GPUs Graphics Practice Reviews
Local hotspots on RTX-5000 cards: When board layout and cooling design don’t work together and a pad mod has to help
Recently, several current graphics card models in the RTX 5000 series, including the RTX 5080, 5070 (Ti) and 5060 Ti in particular, have shown thermal anomalies in the area of local hotspots on the back of the board in my tests. These affect cards from major board partners such as Palit, PNY and MSI as well as variants from other manufacturers, which (have to) largely adhere to the reference design specified by NVIDIA. The thermal load does not manifest itself as a systemic temperature problem of the GPU cores themselves, but in the form of pronounced heat nests below the power supply – often in areas that are hardly cooled or mechanically connected at all when viewed from the rear.
At the center of these observations is the interplay of PCB layout, current routing in the inner layers and insufficient thermal decoupling in the mechanical design of the cooling units. While the electrical design is superficially correct and functional, the voltage converters, the vias between the VRM stages and the GPU pads as well as the current-carrying tracks in the PCB are subject to considerable power losses at certain points, which can lead to temperatures without appropriate heat dissipation that have a lasting negative impact on material integrity and ageing behavior. The affected cards have a very similar layout structure, which leads to the conclusion that these are not individual manufacturing errors, but rather a result of a lack of coordination between the board and cooler design.
Important: The aim of today’s investigation is by no means to give cause for concern or to express blanket criticism of individual manufacturers. Rather, the objective presentation of technical correlations is intended to help raise awareness – especially where several parties are involved in the manufacturing process. Layout managers at board partners are often directly dependent on external PCB suppliers and have to adapt their designs to cooler solutions, which in turn are created under separate design and manufacturing premises. The lack of interoperation between these development lines then leads to design compromises which – as in the present case – can have unfavorable thermal effects without one of the parties involved being able to fully oversee this in isolation.
In a specific case, a simple modification was carried out today on an affected card, in which the affected hotspot was significantly mitigated by the targeted installation of additional thermal head solutions on the back using thermal pads or thermal putty. The temperature difference at the critical point was reduced by almost 10 Kelvin with an identical load situation for one card, which impressively demonstrates that considerable improvements can be achieved with minimal intervention. This observation underlines the central importance of a holistic view of the PCB layout, current path design and mechanical heat dissipation – especially in the context of series products that are designed for long operating times under high continuous load.
Brief introduction to layout and manufacturing issues
The supply of high currents on modern graphics card boards represents a central challenge in the interplay between electrical performance, thermal controllability, mechanical integrity and economic manufacturability. The layout of high-end models in particular, which have peak outputs of up to 600 watts, is designed in such a way that enormous currents – sometimes well over 30 amps per voltage domain – have to be distributed and routed in an extremely confined space. The resulting technical demands on the design, choice of materials and manufacturing tolerances are naturally correspondingly high. However, we will see that even cards with a peak power of just 180 watts can be affected if the topology is concentrated on just a few supply phases and the problem persists due to the concentration.
GeForce RTX 5080
From a technical point of view, the problem begins with the dimensioning of the traces. Copper layers on a PCB typically only have a layer thickness of 35 to 70 micrometers per layer pair (1 to 2 oz Cu). In order to still provide sufficient cross-section for high currents, several layers must be connected in parallel, which is done via so-called power planes – large copper areas that are explicitly intended for current distribution within the layer stack. These areas are connected vertically via densely placed via arrays. This results in locally high current densities, especially at the transitions from voltage converters to the GPU or memory, which are particularly critical both electrically and thermally.
A key aspect of the layout is the placement and phase design of the VRM components. As modern GPUs have several separate supply rails (e.g. NVVDD, MSVDD, FBVDD), the power supply must be segmented and yet as low-loss and synchronized as possible. This is usually done using parallel multiphase converters that are positioned as close as possible to the respective load points in order to keep inductance losses low. However, the components required for this (FETs, coils, drivers) require space, which is limited, especially in dense layouts. The consequence is a concentration of high-current-carrying structures in a small space – a situation that is difficult to control thermally if suitable measures for heat distribution and dissipation are not taken at the same time.
