PSU Reviews
Is the Seasonic PRIME Noctua TX-1600 still reliable with less airflow? Thermal comparison with the standard power supply unit
I tested the Seasonic Prime Noctua TX-1600 some time ago and found it to be a good power supply. However, I was concerned by the fact that the fan was replaced without making any internal adjustments. Therefore, I decided to test it again and this time perform a full thermal analysis. For this investigation, I used a commercially purchased specimen, not the test sample originally provided by Noctua.
A manufacturer must perform a full thermal analysis if a significant change to a component could affect the cooling of a power supply or other IT components. Thermal sensors are carefully attached to all critical components without affecting the internal airflow. The power supply is then pushed to its performance limit to determine whether and to what extent the change affects reliability and operation – especially compared to the original configuration. This is exactly what is being investigated today with the Seasonic Prime Noctua TX-1600 and the regular TX-1600 version.
According to Noctua, this power supply is around 8-10 dBA quieter than the standard version in the speed range from 17 to 100%. This indicates a less aggressive fan control. In addition to the fan modification, Noctua has also changed the top cover. Inside, however, there are no differences – both power supplies use identical heat sinks. And now? I’ll just do what Noctua should have done. Or Sesonic, or even better both.
Manufacturer (OEM): Seasonic
Max Power: 1600 W
Cybenetics Efficiency: Cybenetics Efficiency: [115V] Cybenetics Titanium (91-93%), [230V] Cybenetics Titanium (93-95%)
80 Plus Efficiency: n.a.
Noise: Noise: Cybenetics A ( <15 dB[A])
Compliance: ATX v3.1, EPS 2.92
Alternative low power mode support: Yes
Operating Temperature: (Continuous Full Load): 0 – 50 °C
Power 12V (Combined): 1600 W on one single rail
Power 5V 3.3v: 125 W
Power 5VSB: 15 W
Cooling: 120 mm Hydraulic Bearing Fan (NF-A12x25 – High-Speed)
Semi-Passive Operation: ✓ (Selectable)
Modular Design: Yes (Fully)
High Power Connectors: 3x EPS (3x cables), 6x PCIe 6 2 pin (6x cables), 2x PCIe 12 4 pin (600W)
Peripheral Connectors: 18x SATA (5x cables), 3x 4-pin Molex (1x cable)
Cable Length: ATX Cable Length: 610 mm
EPS Cable Length: 700 mm
6 2 pin PCIe Cable Length: 750 mm
12 4 pin PCIe Cable Length: 650 mm
Distance between SATA/Molex connectors: 155/125 mm
In-cable capacitors: No
Dimensions (W x H x D): 150 mm x 86 mm x 210 mm
Weight: 3.18 kg (7.01 lb)
Warranty: 12 years
Power Specifications
Rail 3.3V 5V 12V 5VSB -12V
Max. Power Amps 25 25 133.33 3 0.5
Watts 125 1600 15 6
Total Max. Power (W) 1600
Seasonic Prime TX-1600 Noctua Edition 1600W ATX 3.1 (SSR-1600TR2 NE)
Caseking.deVorbestellung549,90 €*Stand: 27.03.25 13:49
alza.deLagernd, Lieferzeit 1-3 Werktage629,90 €*Stand: 27.03.25 12:40
*Alle Preise inkl. gesetzl. MwSt zzgl. Versandkosten und ggf. Nachnahmegebühren, wenn nicht anders beschriebenmit freundlicher Unterstützung von geizhals.de
l
letauch
18 Kommentare 16 Likes
Hallo zusammen,
die Elkotemperaturen wurden ja auch erfasst. Das sind die eigentlich lebensdauerbestimmenden Bauteile auf solchen Platinen. Da sind die Messwerte jedoch nicht in der Tabelle aufgeführt.
Wie verhalten sich diese?
