Audio/Peripherals Keyboard Reviews
The new be quiet! Dark Mount keyboard Review – Whisper-quiet performance with versatile functions
The new be quiet! keyboard certainly sets standards in terms of versatility and should particularly inspire those who are looking for a highly customizable and flexible board and are equipped with enough small change. Whether for everyday office use, where numerous multifunctional features are required, or for gamers who want to benefit from the extensive configurability – this keyboard should offer impressive options for both worlds. In addition to its sophisticated design and high-quality workmanship, its exceptional noise reduction is particularly impressive. With its extremely quiet typing noise, it is perfect for anyone who prefers a virtually silent experience. Thanks to the wide range of installation and modification options, it opens up completely new ways of customization for users. A keyboard of this type is certainly a rarity in its own right and definitely worth a closer look.
The name “Dark Mount” represents a deliberate semantic and design bridge between the previous MOUNTAIN product line and the design language of be quiet! The be quiet! Dark Mount is therefore not just an alternative to the MOUNTAIN Everest Max, but a deliberate continuation and reinterpretation of its design principles with the aim of acoustic optimization and brand-appropriate design language. It is therefore not only a successor in the technical sense, but also an expression of a strategic repositioning in the premium segment of mechanical keyboards.
With the Dark Mount, however, be quiet! is deliberately setting new accents – particularly in terms of acoustic behavior and haptic perception. While the Everest Max offered various Cherry MX switch options and focused strongly on diversity in tactile feedback, be quiet! is taking the path of a uniform, specifically quiet typing feel with the Dark Mount. The introduction of its own silent switches with internal damping and the two-layer damping concept inside the case show that noise characteristics have been defined as a central differentiating feature. This orientation is clearly in line with the core philosophy of be quiet! as a brand that has always focused on acoustic optimization in other product areas, such as power supply units or coolers. With the acquisition and integration of MOUNTAIN, be quiet! is expanding its portfolio to include a segment that was previously outside its core competence.
Unboxing and scope of delivery
The first glance at the board reveals well thought-out and carefully designed packaging that not only ensures safe transportation, but also offers an orderly and clear unboxing experience. The packaging is divided into two layers, with each component precisely embedded in custom-fit cut-outs to protect it from damage. The first layer presents the heart of the set – the high-quality board, which immediately catches the eye with its robust construction and elegant design. The second level conceals an extensive accessory package that extends the functionality of the board and offers a wide range of customization and individualization options. This multi-level arrangement ensures that each element is securely fixed yet remains easily accessible, which not only ensures the protection of the individual parts but also provides a consistently high-quality unpacking experience.
On the second level is a versatile accessory pack that extends the keyboard’s functionality and increases comfort. This includes an ergonomic wrist rest, which ensures a relaxed posture when typing and thus reduces fatigue. A high-quality, braided USB-C cable ensures a stable and reliable connection. Particularly noteworthy is the separately included numpad, which not only offers the classic numeric keypad function, but is also equipped with additional features that enable even more individual use. This is complemented by a compact additional board, which opens up further customization options and increases the functionality of the keyboard even further. Another innovative element is the set of magnetic spacers, which allows infinite height adjustment and thus enables the keyboard to be ergonomically adapted to the user’s individual needs – a well thought-out solution for maximum comfort and flexibility.
The scope of delivery is extensive and reminiscent of the Everest era.
Customization of the numeric keypad and media dock – Numpad structure on the right and media dock on the left
Customization of the numeric keypad and media dock – Numpad left and media dock right setup
There are numerous options available to configure the board to suit your own wishes and requirements. From individual customization of the key assignment to macro functions and RGB lighting, there is a wide range of setting options. Different profiles can also be created so that you can quickly switch between different setups depending on the usage scenario – be it for productive work, creative writing or intensive gaming. This versatility makes the board particularly attractive for users who value personalized and flexible operation.
The board also cuts a fine figure without accessories. But if you have already bought all the accessories, you will certainly (want to) use them,
E
Eribaeri
166 Kommentare 67 Likes
Schaut gut aus! Also:
- 45/55g Hot-swapable Switches (supi)
- Browserbasierte Software (supi)
- Numblock Hot-swapable (weltklasse)
- Kabelgebunden, vermeintlich 1000hz Pollingrate
Aber.. Gehe ich richtig in der Annahme, dass das keine optischen Switches mit variablem Aktivierungsweg sind?
Treiber und Latenzinkonsitenzen werden sie wohl noch fixen :)
Karsten Rabeneck-Ketme
109 Kommentare 47 Likes
Die gibt es mit linearen und clicky Switches ;)
E
Eribaeri
Joa, das is nich die Antwort auf meine Frage, ne? ;)
Carcasse
428 Kommentare 146 Likes
Das ist schon die Antwort auf deine Frage. Es ist nur nicht die Antwort die du erwartet hast. GidF
Alter.Zocker
458 Kommentare 325 Likes
Als "Betreiber" einer "Mountain Everest Max" erkenne ich die Parallelen wie auch die Fortschritte bei der "Dark Mount". Ich bin aber noch auf der Suche nach einem Keyboard für einen meiner Arbeitsrechner und da bin ich eher auch auf eine 75% Lösung aus (Platzbedarf am immer zu kleinen Schreibtisch) und v.a. brauche ich hier etwas, das ohne RGB-Bling-Bling eine gut erkennbare und haltbare Tastenbeschriftung mitbringt. Jeder der gerade dunkle RGB-Tasten mal ohne BEleuchtung gesehen hat, wird nachvollziehen können, dass daher die zur Verfügung stehende Auswahl erheblich zusammenschrumpft...
MEine "Everest" hat übrigens auch ein paar MAcken, wo mich natürlich besonders interessiert, wie das nun unter der Flagge von Listan/beQuiet gelöst wurde:
Am schwerwiegendsten ist da noch die Unzuverlässigkeit der (an sich genial unkomplizierten) USB-C Kontaktierung beim rechts angedockten Ziffernblock (vermutlich durch ungünstige Toleranzlage ist die USB-C-Verbindung über den "Magnet-Schieber") auf der rechten Seite des HAuptblocks so schlecht, dass es am Ziffernblock immer mal wieder dunkel wird und nur ein Rumrütteln oder Ziehen und Stecken wieder Leben in das "10er-Anhängsel" bringt, während die Verbindung mit dem steifen und dicken USB-C-Kabel zuverlässig ist (aber dafür eben vergleichsweise ultra-Sperrig und raumgreifender , als mir eigentlich lieb ist). Auf der linken Seite angedockt ist die Zuverlässigkeit besser, aber hier stört (mich) halt das nun sehr gewöhnungsbedürftige Layout...
Weiterhin ist bei meiner Everest MAx (dunkle Ausführung) die Eloxierung des Alu-Rahmens offenbar nicht wirklich lichtbeständig, exponierte Stellen (da wo nicht das Multimedia-Anhängsel samt "bebildertem Drehknopf" sitzt) werden langsam von Schwarz-eloxiert zu grünlich-bräunlich eloxiert, was bei einem Umbau der Konfiguration (Multimedia-Anhängsel weg oder woanders hin) zu recht deutlich sichtbaren "Ausbleichspuren" am Alu-Rahmen fürt...
Ansonsten ist die Everest vom Schreibgefühl (rote Switche) nach wie vor sehr angenehm und für mich sehr gut passend, saubermachen müsste ich das Teil aber auch wieder mal, da sammelt sich schon prominent sichtbar Staub und "Brammel" unter den Tastenkappen ;)
Wie verhalten sich eigentlich "gelubedte" Switche nach längerer Zeit in so einem staubig-krümelilgen "Habitat", wie unter den Keycaps i.d.R. nach einer gewissen BEtriebsdauer anzutreffen ist (es sei denn man kultiviert einen überdurchschnittlichen Reinlichkeitsdrang und saugt/putzt sein Keyboard mindestens 14tägig, hält keine "Mini-Kakadus" als Haustiere usw...), geht dann nicht das "Lubricant" eine "unheilige Verbindung" mit Staub und Bröselei zu einer zähen teerähnlichen Masse ein, unter der die einst so gelobte "Taktilität" dann mehr als nachhaltig leidet?
E
Eribaeri
@Carcasse ich danke Dir für den Link. Google doch nächstes Mal die Schlagwörter der Frage. Dann weist Du auch, worum es geht.
Außerdem riskierst Du so keine (peinliche) Themaverfehlung. :)
Switches sind mechanisch (default), oder optisch in ihrem Auslösemechanismus.
Optische Switches sind deshalb eine feine Sache, weil sich der Auslösepunkt pro Nutzungsprofil verschieben lässt.
Dass die optischen Switches idR mehr Clicks durchhalten, ist in meinen Augen schmückendes Beiwerk.
Obendrauf lassen sich dann weitere Eigenschaften implementieren.
Also: Linear, taktil, clicky, Sound, Freeplay, Hotswapable, was auch immer das Herz begehrt.
Alter.Zocker
Sind die Switches mit parametrierbarem Aktivierungsweg / Anschlagdynamik udgl. nicht induktive bzw. auf dem Hall-Effekt basierende Switche? Solche gibts ja durchaus am MArkt, aber ich vermute, hier muss die Ansteuer- und Auswerteelektronik der Tastatur grundlegend anders aufgebaut sein, als bei "klassischen" Switchen, die auf mechanischen Kontakten basieren.
Edit: Sehe grad, dass es von der Fa. "Keychron" (vermutlich aus Fernasien?) eine Tastatur gibt, die nahezu alle meine Anforderungen erfüllt (siehe weiter oben) und die es auch in Varianten mit solchen weitgehend elektronisch konfigurierbaren HAll-Effekt-Switchen gibt...leider zu einem recht feudalen PReis, zumindest aus meiner Sicht: Sogar bissl teurer, als meine Everest Max seinerzeit und dabei knapp die Hälfte der Tasten...aber sieht schick aus, v.a. in Schwarz/weiß...ich gerate grad sehr in Versuchung....
E
Eribaeri
Vielleicht noch interessant für alle angehenden Keyboard-Liebhaber:
Wooting und co. haben mit Gateron noch magnetische Switches entwickelt.
Die haben die Vorteile der optischen Switches, aber kein Problem mit Staub im Keyboard. Der Schmutz ist dem Lorentz ja egal.
Die hier im Artikel aber etwas von 5-Punkt Cherry Sockeln steht...
E
Eribaeri
Yes Sir!
Mechanische Switches schließen in meinen Laienhaften Augen nur nen Kreis.
Magnetische (Hall Effect) Switches haben nen Sensor.
Is teurer, bieten die Konkurrenten aber größtenteils für Enthusiasten-Keyboards an. Konkret: Wooting, SteelSeries, Corsair und wahrscheinlich die Grünen.
ipat66
1,629 Kommentare 1,779 Likes
Interessantes und sehr leises Tastaturmonster :)
Jetzt noch das Ganze für 150 Euro und ohne Kabelanschluss ( oder eben nur als Alternative ) ...
Dann wäre ich wohl ein Kunde :)
Danke Karsten .
Hi,
Das ist eine interessante Frage. Da ich keinerlei Tiere im Haushalt habe, kann ich das nicht beantworten. Zu switchen an sich, die halten eigentlich, wenn man die einmal vernünftig fertig gemacht hat. Sie sind ja auch geschlossen. Aber selbstverständlich wäre es möglich, wenn feiner Dreck oder Staubpartikel sich unter den Caps länger ablagern, dass dies irgendwann Auswirkungen haben könnte. Ich persönlich habe so etwas noch nie gehabt. Meine Boards sind immer explizit sauber. Gut, ich esse aber auch nicht am Schreibtisch oder schwenke mit Chips oder Schokolade darüber herum. Somit ist auch das bei mir ausgeschlossen. Wenn man die in normaler, ordentlicher Umgebung benutzt, sollte da eigentlich nicht viel passieren. Mit Tierchen, leider keine Ahnung.
Sure. Sehr gerne. Dankt auch bitte Igor. Der sein Know-how in diesen Artikel hat einfließen lassen. Danke an dieser Stelle @ igor!!!
B
Besterino
7,488 Kommentare 3,998 Likes
Wie sieht denn das PCB aus? Im Artikel habe ich nur gesehen, dass da zu den Switches irgendwas für/von „5-Pin MX“ steht - den Bildern nach sind das aber eindeutig immer noch 3-Pin Switches. Die Switches sind mir da aber eigentlich völlig egal, viel spannender ist, ob das PCB nun die Löcher für die 5 Pins hat (die Everest hatte sie nicht) und damit auch eben offen für die gängigen Switches anderer Hersteller ist!
Ganz persönliche/subjektive Meinung: die bisherigen hauseigenen Everest Switches waren durch die Bank Müll.
Die Aussage, dass das Schmieren „reduziert auch Vibrationen, die sich ansonsten akustisch im Gehäuse ausbreiten würden“ halte ich für etwas gewagt… möchte gerne denjenigen kennenlernen, das jemals ein Vibrieren des Stems im Switchinneren über die sich im Gehäuse verbreiteten Vibrationen gehört hat… :D Mit Verlaub, man kann Fan vom Schmieren sein und es mag auch von mir aus die Akkustik verändern, aber so wohl eher nicht… :)
Noch eine Bitte: für mich gehören zu einem Keyboard Review auch eigene Bilder zur Tasten-Unterseite, Macro-Aufnahmen der Tasten-Oberseite, Aussagen zum Tastenmaterial (PBT vs ABS?) und deren Haptik (glatt / rau?), Bilder vom PCB sowie eigentlich auch von einem Tear Down dazu - letzteres ist natürlich schwierig, wenn man das Ding nur leihweise erhalten hat.
Letzte Anmerkung: beim Text bitte gerne weniger von den Marketingmaterialien inspirieren lassen. Gute Reviews trennen subjektive Meinung von Fakten und geben die Meinung erst im Fazit ab. Gerade die Passagen mit direkter Ansprache des Lesers wie „kannst Du…“ „…für Dich…“ wirkt quasi aus den üblichen Marketingunterlagen abgeschrieben. Oder Du musst der KI konkretere Vorgaben fürs Umschreiben machen. ;) Das fällt umso mehr auf, weil der Stil gerne mal wechselt - insbesondere Seiten 1, 2 und 5 scheinen aus einer anderen Feder als 3 und 4. Bitte als konstruktive Kritik verstehen!
Ich hätte die echt gern mal in den Fingern, um mir einen eigenen Eindruck zu verschaffen. Aber nur dafür kaufen und dann widerrufen ist nicht mein Stil.
Alkbert
1,069 Kommentare 851 Likes
Ich kann jetzt echt nicht mehr sagen, was ich für meine G915 Lightspeed von Logi abgedrückt habe und die kann deutlich weniger. Da beeindruckt auch das Alu Gehäuse nicht mehr sonderlich. Insofern ist der aufgerufene price tag hier nicht sonderlich beeindruckend, falls man so ein Teil benötigt. Ich brauch´s net. Aber die Ansprüche sind halt unterschiedlich.
N
NatokWa
19 Kommentare 15 Likes
Jetzt frage ich mich doch glatt wie sich die Orangenen Taster im Vergleich zu meinem Custom-Board schlagen in Sachen Lautstärke... hat ne Weile gebraucht das (für mich) Perfekte Setup zusammen zu kriegen und doch ist es immer noch nicht SO leise wie ich es gerne hätte ......
Hab ein GMMK-TKL Baseboard mit Gamakay Phoenix (Silent V1) die ich aus dem USA importieren musste .... das es die jetzt auch in DE direkt zu kaufen gibt als V2 hab ich auch erst vor kurzem gemerkt .... Nutze die Tasta jetzt schon über 2 Jahre so aber leiser geht immer.
Wenn ich zu schnell tippe guckt meine Frau mich böse an weil sie Fernsehen will :)
B
Besterino
Joah, wenn man's leise haben will mit mechanischen Tastern, kann das in eine Odyssee ausarten. Ich hab so ziemlich jeden (zu der Zeit verfügbaren) silent-Switch in den Fingern gehabt (u.a. dank der Luxx-Aktion mit dem Switch-Tester) und mir am Ende eigene Frankenstein-Switches gebastelt aus Black Lotus und Dolphin. Krank.
Das PCB hat natürlich 5 Pin. Die Caps sind normale PBT-Doubleshots. Es sollte jedem klar sein, was das ist. Und dass es auch hochwertigere Caps zu kaufen gibt, sollte auch bekannt sein. Ich habe für Sie nun 2 Bilder angehangen. Bzgl. der Kritik: Das muss ich so zur Kenntnis nehmen. Ach, und die Caps fühlen sich leicht rauh an.
B
Besterino
Danke! (So natürlich war das für mich nicht, Das Everest PCB war halt noch 3-Pin.). Und Siezen muss man mich auch nicht :) - mir ging es bei meiner Anmerkung nicht um das „Du“ als solches im Artikel - tut mir leid, wenn ich mich da missverständlich ausgedrückt habe.
Lagavulin
310 Kommentare 264 Likes
Vielen Dank für den Test!
Eine leise Tastatur mit taktilen Keys wäre genau das Richtige für mich, um endlich mal meine klappernde Logitech-Tastatur zu ersetzen. Dafür bin ich sogar bereit, auf die von mir heißgeliebte analoge Lautstärkeregelung (via Walze) zu verzichten. Mal sehen, wo sich der Marktpreis einpendelt. Für 200€ würde ich zuschlagen.
Eine Frage hätte ich noch:
Lässt sich die Beleuchtung des umlaufenden LED-Streifens unabhängig von der Beleuchtung der Tasten abschalten (also Beleuchtung LED-Streifen aus, aber Beleuchtung der Tasten an)? Das Letzte was ich brauchen kann, sind unnötige Lichtquellen vor einem Glossy Monitor.
