The Revopoint MetroX presented today is a portable 3D scanner aimed primarily at users who want to create detailed digital models of physical objects in a professional environment. With the increasing use of additive manufacturing techniques, digital archiving methods and the growing need for precise geometry data for quality assurance, product development or reverse engineering, the demand for compact, powerful and easy-to-use 3D capture tools is also increasing.
In this context, the MetroX is positioned as a device that combines optical precision with a structured light method and enables mobile, computer-independent data capture. Revo Scan, the associated software solution, supports both manual fine configuration and automated workflows and thus promises flexible adaptation to different areas of application – from individual part scanning to the systematic capture of complex geometries. And the whole thing is already available for well under 1000 USD via Kickstarter, so it’s not a bad offer.
The technical framework conditions, the measurement technology used, the user guidance and the processing procedures within the software environment are key aspects that need to be taken into account when evaluating such a system. This review therefore deals with the question of the extent to which the MetroX meets these requirements in practical use – regardless of whether it is used in an industrial context, in an academic environment or in the field of digital modeling.
Scope of delivery and unboxing
The scope of delivery of the MetroX 3D scanner is designed for immediate and complete use of the system, with both functional and supporting components included. The standard version of the scanner is supplied with a stable stand and a holder to enable both stationary and hands-free work. A motorized turntable with two axes is also included and is used to automatically rotate the object to be captured, allowing a complete 360-degree capture without manual intervention.
A calibration panel is included for quality assurance, which can be used to regularly adjust the scanner. For mobile operation, a wrist strap is included to ensure that the device can be carried safely. In addition to a USB connection cable from type A to type C and an adapter for the alternative connection via type C to type A, the accessories include an external power supply unit. The connection options can therefore be flexibly configured with common devices. The software can be downloaded from the homepage and the automatic firmware update is a nice feature:
For applications where the object surface does not offer sufficient inherent structure to be correctly recognized by the scanner, the set contains a larger number of self-adhesive reference markers. These can be placed on the object and are used by the detection software for geometric orientation. A compact test model in the form of a neutral bust enables a test scan to be carried out immediately in order to gain initial experience with the system. The entire equipment is supplied in a robust transport case, which ensures safe and orderly transportation and storage of all components.
The scope of delivery is supplemented by a printed user manual and a warranty card.
The Advanced Editionmarker box
The extended version of the MetroX, the so-called Advanced Edition, also includes a set of structured marker blocks. These consist of geometrically clearly defined elements such as spheres, domes or pyramids and are magnetic so that they can be positioned particularly well on metallic surfaces.
They serve as visual reference structures when digitizing more complex geometries and at the same time reduce the need for individual adhesive markings. This extension is aimed in particular at users with increased demands on accuracy and efficiency when capturing technical components.
Revopoint MetroX on Kickstarter
- 1 - Introduction, unboxing and features
- 2 - The principle of the structured light method
- 3 - The functional principle of point clouds
- 4 - Triangulation of the point clouds in a mesh
- 5 - 3D for Dummies: One-Click-Solution
- 6 - Limits of the system and the effective accuracy
- 7 - Summary and conclusion
- 8 - Appendix: Datasheet
- 9 - Appendix: Quick Start Quide
11 Antworten
