Case Reviews System
Umbrella Corporation meets Cooler Master and mATX: MasterCase TD300 Mesh Review including a case mod
The TD300 Mesh is Cooler Master’s new mATX case and thus the little brother of the popular TD500 Mesh ATX. The name also hides why the case is so popular, because with its mesh front, the case offers good ventilation and promises a lot of fresh air inside the case. And thus a better heat exchange. The TD300 Mesh is available in two versions: black and white. It is pleasing that no surcharge is demanded for the color variant. The current street price for both versions is 89.95 Euros.
We will find out what is possible in this case in today’s test. Minor spoiler: I’m sure the Umbrella Corporation would be delighted.
Scope of delivery
Cooler Master ships the TD300 Mesh in a plain brown cardboard box, which at least shows the case – nothing else is visible from the outside. Inside, the case is well protected as usual (and unfortunately not very environmentally friendly) with 2 styrofoam blocks and a foil.
The case also contains an accessory box with various screws, cable ties, brackets for mounting HDDs and rubber clips for mounting SSDs – that’s all that’s included, but it’s enough as it is. Two ARGB Sickle Flow 120mm fans are still pre-installed in the case itself.
Technical data
For the very curious we have of course the data sheet again, the manual I will give you then in the chapter with the assembly. And also, I have a video of the build at the very end, but spoilers are uncool.
Daten
RX480
2,085 Kommentare 1,009 Likes
Chickes Display, sogar mit Umbrella-Logo und passender Build mir rotem Fluid in weißem Case=nice!
Der Kritikpunkt mit den Lüftern würde evtl. eh entfallen, wenn vorn ein Radi von der GPU wäre.(oben dann CPU)
(da machen unterschiedliche Drehzahlen kaum Sinn)
Pascal TM-Custom
1,100 Kommentare 1,313 Likes
Danke 😊
Ich denke du meinst das mit dem Lüfter Hub? Wie gesagt ich finde einfach und damit meine ich nicht nur Cooler Master das es eine Sinnvolle Aufteilung braucht nach Lüfter Anzahl.
Aber irgendwie machen das viele so.
Versteh nur nicht ganz warum.
Ghoster52
1,664 Kommentare 1,346 Likes
Dem kann ich mich nur anschließen, schönes Gerät... (y)😍
Pascal TM-Custom
Gerne dürft ihr das Video dazu anschauen
Viel Spaß dabei 😊
grimm
3,516 Kommentare 2,556 Likes
Was hätte man denn für so einen Build zu investieren? Mal abgesehen von den Custom-Bauteilen, die du selbst hergestellt hast...
Mich hätte noch interessiert (im Video), wie du die Hartschaumplatte da reingeschraubt hast.
Sieht aber super aus - Topp-System!
Pascal TM-Custom
Laut Build.gg bin ich mit allem bei ca.3000€+/-
Das teuerste ist natürlich wieder die GPU.
Die Custom Teile sind eigentlich Cent. Beträge die Platten sind günstig und die 3D Druck Teile genauso.
Befestigt werden die Platten mit Doppelseitigen Klebeband und erhalten zusätzlich halt mit der Schottverschraubung und der Tubes.
Ich kann diese Platten wirklich empfehlen die haben ausreichend Stärke das nichts durchhängt. Dazu gibt es die in Matt und Hochglanz in verschiedenen Stärken.
Kein Sägen nötig, kein splittern und sie lassen sich ganz easy in Form bringen mit einem Heißluft Föhn.
Freut mich das dir mein Build gefällt.
s
stillnameless
25 Kommentare 41 Likes
Da ich eher pragmatisch veranlagt bin und ich Technik doch eher zweckgebunden nutze, halte ich per se eigentlich nicht viel von Modding in diese Richtung.
Hier allerdings muss ich zugeben: sieht super aus, tolle Kiste.
Meinen Respekt für diese Kreativität und die Umsetzung!
Pascal TM-Custom
Vielen Dank das freut mich natürlich besonders. 😊
N
Novasun
125 Kommentare 75 Likes
Wunderschöner Build. Gefällt mir echt gut.
ro///M3o
411 Kommentare 299 Likes
Geil :cool: bekomme ich direkt wieder Lust zum basteln!
Mein absoluter Favorit in diesem Build ist dein Ausgleichsbehälter samt 3D DNA Strang. Sieht mega aus. Raijintek hat da ein schickes Teil gebracht und die Idee mit dem DNA Teil ist genial.
Ja und natürlich das Display mit dem Raspberry.
RedF
5,364 Kommentare 3,186 Likes
Die Hardschaumplatten muss ich mir merken : ) .
igor'lLAB Community
