Now that Minisforum hasn’t appeared here for a while, it’s back in full force. Because the model I’m presenting to you today can be equipped as you need it thanks to the AM5 base. So let’s take a look at this little powerhouse together.
The plainly designed box seems to have taken a beating on its way to me, if you take a look at the dented corner.
Apart from the product image on the front and the stick-on overview on the back, there’s not much else to see.
A look inside doesn’t reveal much either, as the system itself is once again wrapped in a bag.
The included accessories are certainly more exciting than what we usually get to see here. We have the M.2 to SATA adapter card, a small tool and HDMI cables. But there is also a real chunk of a power supply unit, as up to 240 watts are possible with the SOY-1901263-244-B.
Specifications
Here is an overview of some of the technical details, further information can be found on the manufacturer’s product page.
9 Antworten
