Latest news PSU
Noctua and Seasonic introduce ultra-quiet 1600W power supply | Press release
Noctua and Seasonic have introduced the Seasonic PRIME TX-1600 Noctua Edition ATX 3.1 power supply for PCs. This power supply is based on Seasonic’s current flagship model and utilizes Noctua’s NF-A12x25 fans and a specially designed fan grille to enable quieter operation. The Seasonic PRIME TX-1600 Noctua Edition is particularly suitable for quiet workstations and gaming PCs where a reliable power supply is important.
Eric Lan, CEO of Sea Sonic Electronics, emphasized the importance of the collaboration with Noctua, a leading manufacturer of quiet PC fans and cooling technologies. He explained that this partnership is valuable due to the shared quality and performance standards of both companies. Eric Lan expressed his confidence that this cooperation will be successful and that the new power supply will be a top product for performance and silent enthusiasts.
Seasonic is known for manufacturing premium PC power supplies. The PRIME TX series, the company’s flagship product, is characterized by a modern electronic design, high-quality components, top performance and exceptional efficiency. The Noctua Edition of the TX-1600 combines this platform with the NF-A12x25 fan and an optimized fan grille, making it run around 8-10 dB(A) quieter than the standard model.
Roland Mossig, CEO of Noctua, expressed his pleasure about the cooperation with Seasonic and emphasized the high quality and innovative power of Seasonic. He explained that the combination of Seasonic’s power supply expertise with Noctua’s quiet cooling technology and acoustic optimization results in a modern 1600W power supply that operates very quietly.
The TX-1600 Noctua Edition PSU features semi-passive fan control, which operates passively at ambient temperatures of up to 25°C and a load of around 50% and only activates the fan when the load or temperature increases. This makes it a suitable choice for both powerful high-end systems and quiet systems that require less than 1600W. Even at 100% load, the Noctua Edition operates quietly at ambient temperatures of up to 25°C, generating only around 24 dB(A) compared to 34 dB(A) for the regular model. This noise reduction results in an improved Cybenetics Lambda rating from A to A .
The Seasonic PRIME TX-1600 Noctua Edition features ATX 3.1 and PCIe 5.1 support and fully modular Noctua-designed cables, making it an optimal choice for PC enthusiasts seeking high quality, performance and quietness.
p
pintie
201 Kommentare 140 Likes
schick. aber 1600W.. Threadripper System mit 2x GPU ?
das ganze mal in Schwarz mit 1000W und gutem Lüfter fände ich interessanter
B
Besterino
7,141 Kommentare 3,716 Likes
Mega. Merke ich mal für mein nächstes System vor, wobei mir auch was in der 1000W- oder 1200W-Klasse lieber wäre.
OldMan
208 Kommentare 81 Likes
Ob 1000W, 1200W oder 1600W ist doch vollkommen egal, wenn einen der Preis nicht stört. Ein Netzteil ist eh am effektivsten bei ca 50% - 70% der Nennleistung. Das heißt wenn Du richtige Powerkomponenten hast und Du die meiste Zeit so bei 500W - 800W bei der Leistungsaufnahme bist dann machen 1600W bei der PSU durchaus Sinn. Selbst wenn Du weiter nach unten kommst und nicht den optimalen Bereich triffst wird man es kaum im Geldbeutel, also beim Stromverbrauch merken. Ich denke aber dass wir in einem Preissegment um die 500-600€ sind und das will sich nicht jeder leisten.
B
Besterino
Völlig einig. Doof ist halt, dass in den obersten Leistungsklassen gerne ein überproportionaler Preisaufschlag dabei ist, auf den ich gerne verzichten kann. Heisst nicht zwingend, dass ich den nicht bereit wäre zu bezahlen. Kann das aber eben auch gerne lassen, wenn ich nicht muss. ;)
Jean Luc Bizarre
210 Kommentare 136 Likes
Vor allem, war das nicht so, dass bei ATX 3.1 die Wattzahlen eigentlich sinken sollten, weil die Dinge ja eh in in der Lage sein sollen, Spannungsspitzen viel größer, besser und länger ertragen zu können?
Thomas Wallossek
