Computex Latest news
TeamGroup at Computex 2025: Memory solutions between high-end, sustainability and industrial security
At Computex 2025, TeamGroup presented a variety of new memory solutions aimed at gaming, AI computing and professional content creation applications at booth J0617a in Hall 1 of the Taipei Nangang Exhibition Center.
A key highlight was the T-FORCE XTREEM CKD DDR5 memory, which was presented with a clock speed of up to 10,266 MT/s. This module uses Client Clock Driver (CKD) technology to improve signal stability and is equipped with a 2 mm thick aluminum heat sink, which was manufactured using CNC machining and sandblasting. The modules were demonstrated in a system with an Intel Core Ultra 5 265K processor and an ASRock Taichi OCF Z890 motherboard.
In the area of sustainable technologies, the T-FORCE DELTA RGB ECO DDR5 module was presented, which is equipped with a heat sink made from 80% recycled aluminum and an RGB bar made from 100% recycled plastic. This module received the Best Choice Award 2025 in the “Sustainable Tech Special Award” category.
For professional applications, TeamGroup presented the T-CREATE MASTER DDR5 Ai workstation memory with capacities of up to 512 GB, optimized for AI training and data analysis. In addition, the T-CREATE EXPERT CKD DDR5 Ai Memory Module was presented, which offers up to 256 GB capacity and speeds of up to 7200 MHz.
In the area of portable storage solutions, the CinemaPr P36D SSD was presented, which was specially developed for content creators. This SSD offers read speeds of up to 1,000 MB/s and is equipped with features such as HDMI output, gimbal mounting option and cable management.
In the area of cooling technologies, TeamGroup showcased the T-FORCE AI-Flow X, an M.2 SSD cooler with thermoelectric cooling (TEC), and the T-FORCE DUO360V2, an all-in-one cooling solution for CPU and M.2 SSDs. These concepts are designed to improve heat dissipation in high-performance systems.
In addition, the INDUSTRIAL P250Q SSD was presented, which has a one-touch data erase function and is designed for industrial applications. This SSD was honored with the Best Choice Award 2025 in the “Category Award” category.
TeamGroup thus demonstrated a wide range of storage solutions at Computex 2025 that focus on performance as well as sustainability and security.
2,575 Kommentare 1,702 Likes
Hatte Teamgroup denn Details erwähnt, wie die Datenlöschung auf Knopfdruck der INDUSTRIAL P250Q SSD funktioniert? Schnell mehrfach überschreiben wird's wohl nicht sein, denn daß geht nicht in Sekunden auf Knopfdruck, und zerstört auch das NAND nicht. Und die Webseite beschreibt es auch als physische Zerstörung des Datenträgers, und die Methode ist laut Webseite patentiert.
Jetzt ist das zwar zur Vermeidung von Industriespionage etc sehr nützlich, aber gleichzeitig wird es zB dem FBI oder auch unserem BKA gar nicht gefallen, wenn sie selbst mit ihrem speziellen Geräten auch dann nicht mehr an die Daten kommen können, auch wenn sie den Drive selbst haben.
komatös
150 Kommentare 125 Likes
Wie sagt man so schon? Was des einen Freud' ist des anderen Leid! 😄
Feen-Schubser
224 Kommentare 113 Likes
So ein dicker Computer und dann Diashow bei dem mit 10.000 Mhz DDR5 Computer.
Da muss man dann schon 2500W Netzteil dran basteln.
War bestimmt übrig ;)
Humor haben sie. :D
Snake Year with Pussy ID, oh man ich muss zum Ohrenarzt.
Minute 1:30
Aber mir gefällt die Tarnoptik.
Aber was auffällt.
Die Körpersprache der Personen und irgendwie das Igor genau beobachtet wird.
Minute 1:28
Links und rechts von dem Mann.
2 Frauen in Teamgroup Sachen aber unterschiedliche Körpersprache.
Kann auch zufall sein.
Dankeschön für das Video und sehr spannend.
Follow Igor:
