Basics Cooling Reviews Thermal grease and pads
SAVIO GLACIER TG-04 thermal compound tested against the current top dogs Thermalright TFX and Kooling Monster KOLD-01
The database is finally online and this week I also tested a new paste, the Savio Glacier TG-04, which has made it to the top of the pastes tested so far. Of course, Savio is just a brand and the manufacturer behind the brand, ELMAK, has nothing to do with thermal pastes in terms of production, but it is a really good bought-in product. Of course, this kind of thing triggers me and I went looking for clues this time too.
Day one patch for availability (update)
Mindfactory offered the paste for 12.30 euros until just now, stating “in stock” and a fictitious “external warehouse”, but charging a shipping fee of almost 10 euros. This smells a lot like simple dropshipping and anyone who really wants the paste would be better off ordering or buying it directly from Poland for around 8 euros. As on Amazon, it is once again a typical gold-digger item, where you can make fantastic margins without risk and still not have to stock anything. Such a tiny tube doesn’t cost a single euro FOB in China if you order the right quantities. It is interesting that the availability at MF suddenly dropped to zero this morning and Geizhals only lists Amazon. Coincidence? So we’d better wait for X-Apply and the PastX 50 (spoiler). They will be available in quantities and without outrageous surcharges.
Who is ELMAK and who is Maxtor?
Behind the Savio brand is ELMAK Sp. z o.o. a Polish company that has been developing and producing electronic devices since 1990. In addition to contract manufacturing, ELMAK has been selling electronic accessories under its own Savio brand since 2012, which are manufactured by selected domestic and foreign suppliers according to the company’s requirements. The Savio brand offers a wide range of multimedia and gaming products, including webcams, transmitters, TV boxes, keyboards, headphones and wireless speakers. In 2019, a special gaming product line was added to the range, including cases, headphones, mice, gamepads and now also thermal paste.
Savio’s products are manufactured by selected suppliers that meet ELMAK’s quality standards. Although the specific Original Equipment Manufacturers (OEM) in China are not publicly named, ELMAK works closely with these partners to ensure that the products meet the company’s high standards. Based on the technical data and measurements, the paste could be from Maxtor in China.
Maxtor is a company that offers the CTG10 thermal compound, among other things. The calculated bulk thermal conductivity of 14.5 W/mK and the other specifications of the Savio Glacier TG-04 match those of the Maxtor-CTG10 very conspicuously to 100%, including the real achievable performance. It can therefore be assumed that Savio buys this paste from Maxtor or has one of these pastes filled there as an OEM mixture and sells it in the EU. The accessories are limited to a small manual and a spatula, the shape and surface of which are also strikingly similar to those of other Maxtor fillings.
With the STG10, you have secured one of Maxtor’s top products, should my assumption be correct. Of course, the paste does not have 14.5 W/mK, but it is one of the current top trio in my database. Reason enough to dedicate an individual test to it. It has a grey color, a density of 2.8 g/ml and a viscosity of 95,000 mPa-s. The thermal resistance is 0.095 °C-in²/W and the paste is not electrically conductive. The operating temperature range is between -50 and 280 °C. It is particularly suitable for CPUs, GPUs and other applications that require efficient heat dissipation. The paste does not harden and is available in various packaging sizes. And now we elegantly move on to the practice and the measurements…
Test setup and methods Material analysis and microscopy Basic knowledge
Here you can find out why effective thermal conductivity and bulk thermal conductivity can be completely different in practice, what role the contact resistance between the surfaces and the paste plays and how thermal compound can be measured precisely. There is also a detailed description of the equipment, the methodology and the error tolerances. You will learn how laser-induced plasma spectroscopy works and the advantages and limitations of the measurements. There is also high-resolution digital microscopy and analysis of particle sizes. This information is also used to estimate the long-term stability of a paste. Anyone who has always wanted to know what is or is not in a paste and how these pastes are produced will find what they are looking for here. The basic article provides a better understanding of what is often sold for far too much money and sometimes with adventurous promises.
Savio TG-04 Glacier Wärmeleitpaste, 1g, inkl. Spatel
echolot
1,309 Kommentare 1,057 Likes
Die Marke war mir gänzlich unbekannt. Da besser verarbeitbar auf alle Fälle der TFX vorzuziehen. Preislich auch eher im oberen Bereich. So eine detaillierte Analyse bekommt man nur hier bei Igor. (y)
2,547 Kommentare 1,687 Likes
@Igor Wallossek : Ist der Temperaturbereich in dem die Savio Glacier laut Hersteller anwendbar und stabil ist Deiner Meinung nach realistisch? Ich frage v.a. wegen der Obergrenze, die schon ziemlich hoch liegt. Nicht, daß man im Normalfall Temperaturen von über 200 °C erreichen wird (da wär die CPU schon tot oder zumindest in größter Gefahr), aber Stabilität bei über 200 °C sollte (könnte?) auch heißen, das Pump-Out wahrscheinlich kein Problem sein wird.
Feen-Schubser
219 Kommentare 110 Likes
Sehr spannende Paste inkl dem Spoiler.
Aber bietet Maxtor jetzt 2 Pasten an oder ist da nur Tippfehler?
CTG und STG?
Die 2g Tube ist sofort lieferbar und recht günstig mit aktuell 7,82 € 🫣
Cerebral_Amoebe
143 Kommentare 68 Likes
In der Überschrift fehlt ein o bei Kooling Monster.
Wofür steht die Abkürzung FOB?
free on board?
12,248 Kommentare 24,296 Likes
Tippfehler :)
Ja. Und das o auch mit gefixt, Danke :)
Dann schau mal bei der Gehirnfabrik auf die Versandkosten. Mindestens 9.50/10.50 Euro für eine Briefpost. Dann bist auch wieder bei fast 20 Euro. Scheinbar lesen die hier mit :D
Leicht OT: ich kannte ich den Firmennamen "Maxtor" bis jetzt nur als (ehemaliger, RIP) Hersteller von Harddisks. Hat das Maxtor von heute irgendwas mit der ehemaligen HDD Firma zu tun? Und, ja man, ich werde alt 😜.
Nein, das ist Zufall :)
DigitalBlizzard
3,025 Kommentare 1,969 Likes
Streng genommen heißen die Maxtor-Si, haben mit dem in Seagata aufgegangen Maxtor nix zu tun, auch nicht mit den Mp3 Playern vom Verona Pooth Gatten, das ist einer der besseren Mischer/ OEMs aus DingFeng/Guang Dong, Sheen ( Sheen Thermal / Sheen Technology ) hat auch nix mit Charlie Sheen oder Martin Sheen zu tun, das ist auch einer der Besseren Hersteller in China, Dongguan/ GuangDong der u.a. auch für ShinEtsu, DOW usw produziert.
Sheen wiederum ist ein Kandidat der für die Kold verantwortlich sein könnte.
Aber es ist interessant zu sehen, dass man da offensichtlich mittlerweile auch bessere Produkte aus China bekommen kann, als der z.T. Massenschrott mit dem die User bisher abgespeist wurden.
Aber die besseren Produkte kosten dann auch aus China richtig Geld, da ist nix mehr mit 80€ pro Kilo, da muss man dann auch durchaus 300-400 Dollar das Kilo hinblättern.
Aber das scheint allgemein in den Communitys immer noch nicht in allen Köpfen angekommen zu sein, ich habe letzte Nacht echt schlecht geschlafen, und hatte nen Blutdruck von 200, weil es offensichtlich in anderen Foren Leute gibt, die sich selbst nur ungern eingestehen, dass sie sich mit ihren bisherigen "Top Pasten" haben übers Ohr hauen lassen. Auf Blender Marketing reingefallen sind.
Da gibt es Leute die Quasi wieder unterstellen, dass Messungen auf Hochwertigen geeichten und kalibrierten Labormesseeinrichtungen wie der TIMA5 ja so beeinflusst würden, das neue Produkte die die PastyX 50 unberechtigt besser dastehen würden.
Da müsste man mal das Hirn einschalten bevor man in die Tastatur haut.
Im Gegensatz zu Marketing sind Labormessungen doch eher objektiv, auch im Gegensatz zu normalen Tests auf CPUs wie sie bisher Standard wären, wo bei den Tests NIE die gleichen Bedingungen herrschen können, bishin zur Auftragstärke der Paste, sind diese bisherigen Tests maximal subjektiv.
Und wenn man es seinem Hirn mal so richtig geben will, sollte man sich mal Gedanken machen, warum viele der "Namhaften Brands" auf dem Markt, die Pasten für 50-150€ das Kilo verwenden, unter Umständen nicht so gut sind, wie z.B. eine PastyX 50, die eben 550€ das Kilo kostet. Könnte das was mit der Qualität und Güte zu tun haben!?
Ich weiß, es ist nicht schön, wenn man erkennt, dass sein bisher bevorzugtes Produkt vielleicht doch nicht so toll ist, obwohl man 10€ pro Gramm bezahlt hat und es im Influencer Marketing doch sooo toll war, aber wer blind Marketing folgt und nicht hinterfragt oder misst, muss dann damit Leben. Und entgegen der Unterstellungen die man zu lesen bekommt, hat Igor weder Anteile noch finanzielle Interessen im Bereich PastyX und co, sondern will einfach eine Marktbereinigung zugunsten der Konsumenten vorantreiben, und umgekehrt sind wir auf Igor zugekommen, um unsere Produkte durch ihn prüfen zu lassen, bevor wir sie auf den Markt bringen, nicht umgekehrt. Und Igor hat entsprechend nur aus einem Grund diese Aufgabe angenommen und weitergeführt, nämlich weil er von den Produkten nach der Prüfung selbst überzeugt war. Nicht weil er von uns als "Influencer" gebucht wird, er hat nie einen Cent dafür genommen, weil es ihm in diesem Fall um die Sache an sich und persönliche Überzeugung und reale Messwerte ging.
Und eben weil das Lab Seriös ist, haben wir auch Igor bisher als exklusive Plattform für die Berichterstattung über unsere Produkte gewählt, nach Release kann ja jede andere Plattform selbst nachprüfen und feststellen, das es sich hier um Objektivität und nicht subjektives Marketing handelt.
Wir geben unsere Produkte seit Wochen vor Release freiwillig und ohne Einflussnahme sogar an ganz normale User, das einfach nur deswegen, weil wir wissen das unsere Produkte extrem gut und hochwertig sind, ansonsten würden wir uns mit sowas mächtig ins Knie schießen.
Wie viele andere Hersteller kennt ihr, die das machen, lange vor Release einfach so ein Produkt in Hände von Kunden zu geben, und sich der Gafahr auszusetzen verrissen zu werden.
Das geht nur wenn das Produkt ehrlich und ehrlich gut ist.
Und bei uns gibt es keine bekannten Influencer die Unternehmensanteile halten und von entsprechendem Marketing selbst profitieren würden.
So, sorry, das musste mal raus, jetzt geht's mir besser. Und sollte jemand in anderen Foren über solche Unterstellungen stolpern, ihr dürft denen gerne meine Telefonnummer geben, kann jeder gerne direkt bei mir vorsprechen.
Antwort 8 Likes
echolot
Wenn sie offiziell draußen ist ein absolutes "must have".
ipat66
1,644 Kommentare 1,802 Likes
Hallo Digitalsturm … :)
Lass das Ganze nicht so an Dich ran.
Wenn man sich so über jeden Schei§§ aufregt, schadet man sich nur selbst.
Konzentriere Dich auf das Wesentliche und Deine Lieben, und lass die Deppen Deppen sein.
Seit der Wahl in der neu entstehenden Bananenrepublik, habe ich mir zum Beispiel eine Auszeit jeglicher Nachrichten gegönnt und konzentriere mich auf andere Themengebiete. Einzig die Politiksatire schaue ich mir noch an... Ansonsten Astrophysik, Musik, neue Rezepte, … Da gibt es genug !
Denke einfach bevor es wieder mal aufsteigt daran, dass die Erde flach ist und der Mond und die Sonne ( trotz anders lautenden Aussagen ) gleich groß sind … :)
Man braucht ja nur in den Himmel zu schauen ...
Liebe Grüsse
Ich finde es sowieso immer amüsant, wenn irgendwelche Leute irgendwo Dinge unterstellen, die einzig und allein davon zeugen, dass sie die Zusammenhänge gar nicht kennen, über die sie so verschwörungstheoretisch spekulieren....
Da lese ich z.B., dass es ein G'schmäckle haben soll, wenn Romans ganze Pasten mittlerweile soweit hinten stehen und ich die Messbedingungen dahingehend "optimiert" haben soll, damit dann eine gewisse Paste vorn steht. Ich bin doch nicht die ASTM, die genau so etwas festlegt, sondern ich halte mich streng an die Normen. Genau diese Leute haben noch nicht mal mitbekommen, dass ich hier den Kryonaut-Nachfolger schon längst als Prototypen getestet habe.
Wie werde ich wohl da dran gekommen sein? Weil ich Roman nachts verfolge? Und warum gibt es nach über 10 Jahren endlich mal was Neues? Weil sich auch die Pasten weiterentwickeln! Die PastX 50 setzt z.B, auf eine neue Matrix von Dow, die die ganzen China-Butzen noch gar nicht haben. Was habe ich persönlich davon? Nichts, außer einem schönen Erkenntnisgewinn und der Gewissheit, den ganzen Marketingprassel mal als das zu benennen, was er ist. Und da kommt eh bald noch die Umweltbombe der EU-Bürokraten und unserer grünen Öko-Mafia auf uns zu... Stichwort 13.12.2024. Da müssten nämlich alle neuen Pasten ohne Warnpiktogramm aus dem Handel gezogen werden. Ich schreibe demnächst noch einen Artikel darüber. Die haben alle den Arsch sowas von offen.
Und wieso kann ich mir solche Investitionen im mittlerweile weit sechstelligen Bereich leisten? So etwas riskiere ich doch nicht wegen irgendwelcher unterstellter emotionaler Schwächen. Social Media ist echt ein Absurditätenkabinett, wo man schnell übersieht, wo die Schwepunkte liegen... :D
Antwort 10 Likes
DigitalBlizzard
Ja sorry, ich weiß, dass Du da absolut recht hast, ich weiß auch das ich aufgrund des Stresses den wir vor Release haben, neuen Verordnungen, alles umkennzeichnen usw, gerade ne extrem kurze Zündschnur habe und deswegen besser öfter mal eine rauchen gehe, statt mich auf einen Diskussion einzulassen.
Ich kann mit allem leben, aber nicht mit Unsachlickeit und einer Verdrehung der Tatsachen zu Provokationszwecken.
Wenn dann Leute Vergleiche ziehen, mit Halbwissen, ach was, noch nicht mal viertelwissen, und Dinge heranziehen die so auch nicht stimmen, wie sie nach wie vor irgendwo angeführt werden, dann werde ich grantig.
Ich habe das Projekt hochgezogen, weil sich was ändern MUSS auf dem Markt, wir sind ehrlich und trasnsparent und ich stecke da mit komplett eigenem 7 stelligen Geld drinnen, kein Geld von Banken, Investoren oder sonst was, gut versteckt in einem Unternehmensgeflecht oder einer beschränkten Haftung, wenn wir scheisße erzählen würden, würde ich alles verlieren, könnte es mir unter einer Brücke gemütlich machen, deswegen reagiere ich da sehr allergisch. Ich habe 15 Jahre erfolgreiche Selbständigkeit aufgegeben, alles in X-Apply gesteckt was ich je hatte, ich müsste komplett bescheuert sein, irgendwas zu manipulieren, denn uns ist auch klar, das wir nicht unbedíngt beliebt sind bei den Mitbewerbern, und die nur auf den kleinsten Fehler warten um uns zu schlachten.
Da wird dann so ein hanebüchener Schwachsinn ausgegraben wie die Idiotennummer von Pascal M. damals, der zu eigenen Zwecken seine Mitarbeiterposition missbraucht hat, und eine Messung eines an sich schon sehr guten Produktes so derart verfälscht und manipuliert hat, in der Hoffnung er können dadurch "glänzen" und sich quasi als Mitentwickler aufgespielt hat, was er letztlich gar nicht war.
Der arme Wicht hat am Ende ein wirklich gutes Produkt in der öffentlichen Wahrnehmung "schlecht gemacht" durch Manipulation und damit Igor und auch AlphaCool geschadet, deren einziger Fehler es war, dem Kerl nicht zu misstrauen.
Aber wenn ich meinen Mitarbeitern misstraue, dann werfe ich sie raus, also solange mir einer meiner Mitarbeiter keinen Grund für Misstrauen liefert, muss ich ihm vertrauen.
Und das man dann das Ganze so öffentlich verreißt und ins falsche Licht rückt und Igor unterstellt er hätte AlphaCool da absichtlich zugearbeitet, und AlphaCool unterstellt sie hätten für bessere Werte durch Einflussnahme sorgen wollen, der hat schlicht nix mitbekommen.
Ein Igor und ein Andreas wissen beide, dass sowas spätestens nach Release auffliegen würde, und das der Schaden größer wäre, als jeglicher Nutzen durch positive Aufmerksamkeit, und die hätten sich wissentlich NIE auf sowas eingelassen. Der Mitarbeiter hat glaube ich einfach nicht weiter gedacht, als man ihn werfen kann und wollte halt mal King spielen und hat damit richtig schaden angerichtet.
