Computex Latest news
Lian Li and Lancool at Computex 2025: Aesthetics meets functionality
At Computex 2025, Lian Li and its sub-brand Lancool presented an impressive range of new products that impress with both innovative design and technical sophistication.
New cases
The Lancool 4 is characterized by a striking tempered glass front with three integrated 140 mm fans. This combination not only provides a clear view of the components, but also efficient cooling. The vertical PSU mounting creates additional space for GPU cooling. The case will be available from October 2025 at a price of 129.99 USD.
The Lancool 217 INF combines an Infinity Mirror front with two 170 mm fans, which not only provide an impressive look, but also ensure a high air flow rate. The integrated L-Wireless technology enables wireless control of the lighting effects.
With the Lancool 207 Digital, Lian Li introduces a 6-inch LCD display that can be customized via the L-Connect 3 software. The case comes with four pre-installed fans and a 90-degree rotated PSU mounting for easier cable management.
The revised version of the O11D Mini now offers space for ATX mainboards and standard ATX power supplies without compromising the compact design of 45 liters. A slightly protruding rear panel design enables this expansion, while a 10 degree inclined fan bracket optimizes GPU cooling.
New AiO and power supply series
The HydroShift III is an all-in-one water cooling system with a 2K panoramic screen on the pump head. The screen can be rotated so that the display can be adjusted depending on the orientation of the housing. Internally, the cooling performance has been improved with optimized components.
Lian Li introduced four new power supply series: DWS, RS, RB and SP. Particularly noteworthy is the RS series with a 90-degree rotatable power connector, which facilitates cable management in various case configurations.
Lian Li and Lancool demonstrated their ability to harmonize design and functionality at Computex 2025. The products presented offer well thought-out solutions for modern PC construction for both enthusiasts and professional users.
Bisher keine Kommentare
2,786 Kommentare 12,936 Likes
Auf der Computex 2025 präsentierten Lian Li und seine Submarke Lancool eine beeindruckende Palette neuer Produkte, die sowohl durch innovatives Design als auch durch technische Raffinesse überzeugen. Neue Gehäuse Das Lancool 4 zeichnet sich durch eine markante Front aus gehärtetem Glas mit drei integrierten 140-mm-Lüftern aus. Diese Kombination ermöglicht nicht nur eine klare Sicht auf die Komponenten, sondern auch eine effiziente Kühlung. Die vertikale PSU-Montage schafft zusätzlichen Raum für die GPU-Kühlung. Das Gehäuse soll ab Oktober 2025 zu einem Preis von 129,99 USD erhältlich sein. Das Lancool 217 INF kombiniert eine Infinity-Mirror-Front mit zwei 170-mm-Lüftern, die nicht nur für eine beeindruckende […] (read full article...)
Follow Igor:
