Allgemein GPUs Graphics Latest news
MSI Radeon RX 7900 GPUs unveiled, no hint at reference models
MSI says no to AMD designs? Kind of. The company finally fulfills its promise and announces the first Radeon 7000 GPUs on a tried and true basis. This is to be done before the end of January. However, no relabeled AMD reference models (MBA) will be launched for the time being.
MSI Radeon RX 7900 Gaming Trio Classic GPU, Source: MSI
The company has now revealed the full specifications of the new Radeon RX 7900 series. This is also an indicator that MSI will not use the AMD reference models, since no such cards are listed (so far).
The MSI Gaming Trio Classic is a new custom model based on AMD’s RX 7900 XTX and XT GPUs. Both cards are now officially listed on the MSI website and at some third-party vendors. MSI also confirms that the Gaming Trio Classic GPUs will use AMD’s standard clocks, so again, there will be no factory overclocking.
The Classic models are almost a direct copy of the Radeon RX 6900 series. The RX 7900 XT card appears to use the same cooling design as the RX 6950XT Gaming Trio model, but the carrier plate and back plate have been changed to match the Navi 31 design. It is worth noting that the back panel does not have an RGB LED strip like the previous model.
The MSI RX 7900 Gaming X-Trio is a 2.5-slot design with three fans. Both cards measure 32.5×14.1×5.6 centimeters, so they are definitely not the thickest RX 7900 cards on the market. What might be interesting is that both models are equipped with 3x 8-pin power connectors.
Radeon™ RX 7900 XTX GAMING TRIO CLASSIC 24G
Boost Clock / Memory Speed
Up to 2500 MHz / 20 Gbps
24 GB GDDR6
DisplayPort x 3 (up to v2.1)
HDMI™ x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI™ 2.1)
TRI FROZR 2 Design
TORX Fan 4.0 – Fan blades work together in pairs to create unprecedented concentrated air pressure.
Precision-machined heatpipes ensure maximum contact with the GPU and distribute heat along the entire length of the heatsink.
Airflow Control: Don’t worry, Airflow Control directs air exactly where it’s needed for maximum cooling.
The MSI RX 7900 series is now listed by French retailers for €1230 and €1130 for XTX and XT models, respectively. Unfortunately, none of the cards are in stock, so availability is still in question.
Source:MSI via Wccftech
Not_A_Nerd
49 Kommentare 45 Likes
Eine wirkliche Empfehlung war MSI ja noch nie mit seinen Lösungen für AMD GPU Serien.
Hier gab und gibt es deutlich bessere AIBs.
RX480
1,898 Kommentare 895 Likes
Leider wahr, zumindestens die 6950 war voll daneben mit den zu kleinen Spawas.
(vgl. mit der Pure ist die Trio nuuur Schrott)
Warum MSi den 7000ern net die besseren neuen 5.0 Lüfter spendiert, who knows.
(sind den 4000ern vorbehalten)
Keine Empfehlung für OCer oder empfindliche Ohren.
edit: Wer nur UVtet mit abgesenktem PL kann schon ne MSi nehmen, wenn der Preis passt
(das ist bei mir mit der 6800nonXT supi, ... übrigens war auch ne Stütze im Lieferumfang, das Tool für die Beleuchtung kann man nach einmal einstellen
sogar deinstallieren, geht dann trotzdem weiterhin)
Casi030
11,923 Kommentare 2,339 Likes
MSI war mal gut,diese Zeiten sind aber auch schon länger vorbei.
Alexander Brose
836 Kommentare 598 Likes
So ungefähr seit dem Zeitpunkt, wo Jensen sein GeForce Partner Program einführen wollte? ;-)
Grüße!
Chismon
144 Kommentare 99 Likes
Na, wenn ich mich richtig erinnere, war MSI bei den RX 470er Gaming X (8G) Modellen mit 8GB doch damals gut unterwegs bis vorbildlich, ergo "sag' niemals nie" :).
