At Computex 2025, Noctua presented itself at booth R0120 in Hall 2 of the Taipei Nangang Exhibition Center with a variety of new products and prototypes. As a long-time observer of the brand, it was particularly interesting to see how Noctua is expanding its product range while maintaining its focus on quiet and efficient cooling.
NH-D15 G2: further development of a classic
The NH-D15 G2 is the revised version of the well-known NH-D15 air cooler. It is available in three versions: Standard, High Base Convexity (HBC) for AMD processors and Low Base Convexity (LBC) for Intel processors. The HBC and LBC models are specially designed for the respective CPU heat spreaders to ensure optimum heat transfer. In addition, new offset mounting brackets (NM-IB8) have been introduced that offset the cooler 3.7 mm to the north and 2 mm to the east to improve cooling performance for Intel Arrow Lake processors.
NF-A12x25 G2: Optimized fan for various applications
The NF-A12x25 G2 is a further development of the popular 120 mm fan from Noctua. It offers improved performance and lower noise levels. The fan will be available in the classic Noctua color scheme as well as in a black version.
All-in-one water cooling: Noctua’s entry into the AIO market
Noctua presented prototypes of its first all-in-one water cooling systems based on Asetek’s Gen 8 V2 platform. The coolers feature a special noise reduction of the pump, an improved mounting system (SecuFirm ), an optional 80mm fan for cooling VRMs and memory as well as the new NF-A14x25 G2 or NF-A12x25 G2 fans. The market launch is planned for the first quarter of 2026.
Thermosiphon cooler: Pumpless cooling with future potential?
Another highlight was the updated prototype of the Thermosiphon cooler. This pumpless cooling system uses the evaporation and condensation of a fluid to transfer heat. The current version has a 360 mm radiator and flexible hoses for easier installation. No release date has been given as this is a long-term development project.
Collaborations: Products in collaboration with other manufacturers
Noctua presented several products that have been developed in collaboration with other companies:
ASUS GeForce RTX 5080 Noctua Edition: a graphics card with a cooling solution optimized by Noctua.
Antec Flux Pro Noctua Edition: A case with pre-installed Noctua fans and an NA-FH1 fan hub optimized for low noise.
Seasonic Prime PX HPD Noctua Edition: A compact power supply with a 120 mm NF-A12x25 G2 fan and high efficiency…
Pulsar x Feinman Noctua Edition: A mouse with an integrated 40 mm fan for palm cooling, based on the Pulsar Feinman F01 model …
The visit to Noctua at Computex 2025 offered a comprehensive insight into the company’s current developments. The products on show demonstrate Noctua’s continued focus on quality, performance and low noise as it enters new product categories and advances existing technologies.
4 Antworten
