Case Reviews
NZXT H9 Flow RGB spacious double chamber case in test – Lots of space and few flaws
NZXT is putting the latest iteration of the H9 Flow case on the shelves just in time for Computex. After the gigantic success of the H6 Flow, it was only a matter of time before the “kink” also made its way into the top model. Read on to find out how the flagship performs in everyday use.
When the NZXT H6 Flow was released at the end of 2023, it attracted a lot of attention with its unique design, which also largely solved the “airflow” problem of the “O11” style cases. However, because the airy H6 was almost a little too compact for absolute high-end systems, NZXT is now transferring the pentagonal design with the kink to the large H9 series.
The H9 Flow is available in three versions:
  • H9 Flow (incl. 3x F140Q (CV) and 1x F120Q (CV)): €179.90
  • H9 Flow RGB (incl. 1x F420 RGB Core Fans): 219,90€
  • H9 Flow RGB (incl. controller 2x F420 RGB Core 1x F120 RGB Core (CV)): €299.90
All variants will be available in black and white and at the same price.
Once again, the absence of magnetic dust filters – especially considering the price range – is not well received by many potential buyers. However, the manufacturer vehemently defends the statement that no further filters are necessary with this fine mesh (perforated surfaces). As I unfortunately lack long-term experience in this regard, I don’t want to devote too much attention to the subject and will first unpack the housing together with you.
Unboxing
The outer box once again comes in the typical NZXT design.
We were provided with the top RGB model for the review.
As in the automotive industry, the similarities between the individual models of a manufacturer are astounding.
The differences in detail are often only noticeable at second glance, but in reality, the significant increase in size compared to the H6 Flow is noticeable.
Even the untrained eye will notice that this housing is a little “different” when viewed from the front.
Not only the “bevel”, but also the cover of the rear chamber is equipped with a large perforation so that the power supply unit behind it can also draw in cool fresh air from outside.
There is nothing exciting to see on the back of the case.
There is space for up to three 140mm (or one 420mm single frame) fans at the bottom of the case. As no mesh is used here, a pull-out dust filter has been added.
The front glass panel is screwed to the base frame from below and can be removed by loosening the two screws.
And while we’re on the subject: The front I/O consists of a power button with integrated power LED, two USB 3.2 Type A, one USB 3.2 Gen2x2 Type C and a 3.5mm combo jack. The rest button, HDD LED and the second jack connection fall victim to the red pencil of the design language.
The lid is again equipped with a perforated surface and can be easily removed by loosening two knurled screws. The lid has space for radiators up to 420 mm and there is also a cut-out for a fill port.
The cover of the slope is hooked into the basic construction and fixed at the top with a small screw.
A radiator with a length of up to 420 mm can also be mounted here.
In the RGB version, the same 420mm single frame fan is installed here ex works as in the base.