Aber gut, ob das bei den aktuellen MSI nVidia Karten viel besser laeuft ist fraglich, denn die RTX 4070Ti Suprim von MSI - die hier zwar als ganz ordentlich empfohlen wurde - hat bei Hardware Unboxed vergleichsweise schlecht bzgl. der Kuehltemperaturen abgeschnitten (ab ca. 21:12 im nachfolgenden Video), auch im Vergleich zu anscheinend deutlich besser gekuehlten Gigabyte Modellen, insbesondere der sehr gut gekuehlten und deutlich guenstiger angesiedelten Gigabyte RTX 4070Ti Eagle Billigst-/Einsteiger-Karte:
Ich hoffe, dass MSI - egal ob bei nVidia oder AMD/RTG oder evt. sogar Intel und am besten bei den Chips aller Hersteller - wieder an glorreichere Zeiten werden anknuepfen koennen mit eigenen Custom-Modellen, aber die ganze EVGA Chose hat ja wohl eher gelehrt, dass die Margen i.d.R. eher duerftig sind bei den Boardpartnern (das zeigt auch der nVidia Margen/Profit-Cut von 100 US$ von der "unlaunchten" RTX 4080 12 GB zur RTX 4070Ti, der immer noch massig Raum fuer Profite bei nVidia zu lassen scheint) und darunter duerfte auch die Ausstattung/Qualitaet bei den MSI Karten - die i.a. schon laenger nicht mehr zu den Boardpartnern mit den guenstigsten Modellen gehoeren - leiden, aber verallgemeinern wuerde ich das trotzdem nicht (dass MSI Grafikkarten nicht mehr zu empfehlen sind).
Tanzmusikus
256 Kommentare 69 Likes
Meine MSI HD 5770 Hawk und meine (ehemalige) MSI R9 290X Lightning waren & sind gute AMD-Karten.
Laufen sogar noch immer ... ;) (y)
Meine momentane (AMD -> MSI) umgelabelte Referenz-Karte RX 5700 XT läuft mit AiO-WaKü auch ordentlich.
Vermutlich möchte MSI bei den neuen 7000er Karten die Kontrolle über Material & Preis behalten bzw. wieder erlangen.
Eine umgelabelte Karte bringt Ihnen vermutlich zu wenig.
10,786 Kommentare 20,428 Likes
Genau dafür hat doch die MSI-Karte einen BIOS-Switch! Etwas wärmer und unhörbar oder schön kühl und zumindest leicht hörbar. Per default steht sie übrigens auf sehr leise. Ich würde jetzt die 61 °C im geschlossenen Gehäuse (Performance Mode) nicht unbedingt als heiß bezeichenn.
Die dann gemessenen 32 dBA (statt 29) sind auch noch ok. Manchmal verstehe ich die YTer auch nicht wirklich :(
Chismon
32 dBA sind m.E. auch ziemlich gut (okay, ich bin auch kein Silent-Gamer/Fetischist), aber es wird wohl der Vergleich zu noch besseren (kuehleren und guenstigeren) Modellen sein, der dort die MSI Suprim nach den Tests der Karten eher hinten gesehen hat.
Evt. ist deren Kartensample auch nicht so rund gelaufen (auf mich hat es den Eindruck einer Verwunderung und Enttaeuschung bzgl. des Suprim Modells seitens Hardware Unboxed gemacht), wer weiss?
Genau aufgeschluesselt sind die sonstigen (scheinbar guten) Resultate fuer das Eagle Modell von Gigabyte aber auch nicht naeher (andere Prioritaeten und eben auch ein Vergleichstest auf Kosten der Tiefe).
T
Toni Decker
8 Kommentare 0 Likes
ihr meint also die MSI Karten sind nicht so gut?
auch nicht die 6900xt Gaming Z Trio?
warum ist sie eurer Meinung nach nicht so gut?=
Alexander Brose
Würde ich so nicht sagen! Bin mit meiner 6900XT Gaming X soweit ganz zufrieden, sie ist recht leise und dennoch kühl.
Man merkt aber deutlich, dass die Suprim Serie noch "draufgelegt" wurde, dagegen wirken die Gaming X/Z Karten schon bisschen nach Plastikbomber. Ich finde auch die RGB Steuerung nicht gut (nur eine Zone und minimale Einstellungsmöglichkeiten) und die Software (MSI Center) ist gelinde gesagt ein Krampf.
Grüße!
RX480
als 6900 mit moderaten Watt geht MSi, aber die 6950 Trio bei Igor im Review war ein echtes Montagsmodell, wo die Spawas+Kühlung vollkommen
überfordert sind, ... gemessen an der PURE
k.A. wieso dann die Effizienz soooo komplett im Eimer ist, vermutlich Phasen+Spawas net ausreichend dimensioniert
und k.A. warum die 7000er von MSi net die neuen Kühler/Lüfter ala 4000 bekommen
Samir Bashir
