Latest news PSU
Quieter & more efficient: CORSAIR relies on Cybenetics power supply standards
The growing demand for detailed information on power supplies has led CORSAIR® (Nasdaq: CRSR) to rely exclusively on Cybenetics’ more advanced efficiency and noise certifications. This means that the 80 PLUS certification previously used will be gradually replaced. The aim of this decision is to raise consumer awareness of the differences between Cybenetics and 80 PLUS so that they can choose a power supply with more certainty and confidence. These power supplies are said to have undergone rigorous testing to ensure optimal performance, efficiency and acoustics.
Source: Corsair
Details and differences: Cybenetics as the new standard
Cybenetics certification is a more comprehensive assessment of power supply performance than the 80 PLUS system. While efficiency is still rated in a familiar grading system – from bronze, silver and gold to platinum and titanium – Cybenetics takes a much more detailed approach in its tests. The accuracy and depth of the results are significantly improved as a result. As a result, Cybenetics has become increasingly important in the industry in recent years. Some of the key factors that have contributed to this development include:
Enhanced efficiency metrics
Cybenetics provides a detailed representation of efficiency across different loads, environments and operating conditions. Compared to 80 PLUS certification, which primarily relies on a handful of standardized tests, Cybenetics more accurately reflects the real-world use of power supplies. This provides consumers with better information about how a power supply behaves under different conditions.
Noise level rating
Another crucial aspect of Cybenetics certification is the assessment of the noise level of power supply units. This certification categorizes power supplies based on their acoustic performance. The scale ranges from A (almost silent) to F (loud operating noise). This rating is particularly relevant for gamers and professional users who value a quiet system.
Extensive data collection
Unlike 80 PLUS certification, which relies on a limited number of measurement points, the Cybenetics test methodology collects thousands of data points across all loads. This more comprehensive data collection leads to a more accurate and reliable assessment of power supplies and gives consumers more confidence in their purchasing decisions.
Awareness campaign from CORSAIR
To support the transition from 80 PLUS to Cybenetics certification, CORSAIR has launched an awareness campaign. The aim is to inform consumers about the benefits and differences between the two certification systems. A new article on CORSAIR’s Explorer platform provides more detailed information on this topic to help users make informed decisions. The article can be found here: https://www.corsair.com/explorer/diy-builder/power-supply-units/80-plus-vs-cybenetics.
CORSAIR’s power supply product range
In recent years, CORSAIR has started to offer power supplies that carry both 80 PLUS and Cybenetics certification. This is intended to ease the transition to the new standard. However, future power supplies from CORSAIR will only use the Cybenetics efficiency and noise ratings. The aim is to provide the most accurate representation of power supply performance possible.
Source: Corsair
Why choose CORSAIR power supplies?
CORSAIR has made a name for itself in the world of PC components and stands for quality and innovation. The company’s power supplies are appreciated by a large number of users worldwide. There are several reasons why CORSAIR power supplies are so widely used:
Technological development
CORSAIR is continuously working on the further development of its power supply units to ensure a reliable and powerful power supply. An example of this innovative approach is the recently introduced RMx SHIFT series. This series has been designed to enable easier cable management to help build a clean and efficient system.
Rigorous testing and quality control
Every CORSAIR power supply undergoes a variety of tests to ensure that it meets the company’s high quality standards. These tests go beyond the requirements of Cybenetics certification and ensure that the power supplies perform reliably in different environments and under different load conditions.
Long-term warranties and global support
CORSAIR offers warranties of up to ten years for its power supplies, which underlines the longevity and reliability of the products. In addition, CORSAIR offers comprehensive global support that is available around the clock. This ensures that users can receive support at any time should problems arise.
Overall, it is clear that the transition from 80 PLUS to Cybenetics certification for CORSAIR is not only an adaptation to technical progress, but also a step towards an even more transparent and customer-oriented product strategy. Consumers can rest assured that with CORSAIR power supplies they are getting products that meet the highest standards and have been thoroughly tested for performance and reliability.
Wie ein Quasi-Monopol ab 2021 die Netzteilpreise nach oben treibt – Nichtssagende Zertifikate für ungetestete Netzteile inklusive | Investigativ
Source: Corsair
Ghoster52
1,522 Kommentare 1,186 Likes
Ich würde gern ein Daumen nach unten vergeben... :LOL:
Damit man regelmäßiger kauft, das sehe ich als einzigen Vorteil. :LOL:
Corsair Hydro X Series XC7 RGB PRO: 2 Jahre Garantie überstanden, paar Wochen später RGB Ring teildefekt
Corsair RMx Series 2021 RM850x 850W ATX 2.4: nach über 2 Jahren wird das NT sehr warm/heiß und Lüfter ist laut
iCue Software beißt sich mit HW Info, startest HW Info, flackert die gesamte Weihnachtsbaumbeleuchtung
usw. :poop:
H
HabeLeiderKeinLabor
181 Kommentare 146 Likes
Dafür gibt es bei anständigen Netzteilen 10 Jahre Garantie.
NamaNatranius
28 Kommentare 14 Likes
Also meine persönliche Erfahrung mit corsair Netzteilen (4stück) ist Seher gut waren immer sehr leise und hate noch nie ein defekt. Mein erstes Netzteil ist 8 Jahre alt führ 10 Jahren Garantie ist es noch nicht außergewöhnlich aber was will man mehr als Produkte die kein Problem machen.
c
carrera
138 Kommentare 82 Likes
Stromversorgung ist sauwichtig ... habe seinerzeit lange und viel bei JonnyGuru gelesen, bevor ich mich entschieden habe.
mein Fazit: egal, ob es nicht optimal ausgelastet ist, haben ist besser als brauchen ... und was verbaut ist, spielt eben doch eine Rolle.
Und wenn Du 10 Jahre auf eine PSU bekommst, dann ist das erstmal ein Ausrufezeichen ...
Meine Wahl damals 1600 W Platinum EVGA Supernova P2... nicht bereut ... und grundsätzlich als Fehlerquelle erstmal ausgeschlossen ...
H
HabeLeiderKeinLabor
Finde Stromversorgung auch sauwichtig.
Und ich finde Qualitativ hochwertige Geräte sauwichtig, weil ich stinkfaul bin und wenig Bock auf RMA habe.
Darum finde ich mindestens 10 Jahre Garantie wichtig bei einem PSU.
Hingegen nicht so wichtig finde ich es, eine schlechtere Effizienz zu haben und unnötig Geld rauszuwerfen, weil mein Kaffeesatz einen steigenden Stromverbrauch voraussagt :) Schon gar nicht, wenn die Basis für meine Auswahl solch abstruse Pauschalaussagen sind wie "eine 1000W GPU braucht ein 1500W PSU".
PS: Schuko Stecker dauerbelasten bei 1500W? Macht euere "besser haben als brauchen Fraktion" da eigentlich einen CEE Stecker anstelle von Schuko? ;)
Martin Gut
8,114 Kommentare 3,822 Likes
Ich habe auch 3 Corsair RM 550 bis 650 die plus minus 10 Jahre alt sind. Noch nie hat eines Probleme gemacht und hören kann man sie im Normalbetrieb nie. :cool:
1,811 Kommentare 1,135 Likes
Von den (IMHO zu hohen) Preisen der Corsairs mal abgesehen, sind hier vor allem auch Glückwünsche an Aris in Ordnung. Die Entscheidung von Corsair bestätigt eben, daß die bisherigen Klassifizierungen, die sich ja auch schon seit vielen Jahren nicht geändert haben (Bronze, Silber, Gold, Platinum und Titanium) schon länger nicht mehr genug differenzierbare Informationen bereit stellen. Cybenetics kann das besser.
Antwort 5 Likes
Ghoster52
Mein Sohn hat da so ein Glück, wenn da B-Ware oder Versandrückläufer drauf steht,
kann er sich zu 90% sicher sein, das Teil hat nen Schaden. Er hat das "Glück" im negativem Sinne.
Die Corsair-Teile, also das RM850x hat er extra Neu gekauft. ;)
Zum Glück ist noch Garantie drauf, ärgerlich ist es trotzdem!
PS: und ja, wir haben extra bei Aris in der Liste nachgesehen, nix Geiz und so...
NamaNatranius
Vieleicht einfach nur Pech oder RMx Serie ist einfach doch nicht mehr so gutdie haben auch glaub ich nicht mehr ein Jahre Garantie nervt natürlich wenn man ärger damit hatte oder ich hatte immer glück. Aber kenn keinen im privaten Umfeld der bisher Pech hatte mit corsair Netzteilen zumindest. Will auch corsair nicht allgemein in Himmel lobben hatte auch schon Problem mit Produkten grad die Software hat dieses Jahr schon Problem gemacht hat einen Monat gedauert bis die das ihn den Griff bekommen haben musste solang eine alte Version verwenden ist führ denn preis wo die wollen schon etwas enttäuschend.
Nagah
122 Kommentare 96 Likes
Ich denke es ist Pech. Ich habe zwei RMx 850 hier im Einsatz und die sind beide brav und leise.
Homerclon
93 Kommentare 46 Likes
Das von @Ghoster52 genannte Netzteil, hat 10 Jahre Garantie. Auch auf einige andere Modelle gibt Corsair 10 Jahre Garantie.
Und sein WaKü-Block hat eine 3-jährige Garantie.
B
Besterino
7,052 Kommentare 3,629 Likes
Ich hatte bisher 3 Corsair Netzteile: ein ATX hatte extrem lautes und nerviges Spulenfiepen, ein SFX 600W ist top und hält schon seit schätzungsweise 5-6 Jahren und mein aktuelles 1000HXi ist auch prima (allerdings noch recht frisch).
In meiner persönlichen Rangliste hat Corsair aktuell bequiet ersetzt, die seit 2x ratternden Lüftern in zwei PSUs der Dark Rock 13er Reihe bei mir auf der „kauf ich nicht mehr“ Liste stehen. Seasonic ist aber immer noch mein persönlicher Lieblingshersteller für Netzteile (ich wollte aber mal was ausprobieren, wo ich die Lasten/Verbrauch direkt auslesen kann).
H
HabeLeiderKeinLabor
Eben. Das war einfach Pech. RMA und gut ist.
Gibt einen Grund warum Corsair manchmal 7 Jahre, manchmal 10 Jahre gibt auf ihre PSU.
Die rechnen sich die RMA Kosten aus.
Ein PSU mit 10 Jahren, egal von welchem Hersteller, wird mit hoher Wahrscheinlichkeit ein langlebiges Netzteil sein.
Das ist natürlich ein Müllprodukt. Da überrascht mich ein Ausfall nicht. Arctic gibt 6 Jahre aber Corsair kann bei doppelt so teueren AIO nur 3 Jahre liefern? Da müssen eigentlich bei jedem die Alarmglocken angehen.
Tolotos66
31 Kommentare 18 Likes
Leider wird viel zu oft am "Saftspender" gespart. Was habe ich da schon Überzeugungsarbeit leisten dürfen/müssen.
Ich verwende seit 3Jahren ein HX750i und bin sehr zufrieden. Davor sehr veile SuperFlower. BQ ist bei mir schon lange raus. Seit den guten Straight Powere E10 danach zu häufig Probleme (ratternde Lüfter, Abschaltung unter Volllast, beschädigte Kondensatoren) gehabt.
Gruß T.
_
_roman_
117 Kommentare 33 Likes
Mein Corsair RM750 ist nach 18 Monaten gestorben. Ich habe die 90~% Rückerstattung vom Kaufpreis akzeptiert. Fehlkauf aufgrund einer PC komplett Kaufberatung in einem deutschen Forum. Das Mainboard war auch im Grunde eine Fehlberatung.
Das war bisher das einzig defekte Computer Netzteil. Ich verwende immer noch 386 oder waren es 286 Netzteile für gewisse Dinge. Wenn man 12V DC oder 5V DC braucht ausreichend zum Testen. Sicherlich man kann sich Labornetzteile kaufen. Nur das Geld ist ausgegeben und nicht mehr vorhanden. Diese Netzteile habe ich selbst damals aus den PC ausgeschlachtet.
Diese ganzen Netzteiltests sind im Grunde nicht aussagekräftig für mich..
Der Hauptgrund mir ein Enermax Revolution D.F. 750 zu kaufen war ein Test mit dieser Effizienzkurve von 0 bis 100Watt in 5 Watt Schritten. Es wird schon einen Grund haben, warum diese Angabe vom Hersteller fehlt.
Steffdeff
894 Kommentare 853 Likes
In HwInfo unter Programm >Einstellungen>Sicherheit die Corsair und Asetek Unterstützung deaktivieren.
Vielleicht hilft das ja gegen die flackernde Beleuchtung.
Für Weihnachten ist es ja noch zu früh! 😉😃
_
_roman_
Ich vestehe den Hinweis nicht.
Die Brennenstuhl Schuko-Steckerleiste die orginalverpackt bei mir liegt hat 16 Ampere. Wo soll jetzt das Problem sein bei 6 bis 7 Ampere? Da reden wir von einer Billigheimer Steckerleiste im 7€ Bereich.
Lagavulin
266 Kommentare 233 Likes
Das wirklich interessante an der News ist für mich, dass mit Corsair ein großer Player im Markt auf die Cybenetics-Zertifizierung setzt. Ich hoffe, dass die Wettbewerber nachziehen.
H
HabeLeiderKeinLabor
Das war ein Witz. 16 Ampere sind aber auch nicht Dauerbelastung.
Samir Bashir