Grüße
letauch
11,881 Kommentare 23,302 Likes
Ich habe die Frage mal an Aris weitergeschickt. :)
B
Besterino
7,351 Kommentare 3,890 Likes
Na toll. Doof, dass das jetzt erst kommt, allerdings scheint mir der Titel etwas reißerisch. Würde ich mein Netzteil nahe an der Leistungsgrenze betreiben, wäre ich jetzt aber wohl ziemlich sickig. Zum
Glück dimensioniere ich meine Netzteile so, dass der Lüfter idealerweise NIE läuft und das dürfte dann bei der Standard wie der Noctua Edition aufs selbe rauslaufen. So bin ich nur etwas genervt und denke mir, wenn es innerhalb der 12 Jahre Garantiezeitraum aussteigt „kein Ding“, und wenn danach hat es durchaus seinen Soll erfüllt. Und wer weiß heute schon, welche Standard-Sau dann durchs Dorf getrieben wird (looking at you NVIDIA)…
EDIT & Nachtrag: Jetzt bitte auch mal die anderen Netzteile auf ihre Wärmeentwicklung an den diversen Bauteilen überprüfen - insbesondere das vielzitierte Corsair 1600er.
Tronado
4,802 Kommentare 2,682 Likes
Du hast dir direkt eins bestellt weil wo Noctua draufsteht einfach gut sein muss? :unsure:
Ist aber auch gemein, erst tiptop im Test, Wochen später dann zu hohe Temperaturen wegen unzureichendem Lüfter.
Blöd gelaufen. Aristeides, schick ihm doch wenigstens einen braun lackierten Originallüfter zu. :)
FfFCMAD
875 Kommentare 316 Likes
Diese "ganz aus" Thematik bei den Netzteillüftern halte ich auch nicht gerade für ne gute Sache. Selbst wenn der Lüfter nur sehr langsam dreht und dabei unhörbar ist, wird die Kühlung drastisch besser sein als wenn der Lüfter anhält. Zumindest wäre mir das am liebsten. Wichtig ist halt, das der Lüfter wirklich unhörbar ist in dem Moment. Das traue ich Noctua am ehesten zu solange es die PWM-Modelle sind.
R
RazielNoir
572 Kommentare 270 Likes
Ich frag mich nur, ob das wirklich sein muss. Ein Netzteil, das vom Ansatz her für High-End gedacht ist. Eine 4090 mit einem 14900k oder Ryzen 9 7950X3D unter Wasser, vielleicht noch OC. Wie laut ist das Originale NT wirklich bei Volllast eines solchen Systems, was nicht von den Lüftern und der Pumpe der WaKü schon an Geräusch produziert wird?
Interessanterweise sind die gemessenen Schalldruckwerte deutlich höher als der Originale Lüfter allein. Um genau zu sein sogar fast die doppelte Lautstärke (10db!! 52.8 dBA gemessen zu 41.60 dBA lt. Lüfterdaten) Was sind die restlichen Geräuschursachen? Spulenfiepen, Gehäuseresonanzen?
R
RazielNoir
Ich würde gern mal eine DELL Precision 7960 Tower Workstation mit einem XEON W9-3595X und mit 4x RTX 6000 ADA unter Volllast hören. Einfach mal als Vergleich. Das 2.200w-NT sollte da die geringste Lärmquelle sein, wenn ich das richtige sehe ist diese Workstation ausschließlich Luftgekühlt. und mehr Energiebedarf dürfte in einem klassischen Towergehäuse kaum ohne WaKü realisierbar sein.
Nur um mal die Relation zu einem Consumer-PC in Vollausstattung zu sehen, was den Geräuschpegel angeht.
M
M.Edison
18 Kommentare 10 Likes
Ich geh eigentlich davon aus, dass du dein Netzteil in Europa bei 230V betreibst.
Aris: Zu niedrig, um in beiden Netzteilen etwas zu bemängeln.
B
Besterino
@Tronado: nein, ich hab mir das bestellt, weil es von Seasonic ist und deren Lüfter in der Vergangenheit und in meiner Wahrnehmung (akkustisch wie insgesamt) der schwächste Punkt waren - wenn man das denn überhaupt so nennen kann/will. Wenn nun Seasonic diesen Punkt mit einem Noctua-Lüfter adressiert, gehe ich davon aus, dass das insgesamt gute Seasonic-übliche Gesamtpaket darunter nicht leidet.
UND ich gehe eigentlich davon aus, dass ein Tester wie Aris schlichtweg im Blick hat, worauf man Netzteile testet und was man standardmäßig misst, um einen brauchbaren Gesamteindruck zu bekommen. Also NICHT auf einmal bei der Noctua-Edition erst was weglässt (aus dem Parcour was er sonst immer macht) und dann erst nachträglich testet (warum auch immer), oder nachträglich auf einmal auf die Idee kommt, den Testparcour anzupassen nach dem Motto "och hey, das könnte ich mir auch mal ansehen...". Ersteres ist richtig Kacke, letzteres ist natürlich grundsätzlich ok - aber dann kann ich als Leser halt eigentlich alle vorherigen Tests / Empfehlungen in den Wind schießen, da ich ja gar nicht weiß, ob - in diesem Fall - die MOSFETs nicht dort auch zu heiß werden.
Mein Fazit: Kann dummerweise also auch auf Aris nicht mehr vertrauen, dass ein "joah, das passt" auch wirklich so ist. Nervig halt.
Unter'm Strich und realistisch betrachtet aber halt auch wieder ein Sturm im Wasserglas, weil das Netzteil bei mir im Zweifel nicht in die kritischen Bereiche kommen dürfte und mir notfalls 12 Jahre Garantie reichen.
Finnschi001
42 Kommentare 13 Likes
Netter Test. Noctua Branding macht halt nicht alles besser.
Ich Frage mich nur, warum der Temperaturunterschied in % angegeben wird? Und warum wird 0°C als Basis genommen? Das kann in der Realität ja gar nicht erreicht werden.
Bei einem Delta T zu Ambient würde ich % noch verstehen.
Letztendlich haben wir ja aber auch die °C Werte 👍
Dann hast Du den Artikel nicht richtig gelesen. Dieser Messaufwand ist mit immensen Kosten und Zeit verbunden. Das kann man nicht immer machen. Allerdings ist Aris misstrauisch geworden, weil Seasonic angeblich bei Nachfragen gemauert haben soll. Da hat er sich, einmal getriggert, ein Retail aus dem Handel gekauft, die ganzen Sensoren dazu erworben und noch einmal nachgemessen. Mehraufwand incl. Netzteil auch fast 1000 Euro. Dass das Retail anders agiert als sein Golden Sample ist eigentlich schon schräg genug...
Wie im Artikel steht, beide Netzteile erfüllen die Norm und die Zertifizierung, aber man hätte soswohl die Lüfterkurven und Einstellungen optimieren müssen und auch die 12V-Schiene ist beim Retail etwas zu niedrig und außerhalb dessen, was Seasonic selbst kommuniziert. Dadurch wird es nicht unbrauchbar, aber es ist als Retail dann nicht mehr das, was beworben wurde.
Antwort 5 Likes
R
RazielNoir
Was für sich genommen schon bedenklich ist. Retail und Golden Sample....
Klar, die Tester mit geprüfter Ware zu beliefern, damit man ja kein Waterloo aufgrund eines Montagsmodells bekommt, ist verständlich.
Aber in den Handel etwas anders zu geben, als den Testern, riecht schon verdächtig nach Kosteneinsparung am falschen Ende und geplanter Kundenverarsche. Daher bin ich schon froh wenn Aris (oder auch Igor) bei Verdachtsfällen auch mal so einen Nachtest mit Handelsware macht.
Das hier sieht aber nach einem schönen Fall von Gewinnmaximierung mit wenig Aufwand aus. Man nimmt ein etabliertes Produkt, "veredelt" es mit dem Namen/Produkt eines anderen und schlägt ordentlich auf.
Bei Asus hat Noctua schon geliefert, allerdings hat man sich da wohl etwas mehr Mühe mit dem Produktdesign gegeben.
B
Besterino
@Igor Wallossek: Verstehe ich alles. Aber was soll ich als dummer Endverbraucher denn machen? Habe weder Skills noch Equipment noch Zeit (noch Lust) sowas selbst zu machen - muss also auf irgendwelche Drittquellen vertrauen. Hersteller ist blöd, objektive Tests sind besser. Aber wenn am Ende doch wieder nur Fragezeichen bleiben, was dann?
Wenn ich Zeit und Lust finde könnt' ich ja einfach mal Seasonic anschreiben, was die mir als Kunde dazu sagen. Ich kann hier ein hübsches Gruppenbild mit ca. 7 Netzteilen von denen machen und mal fallen lassen, dass mich als Kunde sowas echt ankotzt und in die Hände anderer Hersteller treibt. Was würde dabei rauskommen? Nix wahrscheinlich...
Feen-Schubser
197 Kommentare 104 Likes
Spannend ist ja auch die 12V Schiene.
Aber was ich für mich mitnehme:
120mm Lüfter gegen 135mm Lüfter -> da fehlt halt der Luftstrom an gewissen Bauteilen
50,1 vs 34,7 dBA -> da liegen Welten dazwischen inkl. Frequenzband der Lüfter
HA13525H12SF-Z max. 2315 U/min vs NF-A12x25 – High-Speed 2469 U/min -> im Test aber nur 1947 vs 1894 RPM
Also bei beiden Lüftern noch Spielraum nach oben.
Temperaturen weit entfernt vom Tj(Max) im Test aber Alltag?
230V Netz auch Vorteile haben kann, wenn man die Temperaturen anschaut von Bauteilen.
Preisvergleich ist natürlich wieder total kaputt.
Laut Geizhals so grob 30€ Unterschied zwischen beiden.
Wenn man es zum UVP bekommt, irgendwie gibt es das Netzteil schlecht zu kaufen.
Aber auch sehr spannend:
Deswegen ein Danke für mich das Aris den Hinweisen nachgegangen ist.
Die Liefersituation und die Tests sprechen für sich, oder nur Zufall?
B
Besterino
Also mal zur Lautstärke der Noctua-Edition: ich hab mal den semi-passiv Modus ausgestellt (d.h. also Lüfter läuft immer) und durch meine Glastischplatte ist das Ding für mich absolut unhörbar. Nun fehlt mir leider mangels Graka (oder sonstiger künstlicher Lasten) aktuell die Möglichkeit, das gut Stück mal wirklich etwas ins Schwitzen zu bringen. Besser als meine beQuiet allemal...
Ocastiâ
141 Kommentare 63 Likes
Findet ihr nicht das ihr hier ein wenig übertreibt? So wie ich den Test hier verstehe, sind die Temperaturen in beiden Netzteilen, wenn sie nach spezifikation betrieben werden In ordung, auch wenn ein paar Bauteile bei der Noctua Edition, wenn sie an einem 115v Netz betrieben wird, etwas näher and der erlaubten Höchsttemperatur sind als bei der Standard version.
Natürlich wäre es schöner wenn Seasonic/Noctua hier bessere kühlkörper verbaut hätten, aber insbesondere für leute die 230v Netzspannung nutzen sollte das nun wirklich kein Beinbruch sein.
Ist Seasonic nicht eigentlich dafür bekannt das sie bei garantiefällen anstandslos das defekte Netzteil ersetzen?
Wie gesagt, es gibt zwei Probleme, auf die Aris hinweist: Der verbaute Lüfter hat eine andere Charakeristik, das kann man aber über die Steuerung kompensieren (wenn man denn will) und die Spannungen des Retail-Netzteils bewegen sich außerhalb der Specs von Seasonic. Das ist immer noch locker ATX-Konform, aber es widerspricht den beworbenen Eigenschaften. Nicht mehr und nicht weniger, Und es ist eine Art Machbarkeitsstudie, was man wie messen kann. Da er sich das Zeug gekauft hat, denke ich auch, dass er es in Zukunft öfters nutzen wird.
z
zass
74 Kommentare 24 Likes
Was sich von den 12V bedient ist doch sowieso noch mal geregelt. Das juckt keine Sau ob das 12,2V oder 11,8 Volt sind.
Dr. Aristeidis Bitziopoulos
Chief Test Engineer at Cybenetics LTD
Ph.D. in Wireless Sensor Networks
Bachelor in Computer Science and Electronics
Telecommunications Engineer Degree
