The fact that G.Skill regularly reports new record values for DDR5 modules is nothing new. However, the fact that they have now beaten a 128 GB kit to 8400 MT/s deserves at least an appreciative nod – not least because these are not just laboratory token timings, but a complete run with RunMemtestPro. The whole thing runs on an ASUS ROG Crosshair X870E APEX with Ryzen 9 9950X3D – i.e. AM5, not Intel. AMD can be happy: the platform is slowly becoming a serious playground for RAM overclockers.
More RAM, more clock speed, more… Voltage
128 GB – that’s four 32 GB DIMMs, i.e. a classic full expansion, which is normally the end of the fun as far as the clock rate is concerned. But 8400 MT/s? With CL44-58-58-94? That’s worth more than just a brief raise of the eyebrow. G.Skill shows that even beyond the typical 2-DIMM showcases, clock speeds are slowly but surely reaching regions that were still considered unstable six months ago – at least when more than two modules were on the board. And even if CL44 is not exactly considered the “sharpest” latency now: with 128 GB, latency plays a subordinate role anyway. Anyone working in such capacity regions is thinking more about throughput and stability – i.e. the reality check for RGB permanent lighting.
AM5 as the new OC base – a surprise? Not really.
The fact that G.Skill uses an AM5 setup of all things is remarkable – and at the same time logical. The Ryzen 9 9950X3D not only has a powerful memory controller, but also benefits from fast RAM thanks to the typical IF sweet spot. The X870E APEX used is already the flagship board for such excesses: Four layer PCB, doubled voltage phases, BIOS options that you can spend weeks with – the playground for anyone who spends 30% of their lifetime in the BIOS. Here you can see what happens when the board partner, RAM manufacturer and CPU architecture happen to run in the same direction – and you don’t get stuck at POST.
From 8000 to 8400 MT/s – through the RAM flap in 30 days
G.Skill presented a 128 GB kit with 8000 MT/s just last month. Now 8400 MT/s, with identical capacity and similar timings. The progress is not in the bare number, but in the context: 128 GB is no walk in the park for signal behavior, especially with DDR5. If you want to get to 8400, you have to dig deep into your bag of tricks: PCB layout, IC binning, voltage stabilization – everything has to be coordinated. And whether it is really stable in the end is not determined by the CPU-Z screenshot, but by tools such as RunMemtestPro. And that’s exactly what G.Skill delivers.
This extreme overclock achievement showcases G.SKILL’s continued advancement in pushing DDR5 memory to new limits. While high-frequency memory kits have traditionally been limited to lower module capacities, this latest demonstration demonstrates that enthusiasts and professionals can now harness both blazing-fast speeds and massive memory capacity in a single kit. It provides an ideal choice for AI model development, high-resolution content creation, machine learning, and other professional workloads that demand both large memory pools and rapid memory data speeds.
– G.Skill
Market movement: V-Color in the rear-view mirror, Corsair is still snoring
In addition to G.Skill, V-Color is also increasingly getting involved – and not with paper launches, but with real clock frequencies. While Corsair and its ilk are still busy making their product names unnecessarily complicated, the Taiwanese are simply delivering. It is quite possible that the focus of the RAM overclocking community will shift more towards the AM5 platform in the future – if only because there is still more room for improvement in terms of signal paths and internal topology.
Who needs it? Everyone who knows why
Of course, as always, the question arises: Who needs this? And the answer is as simple as it is ironic: nobody – and at the same time everyone who knows why. Developers, simulation junkies, AI hobbyists, content creators with 16K raw material and Blender farms in the basement – they can all benefit from such kits. Provided they have the platform and the patience to set the whole thing up properly. Plug-and-play is not intended here, even if the RGB module suggests that you can plug it in like a string of lights.
Faster, bigger, but above all controlled
With the Trident Z5 NEO RGB, G.Skill shows that DDR5 beyond the 8000 mark can also be operated stably in full expansion with 128 GB – at least under ideal conditions. Whether the whole thing will find its way into the masses is questionable, but technically it is a sign that the AM5 platform has arrived, and not just for mid-range gaming builds, but also for high-end configurations with aspirations. And that is – despite all the irony – perhaps the best news in the end.
Source: G.Skill
2 Antworten
