Mouse Reviews
Sharkoon SGM25W, SGM70W and FIREGLIDER One Review – From All-Rounder to High-End Gaming Mouse
📖 Reading time: approx. 26 minutes · 5,129 words · 32,073 characters
Brief content overview
The test compares the Sharkoon SKILLER SGM25W, the SKILLER SGM70W and the FIREGLIDER One White Edition as three dual-mode gaming mice in different price and performance classes. The key result: all three models deliver solid to good real-world performance overall, with the SKILLER SGM70W being the most convincing in the overall package of sensor, weight and glide behavior, while the FIREGLIDER One achieves the fastest measured latencies in the test and the SKILLER SGM25W stands out as a price-conscious all-rounder.
Key facts
  • SKILLER SGM25W: Lightweight all-rounder with PixArt PAW3311, 59 g and 1,000 Hz; good price-performance ratio, around 24.89 euros
  • SKILLER SGM70W: High-end model with PixArt PAW3395, 49 g and up to 8,000 Hz; the most convincing overall performance in the test., around 39.85 euros
  • FIREGLIDER One White Edition: Lightweight mouse with 55 g, up to 24,000 DPI and up to 8,000 Hz wired; operates without separate software., around 24.94 euros
  • Technical specifications
  • SKILLER SGM25W: PixArt PAW3311, up to 12,000 DPI, up to 1,000 Hz, 300 IPS, 35 G, 6 buttons, 5 freely programmable, 400 mAh battery, up to 40 hours runtime., Lightweight dual-mode mouse for entry-level use and everyday tasks.
  • SKILLER SGM70W: PixArt PAW3395, up to 26,000 DPI, up to 8,000 Hz, 650 IPS, 50 G, 512 kB memory, 500 mAh battery, up to 70 hours at 1,000 Hz., Lightweight high-end model with a clear focus on response speed.
  • FIREGLIDER One White Edition: PixArt PAW3311, up to 12,000 DPI, up to 8,000 Hz wired, up to 4,000 Hz wireless, 55 g, Omron main switches, 512 kB memory., Modern, very lightweight mouse with hardware controls and no separate software.
  • Measured values and observations
  • SKILLER SGM25W, wired 1K: 20.2 ms average end-to-end latency; 15.2 ms to 25.4 ms; 2.3 ms standard deviation., Significantly better than wireless, but still rated as rather slow in the test.
  • SKILLER SGM25W, wireless 1K: 26.9 ms average end-to-end latency; 20.0 ms to 34.9 ms; 4.0 ms standard deviation., Stable wireless transmission with low variation.
  • SKILLER SGM25W, sensor: 8.26 pixel line deviation; 32.82 pixel circle deviation; 0.7 ms click latency; 19.5 percent Angle-Snap index; 100 percent mouse wheel consistency., Clean tracking without micro-jitter.
  • SKILLER SGM70W, wired 8K: 24.2 ms average end-to-end latency; 19.7 ms to 30.5 ms; 3.0 ms standard deviation; one outlier at 1,589.1 ms., According to the test assessment, the outlier was not taken into account.
  • SKILLER SGM70W, wireless 8K: 27.2 ms average end-to-end latency; measured values mostly between about 16 ms and 27 ms; 166.4 ms outlier; 4.0 ms standard deviation., Stable operation, but with one clear outlier.
  • SKILLER SGM70W, sensor: 17.38 pixel line deviation; 19.99 pixel circle deviation; 0.97 pixel micro-jitter; 0.7 ms click latency; 100 percent mouse wheel consistency., Highest precision in the comparison field.
  • FIREGLIDER One, wired 1K: 15.8 ms average end-to-end latency; 10.2 ms to 23.2 ms; 3.0 ms standard deviation., Best value among the measured mouse variants.
  • FIREGLIDER One, wireless 1K: 17.6 ms average end-to-end latency; 11.3 ms to 22.8 ms; 3.3 ms standard deviation., Very even signal transmission without outliers.
  • FIREGLIDER One, sensor: 12.83 pixel line deviation; 22.79 pixel circle deviation; 0.7 ms click latency; 100 percent mouse wheel consistency., Solid tracking without micro-jitter.
  • Teardown, material inspection and build
  • SKILLER SGM25W: Matte black housing, symmetrical shape, rubberized mouse wheel, underside with sensor, DPI switch, on/off switch, receiver compartment and small PTFE glide feet., Cleanly finished and functionally designed.
  • SKILLER SGM70W: Matte surface, ergonomic symmetrical shape, two glass glide feet plus an additional PTFE foot, sensor, DPI/polling-rate switch, on/off switch and receiver compartment., Extremely smooth glide behavior; described in the test as particularly high quality.
  • FIREGLIDER One White Edition: White matte housing surface, symmetrical shape for right- and left-handed users, separate main buttons, grippy mouse wheel, PTFE glide feet, receiver compartment., The clean underside layout underlines the functional overall impression.
  • Test conditions and limitations
  • The mice were tested over several days in everyday use as well as in numerous gaming sessions under real game conditions.
  • The game environment included Wuchang: Fallen Feathers, among others.
  • Build quality, ergonomics, sensor performance, latency, software, battery life and practical usability were recorded.
  • For the SGM70W, a single latency outlier of 1,589.1 ms was explicitly classified as a measurement error or a lost measurement run.
  • The assessment of the acoustic impression remains subjective; functionally, this did not result in any limitations.
  • Classification
    The SKILLER SGM25W positions itself as an affordable, lightweight all-rounder for ambitious players and offers solid technology with decent sensor performance for its price. The FIREGLIDER One White Edition is aimed at users who prefer a mouse ready for immediate use without additional software while still getting a very lightweight model. In comparison, the SKILLER SGM70W clearly takes the lead: it combines the strongest sensor in the trio, the lowest weight and the most noticeable glass glide feet. In the test field, it therefore appears the most modern and the most consistently designed for maximum responsiveness.
    Strengths
  • SKILLER SGM25W: Good price-performance ratio, pleasant ergonomics, 0.7 ms click latency, 100 percent mouse wheel consistency.
  • SKILLER SGM70W: 49 g weight, PixArt PAW3395, up to 8,000 Hz, very smooth glass feet, highest precision in the comparison.
  • FIREGLIDER One White Edition: 15.8 ms wired end-to-end latency, very even wireless measurements, plug-and-play without software.
  • All three models: Dual-mode operation via USB-C and 2.4 GHz, profiles in memory, PTFE glide feet or glass-based glide elements depending on the model.
  • Limitations
  • SKILLER SGM25W: The right mouse button showed slight rattling during rapid click sequences, and the mouse wheel felt somewhat rough when scrolling up.
  • SKILLER SGM70W: The right mouse button rattled slightly; additionally, a secondary noise occasionally occurred when pressing the mouse wheel.
  • FIREGLIDER One White Edition: The shape felt somewhat large for the tested hand size; in addition, the side buttons sounded slightly hollow.
  • The overall acoustic impression of the three mice was described as rather mixed, even though this did not affect functionality.
  • Questions and answers
  • Which mouse was the most convincing overall in the test? The SKILLER SGM70W, because it combines sensor, weight and glide behavior most effectively.
  • Which mouse was the fastest in the latency measurements? The FIREGLIDER One White Edition in wired operation with 15.8 ms.
  • Which mouse works without separate software? The FIREGLIDER One White Edition; the most important functions are controlled directly via the hardware.
  • Which mouse is the lightest? The SKILLER SGM70W at 49 g.
  • Which mouse is most clearly aimed at price-conscious buyers? The SKILLER SGM25W.
  • Generated as an editorial, reader-visible overview from the article content.
    With the SKILLER SGM25W, the SKILLER SGM70W, and the FIREGLIDER One, Sharkoon expands its gaming mouse portfolio across several price and performance classes. Although all three models at first glance follow a similar design language and can each be operated as dual-mode mice, both wired and wirelessly, they are aimed at different target groups. While the SKILLER SGM25W is designed as a lightweight all-rounder for ambitious players, Sharkoon positions the SKILLER SGM70W clearly in the e-sports segment. Here, more modern sensor technology, significantly higher polling rates, and a further reduced form factor are used. The FIREGLIDER One, in turn, revives the long-established FireGlider name and reinterprets the concept completely as a modern, ultralight gaming mouse.
    All three models share a focus on low weight, a wireless 2.4 GHz connection, USB-C charging, and optical PixArt sensors. The differences lie primarily in sensor performance, polling rate, battery life, weight, switch technology, and the respective target group. For this test report, all three models are compared in terms of build quality, ergonomics, sensor performance, latency, software, battery life, and practical suitability. This makes it possible to assess which mouse is the most sensible choice for which use case.
    Sharkoon uses a modern dual-mode concept for all three mice. All models can be used both via the included USB-C cable and wirelessly via a 2.4 GHz radio connection. This allows continued play during charging without interruption. All three mice also feature integrated profile storage, PTFE glide feet, and optical PixArt sensors. Configuration is done via software or directly on the mouse, depending on the model. The maximum wireless range is specified by the manufacturer as up to ten meters. But let’s start from the beginning 🙂
    Introduction & Unboxing
    Sharkoon uses a consistent packaging concept for all three models with a modern and deliberately minimalist design. The front is dominated almost entirely by a stylized mouse graphic, while the respective model name is highlighted prominently in white with strong contrast. This allows the individual models to be distinguished from one another at a glance. Sharkoon also differentiates the mice by color. The SKILLER SGM25W appears in dark gray, the SKILLER SGM70W has a slightly violet or gray-looking coloration, and the FIREGLIDER One White Edition uses dark gray packaging with an additional note about the White Edition. The overall design looks clean and completely dispenses with eye-catching graphics or marketing elements.
    The back of all three packages focuses on the most important technical features and the scope of delivery. All information is printed in multiple languages and divided into separate language sections. This keeps the layout clear despite the amount of information. In addition to the technical key data, the sensor, DPI range, polling rate, connection options, and the contents of the package are listed. A barcode, model designation, and manufacturer information are also located on the underside of the packaging.
    Personally, I do not like the packaging that much. Somehow it feels a bit loveless. The mice are wrapped in paper, and the accessories are just tucked in at the sides. Yes, of course, the packaging is not the main point, and given the very good price, that can be overlooked. After all, the contents are what matter. I only did not want to leave that unmentioned here. All good!
    Sharkoon SGM25W
    The Sharkoon SKILLER SGM25W uses a deliberately simple and functional design. The top is finished entirely in matte black, which conveys a high-quality impression and appears largely resistant to fingerprints. The symmetrical basic shape with gently rounded contours is striking, making the mouse suitable for palm, claw, and fingertip grip alike. The rubberized mouse wheel has a fine texture and provides good grip when scrolling. Between the two main buttons there is a discreet status LED, while the Sharkoon logo in the rear area completes the otherwise restrained look.
    All important controls and technical components are located on the underside. The optical sensor sits in the center and is supplemented by a separate DPI switch. Next to it is the slide switch for changing between 2.4 GHz wireless mode and the off state. At the rear, there is an integrated compartment for the USB receiver so that it can be safely stored during transport. Fairly small PTFE glide feet ensure smooth movement on different mouse pads. Overall, the underside appears cleanly processed and designed with practicality in mind.
    The RGB lighting is pleasant and fits well into the overall appearance.
    Sharkoon SGM70W
    The Sharkoon SKILLER SGM70W presents itself with a modern, understated design and is aimed at users who value the lowest possible weight and an ergonomic shape. The matte surface looks high-quality, offers good grip, and is also not very susceptible to fingerprints. The rubberized mouse wheel engages cleanly and precisely, while the main buttons have generous spacing and allow for a comfortable finger rest. Overall, the SGM70W leaves a very tidy and high-quality impression that is convincing both in gaming and in everyday work.
    The underside is functionally arranged and houses the optical sensor, the DPI/polling-rate switch, and the power switch. Striking are the large glass glide feet, which offer particularly low friction compared with classic PTFE skates and ensure exceptionally smooth gliding. The USB receiver can be safely transported in the integrated storage compartment. Overall, the underside is cleanly processed and designed for maximum performance as well as high everyday practicality.
    There are also PTFE skates included in the set. I think that is good. I was very curious about the glass feet. They look very high-quality. One thing I noticed here: the feet are so smooth that the mouse almost moves by itself. These are the smoothest feet I have personally seen so far. If that is what you are looking for, this is the right place. In addition, they will not lose their quality. Mouse pad/desk mat with these feet, strongly recommended.
    Sharkoon Firegilder One – White Edition
    The Sharkoon FireGlider One White Edition uses a simple, modern design with a completely white housing surface. Its symmetrical shape makes it suitable for both right- and left-handed users and it sits comfortably in the hand. The clearly separated main buttons, the grippy mouse wheel, and the matte surface convey a high-quality impression. Overall, the mouse appears compact, light, and designed for precise control in everyday use as well as during gaming.
    On the underside are the optical sensor, a separate DPI switch, and the power on/off switch. The large-area PTFE glide feet ensure smooth and low-friction gliding on different mouse pads. Also integrated is a practical storage compartment for the 2.4 GHz USB receiver, which allows it to be safely stored during transport. The clean layout of the underside underlines the thoughtful and functional overall impression of the FireGlider One White Edition.
    Let’s take a look further …
    Sharkoon Skiller SGM25W schwarz, USB (4044951044221)
    ShopAvailabilityPrice
    MindfactoryLagernd im Außenlager, Lieferung 2-3 WerktageStand: 06.09.26 14:5124,84 €*Stand: 06.09.26 14:51
    playox.deAuf Lager, sofort versandfertig Lieferzeit 1-2 Werktage24,89 €*Stand: 06.09.26 09:28
    office-partner.deAuf Lager, sofort versandfertig Lieferzeit 1-2 Werktage24,90 €*Stand: 06.09.26 09:46
    AlternateSofort verfügbar24,99 €*Stand: 06.09.26 14:52
    notebooksbilliger.deOnlineshop: Jetzt vorbestellen Berlin, Dortmund, Düsseldorf, Hamburg, Hannover/Laatzen, München, Stuttgart: nicht lagerndStand: 06.09.26 14:4824,99 €*Stand: 06.09.26 14:53
    HiQ24Alsdorf: lagernd Versandlager: lagerndStand: 06.09.26 14:4026,90 €*Stand: 06.09.26 14:42
    galaxusLager Lieferant: Sofort lieferbar, 1-3 Werktage28,50 €*Stand: 06.09.26 14:52
    PC-KINGVersandlager: Lieferzeit 1-2 Tage Superstore Siegburg: nicht lagerndStand: 06.09.26 02:0331,90 €*Stand: 06.09.26 04:03
    alternateLieferzeit 2-4 Werktage32,98 €*Stand: 06.09.26 14:30
    office-partnerlagernd36,28 €*Stand: 06.09.26 14:10
