Cooling Monitors Practice Reviews
Noctua Edition 200 Hz 3440×1440 G-Sync Ultimate Monitor?! | AOC Agon AG353UCG Fan Mod
I had already disassembled my new AOC Agon AG353UCG monitor the other day in search of the cause of the unpleasant background noise, where I then encountered the G-Sync Ultimate module with its massive heat sink. Since running it passively without a fan caused it to overheat and shut down, modifying the cooling solution is on the agenda today so that it hopefully quiets down and no longer bothers my ears at work and while gaming.
Disclaimer: I would like to state that I am not a trained electrical engineer and we do not make any recommendation for imitation of this mod. In addition, such interventions, as we will show in a moment, will of course void the warranty of the monitor. This article is therefore only to be understood as a practical experience report and at most as inspiration.
First, let’s look again at the initial situation. The cooler uses 5 copper heatpipes to conduct heat to a second set of cooling fins. There a 70mm radial fan from WHEE provides the necessary air flow, but blowing from top to bottom, against the natural convection. The pinout of the fan connector looks like PWM, but it is not controlled depending on the temperature and there is no audible change of the speed during operation.
Originally I just wanted to replace it with another radial fan or at least reuse the connector on the board, possibly with a resistor in the cable for throttling. But since there is not much choice in 70 x 10 mm fans and the connector with 1.25 mm pin pitch could not be found after hours of searching on Aliexpress, I had to find another way relatively quickly.
I then came across this Reddit post by user er0s3nnin_, who had a very similar problem with his Asus G-Sync display. Instead of just replacing the fan, he has also integrated an extra fan controller with temperature sensors into his display so that he can control the fan speed and noise himself depending on the temperature.
I liked this approach and the small controller board with its 3-digit digital display made a promising impression. I decided to use the same controller, because the display was important to me for control and with this model also the fan curve can be adjusted relatively granular. And if a single quiet first set fan doesn’t provide enough cooling power, I could run a second one with it later. The Molex adapter for 12 V you can see here I built myself quickly with my spare crimping supplies for a test run.
v
vonXanten
837 Kommentare 373 Likes
@skullbringer vllt. solltest du diesen Vorschlag mit einer leiseren Lüftung mal weiterleiten. Für mich wäre es ein Grund gewesen den Monitor zurück gehen zu lassen.
War ja auch lange Zeit bei PCs so, Hauptsache die Wärme kommt schnell und für den Hersteller günstig weg von der Quelle. Grafikkarten waren da ein Beispiel.
Und deine Punkte für die Spannungsversorgung sind zweckmäßig ;)
Blubbie
809 Kommentare 275 Likes
Es gibt ne Menge Leute die von lauten lärmenden Lüftern am Monitor berichten, aber auch andere deren baugleicher Monitor keinen krach macht.
Mich hat das damals bei der Monitor Wahl auch verunsichert, da das zurückschicken eines Monitors doch etwas aufwändiger ist.
Bin dann auf Nummer sicher auf einen Monitor ohne Lüfter der nur gsync kompatibel ist gegangen.
Martin Gut
8,267 Kommentare 3,936 Likes
Falls du einmal einen Lüfter bremsen möchtest, nimm keine Widerstände sondern Zener-Dioden.
Ein Widerstand macht das Verhalten des Lüfters müder. Er läuft langsamer an, erreicht mit der Zeit aber fast die selbe Drehzahl.
Mit mehreren Dioden in der Spannungsversorgung kann man die Spannung recht genau um 0.7 V pro Diode senken. Dadurch sinkt auch die Drehzahl wie gewünscht. Ich habe mal eine Grafikkarte beruhigt, indem ich etwa 7 Dioden in Serie gelötet habe um die Spannung von 12 V auf etwa 7 V zu senken. Das waren 4-Pin-Lüfter. Die Regelung über das PWM-Signal hat auch mit tieferer Versorgungsspannung normal weiter funktioniert, nur einfach auf deutlich tieferem Niveau.
Antwort 4 Likes
ro///M3o
385 Kommentare 279 Likes
Cooler Mod, der Lüfter ist im verbauten Zustand ja winzig und kühlt trotzdem sehr gut gegenüber dem Radial Lüfter. Das ist beachtlich.
Ein Loch in der Abdeckung genau über dem Kühlkörper vom Chip inkl. nem großen Lüfter und Staubfilter kam nicht in Frage?
Wie jetzt?
69 Kommentare 55 Likes
Ja, so sind wir Bastler halt. Was nicht passt wird passend gemacht. Wobei ich persönlich von Monitoren mit eingebautem Lüfter so gar nichts halte. Es gibt einfach Bauteile von denen ich erwarte das sie passiv gekühlt werden. Chipsätze gehören da auch dazu.
Antwort 4 Likes
skullbringer
327 Kommentare 359 Likes
Wäre natürlich auch ein vielversprechender Ansatz, wenn man es komplett passiv haben möchte. Mir war aber wichtiger, dass man den Mod äußerlich nicht erkennen und ggf. auch zurückbauen kann.
Tatsächlich hatte ich schon eher mit dem Gedanken gespielt, die Rückseiten-Abdeckung einfach dauerhaft weg zu lassen, hätte was sehr puristisches... 😁
Guest
Ghettomod quasi 😁
Alkbert
970 Kommentare 760 Likes
Ich möchte hier nicht falsch verstanden werden. Ich bin begeistert, was da technisch alles möglich - und letztlich für einen Teil der Konsumentengemeinde auch bestellbar - ist. Vom ökologischen Standpunkt her ist die Ganze Hardwareentwicklung in diesem Bereich allerdings eine Katastrophe, da hier der olympische Gedanke von höher, schneller, weiter den Vernunftaspekt weit aussen vor lässt. Ob das CPU´s sind mit über 280 W Peak Leistung, ob das Graphikkarten sind, die Netzteile mit 1 KW fast schon erforderlich machen, oder ob das Monitore sind, die - überspitzt formuliert - bald wieder den Strombedarf eines alten Plasmafernsehers konsumieren. Auch wenn der aufsummierte Strombedarf hier im Vergleich zu Muttis Föhn eher lächerlich klingt: Das Dingens läuft halt Stunden und nicht nur Minuten.
Ach so, Quelle: https://www.displayspecifications.com/de/model-power-consumption/89b61d1d
rockys82
281 Kommentare 98 Likes
Mit nur Lüfterwechsel wärs bei mir nicht getan, ich hätte mal den Kühler selbst demontiert, wahrscheinlich bringt LiquidMetal auch noch was... aber soein Monitor würde ich mir nie holen, der dieses Modul inne hat und dazu noch einen Lüfter.
AMD hat das mit Freesync besser gelöst und wird sich langfristig wie immer durchsetzen.
Xaver Amberger (skullbringer)