Wirklich guten Lüftern wie den Apex Stealth hängt deswegen immer noch ein Stigma an, das völlig unberechtigt ist, denn die Lüfter sind gut, und böswillige Menschen nutzen Pascals hirnlos Aktion um unbequeme Leute wie Igor zu dikreditieren, was ebenfalls unberechtigt ist, aber halt hinterfotzig genutzt wird wenns, bestimmten Personen scheinbar nutzt.
Und das nervt mich deratig, da halte ich es mit einem fast schon epischen Ausspruch, für alle diese Schandmäuler da draußen
Antwort 4 Likes
Alter.Zocker
516 Kommentare 356 Likes
Ja die über die Jahre entstandene (a)soziale Community funktioniert schon nach recht eigentümlichen Regeln, ganz anders als in der Realität des echten Lebens, wo sich eben noch nicht so einfach die Dümmsten der Dummen als Könige inszenieren können und Lug und Trug an der Tagesordnung sind, ohne dass es groß auffällt oder gar hinterfragt wird. Schlimmerweise wird aber das ganze Geschehen in dieser “asozialen virtuellen Wunderwelt” zunehmend zu einem sehr realen Wirtschaftsraum mit ganz realem Wettberwerb und davon abhängenden ganz realen Existenzen. Ich ziehe meinen Hut vor allen hier und Anderswo, die sich dennoch angesichts dieser “auf den Kopf” gestellten Verhältnisse dem Allen mit persönlichem Engagement stellen und hier zwar wirtschaftlich aber eben auch ehrlich aktiv sind….musste ich mal loswerden…
Härle'sBöckle
382 Kommentare 268 Likes
Was wird denn kritisiert?
Ach, das ist einfach nur noch albern. Angeblich räche ich mich mit den Messungen an jemandem, dessen Pasten mittlerweile nach hinten durchgereicht wurden. Das Geile daran: es hat nie einen beiderseitigen Beef gegeben, die Leute kapieren nur Social Media nicht. Das Dumme ist ja, dass einem immer nur niedere Beweggründe unterstellt werden, weil genau diese Experten nur von sich auf andere schließen :D Aber das Thema ist durch, ich habe Wochenende...
@DigitalBlizzard : Ja, auch und gerade in China gibt's durchaus einige Firmen, die gute und auch sehr gute Produkte herstellen, und zwar mit hoher Qualität. Das Vorurteil daß alles was Made in China ist Schrott sein soll kommt oft daher, daß man sich erstmal nicht informiert und sich dann wundert, warum das Superbilligangebot auf AliExpress oder (schlimmer) von Wish oder **** nichts taugt oder gleich auseinander fällt. Wobei die Haltung, daß das billigste gut genug und Preis am wichtigsten ist nicht nur bei Endverbrauchern verbreitet ist.
Ich habe zwar selbst noch nie so wie Du den Großteil meiner Finanzen in ein Projekt oder Unternehmen wie Deinem X-Apply gesteckt, war aber an einem Startup beteiligt in das ich einige tausend Euro und über die Jahre v.a. viele (tausende) Arbeitsstunden reinsteckte. Das hat in dem Fall leider am Ende nicht geklappt, aber daß ich da ein ziemliches Risiko einging war mir von Anfang an klar, und ich habe es nie bereut.
Wenn man sich aber wie Du mit X-Apply, hier wirklich mit vollem eigenen finanziellen Einsatz in so ein Venture reinhängt, ist es schon mehr als normal, wenn man (Du) sich dann aufregt, wenn die Neider und Hasser allen möglichen und unmöglichen Blödsinn auf Foren und " (a)sozialen" Medien über einen verbreiten. Scheint leider in Deutschland fast ein Volkssport zu sein! Schon alleine deshalb drücke ich Dir hier beide Daumen und wünsche viel Erfolg 👍🏻👍🏻👍🏻!
Im Falle von X-Apply habt ihr/hast Du bereits ein paar Produkte, die echte Marktlücken füllen.
Am Montag gibts eine Kaufwarnung vor eine Paste, die eine andere gleichen Namens ersetzt und nur mit einem Appendix daherkommt (der sogar noch ein Upgrade impliziert). Das ist eklatante Irreführung. Gleicher Preis, halbe Menge und auch nur noch halbe Performance. Pfui.
Antwort 4 Likes
D
Der Do
115 Kommentare 73 Likes
Alles nette Pasten, aber keine lieferbar....
Der Markt dreht derzeit wieder durch, warte bis weit nach Weihnachten bis ich mich dem wieder widme.
Follow Igor:
