Aircooling Latest news
Noctua introduces the NF-A6x15 60mm fan and the NA-SC1 Sx2 splitter cable set | Press release
Noctua has expanded its A-series with new 60mm slim fan models. The new NF-A6x15 is a slimmer version of the previous NF-A6x25 and has been developed to meet the requirements of devices and applications that require fans with a thickness of up to 15mm. It is available in two voltage variants (12V and 5V) and offers both 3-pin and 4-pin PWM connectors.
Features of the NF-A6x15
The NF-A6x15 has been equipped with advanced aerodynamic design features to provide high performance with low noise. These features include the Flow Acceleration Channels, which increase airflow speed and reduce turbulence, and the AAO (Advanced Acoustic Optimization) frame, which optimizes stability and noise. The 5V versions of the NF-A6x15 include Noctua’s OmniJoin™ adapter set, which enables easy connection when replacing fans in devices with proprietary connectors. An additional USB-A power adapter cable allows the fan to be operated on power banks, devices with USB host ports or USB power supplies, making it versatile.
In addition to the new fans, Noctua has introduced the NA-SC1 Sx2 set, which consists of two 3-way PWM splitter cables. These cables make it possible to operate and control up to three fans simultaneously via a single fan connection. By connecting the second splitter cable to the first, up to five fans can be operated simultaneously. The NA-SC1 splitter cables are encased in a robust black fiberglass-silicone jacket, which makes them particularly durable and flexible. This makes them suitable not only for use in PCs, but also for other ventilation applications where a reliable and versatile solution for controlling multiple fans is required.
Possible applications
The NF-A6x15 is ideal for applications that require compact and efficient cooling, such as in 3D printers, DIY projects or special industrial applications. The NA-SC1 Sx2 set provides an easy way to efficiently control multiple fans in such systems without the need for additional fan hubs. These new products from Noctua offer flexible and effective solutions for various cooling requirements and add important options for use in confined and specialized environments to the company’s existing portfolio.
About Noctua:
Noctua is an Austrian manufacturer specializing in the development and production of premium cooling solutions for computers. Founded in 2005, the company is particularly known for its quiet and efficient fans and CPU coolers, which are highly recognized worldwide. Noctua products are characterized by high build quality, innovative technologies and a long service life. The company places great emphasis on low-noise performance and offers various fan sizes and cooler models for different applications, from desktop computers to high-end gaming systems.
Bisher keine Kommentare
2,731 Kommentare 12,773 Likes
Noctua hat seine A-Serie um neue 60mm Slim-Lüftermodelle erweitert. Der neue NF-A6x15 ist eine schlankere Variante des bisherigen NF-A6x25 und wurde entwickelt, um den Anforderungen von Geräten und Anwendungen gerecht zu werden, die Lüfter mit einer Dicke von bis zu 15mm benötigen. Er ist in zwei Spannungsvarianten (12V und 5V) erhältlich und bietet sowohl 3-Pin- […] (read full article...)
Thomas Wallossek
