The T-Force Xtreme series had been announced for some time, but now, in January 2020, the fastest modules will finally be available on the market. I was able to get one of the packs with the T-Force DDR4 4000 Xtreem ARGB and of course also test the memory bulb extensively. These kits made of 8GB modules come with three different speed gradations, with clock speeds and timings looking good, if not record-breaking. With CL14-14-14-34 (DDR4-3200), CL14-15-15-35 (DDR4-3600) and CL18-22-22-42 (DDR4-4000) the timings are even quite good, even if there are faster modules. But this will certainly be less of an interest to Ryzen users. But I'll get to that in a while.
The T-Force Xtreem-ARGB-DIMMs are therefore more orientated towards the optics, because the freely addressable light-emitting diodes of the quite unusual lighting are stuck in an interesting housing. This in turn makes the memory modules approx. 4.9 cm high, which is guaranteed to cause conflicts with some symmetrically mounted air coolers.
Well, if you want to be beautiful, you always have to suffer something, so here too. Depending on the timings, the required operating voltages are 1.35 to 1.45 volts, i.e. still within the acceptable range for OC modules, but nothing for me. I will use a maximum of 1.35 volts in the test, which by the way also worked. RAM-Lotto, then. In the design of the luminous effects, something new has been come up. Instead of a simple, translucent plastic, you rely on mirror effects and a complete full illumination on the front side. Since this is always difficult to capture in pictures, I briefly held the camera on it:
The respective timings and clock rates ex works can be found in the data sheet or the homepage and since I have simply tested the other clock rates and timings for better comparison, they are quite interesting.
As with the motherboards, the number of layers and the board material used play a major role. If you don't need to think about 3000 MHz for motherboards under 6 layers, you should direct a total of 10 layers, an optimized layout and coated contacts. And if you don't want to download a video partout, you'll just get the light beams pressed on your eye again as a still image:
The test setup
The setup is of course listed transparently. In this case, only the hardware configuration with CPU, RAM, motherboard, as well as the new cooling is different, so that the summary in table form quickly gives a brief overview of the system used here and today:
Test systems and measuring rooms | |
Hardware: |
AMD Socket AM4 Intel Socket 1151 Tested clock rates: Nvidia Titan RTX 1x 2GB Aorus SSD PCIe 4.0 (NVMe, System SSD) |
Cooling: |
Alphacool Ice Wall 280 Prototype Alphacool Ice Block XPX (Intel) / XPX Pro (AMD) Thermal Grizzly Kryonaut (for cooler change) |
Monitor: | BenQ PD3220U |
Housing: |
Raijintek Paean Open Benchtable |
Thermography: |
Optris PI640, infrared camera PI Connect evaluation software with profiles |
