintie
das ist aber keine Kühlflüssigkeit. Mit Phasenübergang geht natürlich viel. Aber auch da muss man dann schauen das sich keine Gasblasen sammeln. Und auch sonst seeeehr aufwendig. Und nicht alle Flüssigkeiten Wohnzimmertauglich
Ist sowas cool - auf jeden Fall. Macht es sinn - sicher nicht.
hatte lange alles mit custom Wakü, bin wieder zurück auf Luft.
Achja. hat alles so seine Nachteile
OldMan
Also wen das interessiert wie das im RZ läuft der kann sich das mal in den beiden YT Beiträgen anschauen. Das Ganze nennt sich dann Immersion Cooling und ist aktuell das effizienteste was der Markt bietet. Wenn man das zum ersten mal live sieht stellt es einem zwar die Nackehaare auf, aber ich bin mir sicher dass das früher oder später auch für Enthusiasten in irgendeiner Form kommen wird.
Hier die beiden Beiträge die empfehlen kann:
Kurzform:
Mit Hintergrundwissen (Wird auch der Unterschied zur reinen Chipkühlung dargestellt):
Samir Bashir