In terms of production technology, it is generally possible to manufacture high-current PCBs with several copper layers, reinforced vias (e.g. via filled or stacked micro-vias) and complex power layer structures. The use of heavy copper designs with up to 3 oz Cu per layer is also available, albeit with significant limitations in terms of cost, mechanical processability and minimum spacing in the design rule set. Such solutions have been tried and tested in industry, but for cost reasons are used almost exclusively in the server or industrial electronics sector, not in consumer graphics cards.
Figure: Highly abstracted side view of a multilayer PCB with several power planes, the large copper layers embedded at different depths on the board. These layers are responsible for the low-loss distribution of the supply voltage. Vias are used to bring this supply to the surface of the board – for example to GPU pads or memory modules. These plated-through holes create the vertical connection between the copper layers. The critical point is the region where several vias lead close together into a very small area. The current density is highly concentrated there. With limited heat dissipation in the Z-axis of the PCB (vertical), this leads to localized heating – the hotspot.
The economic framework conditions set tight limits on what is technically possible. In series production, every layer, every via concept, every waiver of standard processes counts – both in terms of unit costs and production time. PCB manufacturers optimize for high yield with low variance. Accordingly, many board partners are reluctant to deviate from the reference design when developing custom PCBs, as this entails extensive thermal validation, EMC testing and mechanical adjustments. The cooling solutions are also usually designed according to fixed tolerance grids, which leaves only limited room for structural changes.
In practice, this means that current-carrying paths are often routed up to the load limit of the thermal and electrical specification, with no additional leeway for ageing, manufacturing variation or load peaks. This results in structures that function reliably under ideal conditions but react sensitively to minor deviations in cooling, placement or load distribution. The resulting local hotspots are therefore an expression of a supply system that works in principle but is not designed to be robust – with all the risks that this can entail in long-term operation.
p
pinkymee
131 Kommentare 147 Likes
Toller Artikel! Danke dafür.
Allerdings traue ich keinem dieser Hersteller. Schließlich soll man nach spätestens 2 Jahren was Neues kaufen. Was kommt da gelegener, als eine hausgemachte Alterung, aufgrund von thermischer Überlastung? Ich kann nicht glauben, dass die Herren des Designs und der Entwicklung, keine Wämebildkamera besitzen. Wer das einfach so annimmt, ja, der soll dann auch einfach an den Osterhasen und Weihnachtsmann glauben. Ooh Mist, das war jetzt für Viele ein Spoiler! Verdammt, sorry, war mit Absicht ;)
Für mich ist das volle Absicht. Keins dieser Produkte soll ewig halten. Mindestens die gesetzliche Gewährleistung, danach ist jedes Ableben willkommen ;) Und genau deswegen juckt es die auch nicht, wenn Igor die Herren darauf anspricht. Die wissen es längst :ROFLMAO: Soll ja so sein.
Antwort 6 Likes
12,111 Kommentare 23,904 Likes
So eine genaue? Eher nein. Immerhin hatte sich seinerzeit das Gigabyte R&D nach dem Besuch hier in Chemnitz eine für 12K gekauft. Wenn ich darüber nachdenke, wie es bei PC Partner aussah: Hotboxen mit angeklebten K-Widerständen und Mädels, die mit eher lausigen FLIR-Handhelds in schrägen Winkeln messen.
Antwort 7 Likes
M
Mr.Inkognito
57 Kommentare 31 Likes
Die Hersteller müssen doch jedes GPU-Design von Nvidia prüfen und abnehmen lassen.
Prüft Nvidia auch das Kühlkonzept und wenn ja, wie aufwendig ist diese Prüfung?
In wie weit erlaubt Nvidia nachträgliche, minimale thermische Anpassungen des Kühl(er)Design durch die Hersteller, wenn die Hersteller Designprobleme feststellen?
Kühlung wird nur sensorisch gemessen. GPU und Memory. Die Prüfung ist ein Witz. Die Hersteller messen selbst und tragen das dann in die Green Light Software ein. Das ist quasi Essen auf Rädern, analog Audio...
Antwort 4 Likes
C
Cyco
27 Kommentare 40 Likes
Mal blöd gefragt. Meist haben die Backplates ja keine stabilisierende Funktion. Reicht es da nicht einfach die Backplatte wegzulassen, um die Wärmenester zu reduzieren? Gerne auch noch mit anblasenden Lüfter auf die Region?
Thermische Anbindung an die Plate ist besser. Und sie stabilisieren durchaus ;)
Antwort 5 Likes
c
cunhell
669 Kommentare 682 Likes
Ich weiss ja nicht, mir scheint zumindest Nvidia spart zur Zeit an allen Ecken und Kanten. Stromversorgung suboptimal konstruiert und implementiert, Treiber sind so lala und auch die Kühlerkonstruktionen scheinen nicht wirklich durchdacht zu sein.
Und das nicht bei Entry-Level-Karten sondern auch bei hochpreisigen Modellen.
Man zehrt von dem Guten Ruf den man sich über Jahre erarbeitet hat. Ist der einmal angekratzt, könnte das irgenwann eine Negativ-Spirale zumindest in dem Grafikkartenbereich einläuten .
Hochmut kommt vor dem Fall heisst es doch so schön.
Cunhell
M
Mr.Inkognito
Erlaubt Nvidia Änderungen des Kühldesign auf den kurzen Dienstweg oder muss die GPU das kompletten Genehmigungsverfahren erneut durchlaufen?
p
pinkymee
In der heutigen Zeit ist das doch echt n'Witz ...... :eek: :ROFLMAO:
Naja. Wenn du Kameras im 5-stelligen Bereich anschaffen musst, dann eher nicht
2,473 Kommentare 1,615 Likes
Obwohl das auf der einen Hand sehr viel Gutes über Dein Labor aussagt, ist es andererseits schon erschreckend, daß einige sogenannte Boardpartner hier im Blindflug agieren. Da wundere ich mich schon fast, daß nicht mehr GPUs den schnellen Hitzetod sterben.
Und zumindest Gigabyte hat ja nach dem Besuch bei Dir gemerkt, daß sie hier Nachholbedarf haben bzw hatten. Was ich Gigabyte eher als Pluspunkt anrechne.
Karsten Rabeneck-Ketme
109 Kommentare 47 Likes
Danke für den tollen Artikel!
Das heißt, die Hersteller zertifizieren sich selber? Was könnte da schon schiefgehen 😜?
So ähnlich ging das ja bei Boeing mit der 737 Max: die Firma machte die meisten Sicherheitsprüfungen selber, und versicherte dann der FAA (US Flugaufsichtsbehörde) daß alle Tests bestanden wurden und das Design okay ist.
R
Rai
106 Kommentare 39 Likes
Immer wieder schön, wenn sich ein unabhängiger Tester dieser Problem annimmt, auch unter Inkaufnahme teurer Messtechnik. Vielen Dank. Die Lösung könnte so einfach sein, aber scheinbar steht das nicht auf der Prioliste der Hersteller. Man sollte sich eigentlich denken, das ein Nachmessen seitens der Boardpartner diese Probleme offenlegt, das nicht gehandelt wird, zeigt, das es wohl nicht passiert.
c
cunhell
Tja, ein paar LED-Lämpchen als Designelemente sind halt billiger als eine durchdachte bzw. überdachte Kühlerkonstruktion.
Bling-Bling sehen die Kunden, Hotspots, die die Dauerhaltbarkeit verringern aber nicht.
Und messen kann man die auch nicht immer :)
Cunhell
R
RazielNoir
618 Kommentare 292 Likes
Was aber für NVIDIA als Ersteller der Referenz locker aus der Taschengeldkasse kommen dürfte. Und zumindest fürs Refenrenzdesign wäre es eben auch von Vorteil, nicht nur eine Simulation, sondern auch eine vollständig funktionale Karte als Testmuster gegenzuprüfen. Simulation gut und schön, aber es wäre nicht das erste Mal, das eine Simulation Problemstellen nicht aufzeigt.
Alkbert
1,067 Kommentare 851 Likes
"[...]Auch der Einsatz von heavy copper-Designs mit bis zu 3 oz Cu pro Layer ist verfügbar, allerdings mit erheblichen Einschränkungen hinsichtlich der Kosten, mechanischen Verarbeitbarkeit und Mindestabständen im Design-Rule-Set. Solche Lösungen sind industriell erprobt, werden aber aus Kostengründen fast ausschließlich im Server- oder Industrieelektronikbereich eingesetzt, nicht in Consumer-Grafikkarten.[...]"
Vielleicht sollten alle Beteiligte an der Produktion mal darüber Gedanken machen, die Gewinne aus den exorbitanten Kosten für die heutigen Graphikkarten nicht ausschließlich irgendwelchen dahergelaufenen Shareholdern in die Taschen zu stopfen, sondern in der Breite mal an die Qualität und den Endverbraucher denken, der sich zunehmend mehr und in jedem (!) Bereich mit "läuft gerade mal so" Produkten herumärgern muss. Ein Quasi-Monopol macht die Sache natürlich nicht besser.
d
daddler
10 Kommentare 5 Likes
Dass man nicht groß am Design schraubt und letztlich mit mehr Platz- oder Kupferbedarf die Kosten in die Höhe schraubt ist wirtschaftlich natürlich verständlich. Um das Thema nachvollziehen zu können braucht man bestimmt auch keine 12k FLIR Kamera, eine Portion Hausverstand tut es auch, denn die Layerstärken und Anzahl der Durchkontaktierungen sind ja auch nicht Daumen x Pi geschätzt, sondern basieren auf technischen Regelwerken - also an sich sollte klar sein, wie viele Elektronen in dem Bereich angestoßen werden und dass die bei ihrem Tango etwas Wärmeenergie frei setzen.
Wenn wir eine 5060ti für 449 ausm Regal holen, wäre spannend zu wissen wie viel am Ende als Marge beim Boardpartner wirklich übrig bleibt. Ich habe den Eindruck, dass der Kostendruck enorm ist und in Wahrheit nur durch gezielte Effizienzsteigerung und Einhaltung von Vorgaben der Hersteller auf Punkt und Beistrich gerade so noch Asche hänge bleibt am Ende des Tages.
Wenn sich die Sache allerdings mit einem Klecks Thermal Putty auf der Backplate halbwegs lösen lässt - das wird das Budget wohl nicht sprengen. Wenn man damit die dauerhafte Zuverlässigkeit des Produktes merklich steigern kann, würde das tatsächlich lohnen. Dass es am Ende nicht viel mehr sein kann/darf, um wettbewerbsfähig zu bleiben, ist halt Fakt.
c
cunhell
Wieso, Nvidia macht alles richtig. Geld sparen und mit den Gewinnen Mitbewerber unter Druck setzen, da man mehr Geld für Personal zur Softwareentwicklung zahlen kann. Und die, wie man weiss, ist heute bei Grafikarten mindestens ebenso wichtig wenn nicht sogar deutlich wichtiger als die Hardware.
Und viele Hardware-Seiten/Influenzer messen einmal Benchmarks und loben die nächste Kartengeneration über den grünen Klee ob der tollen neuen Features. Über die handwerkliche Umsetzung der Karten machen sich die wenigsten davon Gedanken. Von Analysen à la Igor ganz zu schweigen.
Und geht es doch mal schief, wird der User als Schuldiger hingestellt und bekommt dann auch noch hämische Kommentare der Community zu hören.
Da kommt der Hersteller aus dem Grinsen gar nicht mehr raus.
Cunhell
Follow Igor:
