Taipei – MSI presented a total of seven new gaming monitors from the MPG and MAG series at Computex 2025. The focus remains on QD OLED panels, supplemented by models with Rapid IPS and Rapid TN. The range extends from high-end devices with UHD resolution and 240 Hz to extremely fast 600 Hz models for e-sports enthusiasts. MSI is thus emphasizing its claim to position itself as a serious player in the display segment – with a clear focus on image quality and speed. And while Igor was busy with graphics cards and motherboards, our colleagues at WCCFTECH had their sights set on the monitors. They also ordered test samples.
QD-OLED dominates the upper market segment
The most striking devices in the line-up are based on the third and fourth generations of Samsung’s QD OLED technology. Models such as the MPG 271QR QD-OLED X50 and MAG 272QP QD-OLED X50 achieve a refresh rate of 500 Hz with a resolution of 2560 × 1440 pixels and a screen diagonal of 26.5 inches. These monitors are VESA DisplayHDR True Black 500 and ClearMR 21000 certified, which indicates a combination of high luminance and excellent motion display. The response time is 0.03 ms (GtG), which is a drastic reduction compared to conventional LCDs. The MPG 322URX QD-OLED is slightly larger and is technically based on the same platform, but offers a larger surface area of 31.5 inches – intended for immersive gaming environments. Those who require an even higher resolution will find a UHD model (3840 × 2160 pixels) with 240 Hz in the MPG 272URX QD-OLED. Thanks to DisplayPort 2.1a (UHBR20), a bandwidth of up to 80 Gbit/s is available, which creates sufficient scope for uncompressed 4K with high refresh rates.
Rapid IPS and dual mode: versatility instead of spectacle
With the MPG 274URDFW E16M, MSI also has a device in its range that works with a Rapid IPS panel and supports a so-called dual mode. Here, the user can switch between UHD at 160 Hz and FHD at 320 Hz – a pragmatic solution for gamers who want to switch flexibly between image quality and response speed. The 27-inch device offers G-Sync compatibility and is therefore aimed at users with NVIDIA GPUs. The MAG 272QPW QD-OLED X28 – a third-generation QD-OLED monitor with 280 Hz – also appears in the mid-price range. Compared to the X50 model, the feature set is somewhat slimmed down, but this also suggests a lower entry hurdle in terms of pricing.
Extreme case for e-sports: 600 Hz with Rapid TN
Probably the most striking new addition is the MPG 242R X60N, which is clearly aimed at the e-sports community. With a frame rate of up to 600 Hz at Full HD resolution (1920 × 1080 pixels) and a response time of 0.1 ms (GtG), MSI is targeting particularly competitive gamers here. The 24-inch display uses a Rapid TN panel, which comes with a classic 4:3 mode and KVM support – the latter is particularly relevant for users with multiple systems. The 4:3 mode is likely to be of particular interest to CS gamers, as this aspect ratio is traditionally preferred in the scene.
MSI is following a clear line at Computex 2025: QD-OLED remains the focus in the premium segment, supplemented by niche models for e-sports and multi-mode users. The monitors on display cover a broad spectrum – from UHD with a high frame rate to full HD with maximum frequency. The combination of technical diversity and the consistent integration of functions such as DisplayPort 2.1a, KVM or OLED-specific protection mechanisms (OLED Care 2.0) is striking. It remains to be seen whether MSI will be able to hold its own against established display manufacturers in the long term – but the will to compete is unmistakable.
Source: wccftech
1 Antwort
