It should come as no surprise to anyone that the QD OLED bandwagon is picking up speed. Samsung Display is now supplying third-generation panels, and now MSI is also entering the race with two monitors aimed specifically at enthusiasts – or at least those who like to race across their favorite maps at 500 frames per second. The new displays were unveiled at Computex 2025 under the model names MAG 272QP QD-OLED X50 and MPG 271QR QD-OLED X50.
Resolution, speed and response time
Both models rely on a 27-inch panel with native 2560×1440 resolution (i.e. 2K) and an impressive – at least on paper – maximum refresh rate of up to 500 Hz. The target group is clear: competitive gamers who (want to) see the difference with every frame. According to the manufacturer, the response time of the panels is just 0.03 ms GtG, which at least theoretically ensures minimal motion blur and almost instantaneous switching. As usual, whether this 500 Hz can realistically be achieved permanently depends on the graphics card, the game and the other conditions. In any case, MSI is clearly focusing on maximum performance here – with high picture quality thanks to OLED technology.
QD-OLED of the third generation
Both displays use the third generation of Samsung’s QD OLED panels. Among other things, these should offer higher brightness, a better color gamut and an improved lifespan compared to previous iterations. At the same time, however, the known weak point remains: Burn-in. MSI is trying to counteract this with “OLED Care” – however, the manufacturer does not specify the concrete measures or technologies behind this in detail.
AI sensor technology – at least on one model
The MPG 271QR QD-OLED X50 also comes with a function that MSI markets as the AI Care Sensor. The term refers to an integrated NPU-based IC (probably a dedicated AI chip) which, according to the manufacturer, captures images of the user every 0.2 seconds and dynamically adjusts the display settings. Presumably this refers to brightness, color temperature or similar – although MSI is also stingy with details here. This sensor should also be able to recognize human shapes with a high degree of accuracy, which could be used for image optimization or switching off during inactivity, among other things. Sounds like a somewhat overambitious feature whose real use in everyday life has yet to be proven.
Certificates and missing information
Both monitors have relevant certifications. The MPG 271QR is labeled with DisplayHDR True Black 500 and ClearMR 21000. This indicates high contrasts and low motion blur – provided the implementation is clean. The MAG 272QP does not yet have this information. Interestingly, MSI does without the AI Care Sensor on the MAG 272QP, otherwise the features appear to be largely identical. The following also applies to this model: 2K resolution, QD OLED, 500 Hz, 0.03 ms GtG. What’s missing? Pretty much everything that would be important for a concrete classification: connections, color space coverage, ergonomics, price, availability. Whether there is active cooling (which is not unusual for OLEDs with high brightness) also remains open.
Assessment of the market situation
In terms of price, the whole thing will probably be well above the price of already known QD OLED models such as the MAG 271QPX – this is currently around 700 US dollars, but “only” offers 360 Hz and uses the second panel generation. So if you want 500 Hz, you will probably have to dig deep into your pockets – if the devices actually become widely available. Whether the refresh overkill will pay off in everyday life is a question in itself anyway. Because despite all the enthusiasm for new technology, in the end it’s not what’s on the box that counts, but what arrives at the desk – and whether the game actually delivers 500 FPS is another story.
Source: MSI
1 Antwort
