Cooling Reviews Watercooling
Endorfy Navis F360 CPU AiO Cooler Review – Retest of the big brother
Towards the end of last year, we first had the 280mm variant of this AiO water cooler in review, and now the manufacturer asked me to also include the version with a 360mm radiator in the rankings. Recently, a decent overall package of cooling performance, workmanship and warranty length was put together, but now the CPU temperature is to be improved a bit. Read the following article to find out whether this works.
Since nothing has changed on this AiO except the radiator area, I won’t go into every little thing again. Just read the article about the 280mm version:
Endorfy Navis F280 CPU AiO Kompaktwasserkühlung im Test – Neuer Name, aber auch weiter gute Leistung?
The new design and international brand name of SilentiumPC, now Endorfy, can be found prominently placed all over the gray and black cardboard. Here, too, the front shows the included product in schematic form, while the back provides information about the specifications in tabular form.
Included are the various mounting materials for the current sockets as well as a tube of thermal paste and a small wrench.
There is also a 4-pin PWM extension cable for the fans.
Assembly and installation
Four spacers are screwed onto the existing backplate of AM4 mainboards – after removing the plastic clips. The pump block is then simply plugged onto this.
Finally, a spring together with the end screw is placed on top and tightened. The installation goes smoothly with a standing system and without a third hand. The manufacturer also states that for best performance the pump block should be installed with the connections to the LEFT.
Specifications
Before we go straight to the results, here is an overview of the technical details. More detailed information about this cooler can be found on the product page from the manufacturer.
FritzHunter01
1,319 Kommentare 1,803 Likes
Eine 360er um die 100 € ist ok. Für meinen Geschmack zu wenig Beleuchtung, aber was weiß ich schon…
A
Ada
10 Kommentare 2 Likes
Sieht nach einem fairen Angebot aus. Zwei Fragen dazu..
1) Wie lange sind die Schläuche von dem Ding?
2) Ist es ein Problem wenn die Schläuche (naja nicht gespannt, aber sagen wir) in voller Länge gestreckt werden beim Einbau?
F
Furda
653 Kommentare 371 Likes
Die Schläuche sind so extrem kurz, dass selbst im Test, entgegen der Anleitung diese seien besser links, dennoch rechts verbaut wurden? Dann noch wie immer die Radiator-Anschlüsse oben anstatt unten? Wieso?
Diese AIO ist, meiner Meinung nach, richtig betrieben also nur im Deckel möglich.
v
vonXanten
831 Kommentare 364 Likes
Jaja mit mehr RGB kühlt die dann mindestens 5K weiter runter ;)
Finde es gut mal ein schlichteres Modell zu sehen ohne viel Bling Bling. Aber die Auswahl ist so riesig da findet jeder etwas....
Lagavulin
289 Kommentare 254 Likes
Selbst wenn der Hersteller die Schläuche so lang machen würde, dass man die 360mm AIO mit Anschlüssen unten in der Front eines Fullsize-Tower einbauen kann, kommt das böse Erwachen beim Einbau der Grafikkarte: Passt nicht. Eine AIO bei der das möglich wäre, ist bspw. die Alphacool Eisbär – aber auch nur dann, wenn die Schauchlänge reicht und wenn man sie öffnet und unten am Radiator Winkelanschlüsse verbaut. Oder man kauft sich die Komponenten der Eisbär und baut sie selbst zusammen mit Winkelanschlüssen. Aber auch in diesem Fall muss man messen, ob zwischen Grafikkarte und Radiator überhaupt genug Platz ist, um die Schläuche nach oben zu führen.
F
Furda
Ja es gibt einiges zu beachten, wenn man eine AIO sauber einbauen möchte. Viele greifen dann zu Notlösungen und nicht-passend wird irgendwie passend gemacht - anstatt das Richtige zu kaufen.
Leider nutzen Tester auch Notlösungen und Unerfahrene kopieren diese unwissend. Ohne Kritik kommen die Hersteller damit immer weiter durch, anstatt mal ihre Produkte so zu gestalten, dass sie gut modular einzubauen sind.
Tim Kutzner
939 Kommentare 776 Likes
1) 42cm von Ende zu Ende, zieh da nochmal etwas für die Anschlüsse selbst ab
2) Nein, wieso sollte es? "Strecken" im Sinne von länger ziehen kannst du die in der Regel sowieso nicht
Tim Kutzner
Ob die Schläuche beim Einbau in der Front nun oben oder unten sind macht meiner Erfahrung nach keinen Unterschied, solange die Pumpe tiefer sitzt. Mögliche Luftblasen bleiben trotzdem im Radiator und kommen nicht in die Pumpe.
Von "Notlösung" weit entfernt.
Alexander Brose
843 Kommentare 609 Likes
Gefällt mir optisch ziemlich gut (black is beautiful) und der Lüfter vom Fera 5 (dürfte derselbe oder sehr ähnlich sein?) hatte mir letztens auch echt gut gefallen. Angenehm leise, keine Lagergeräusche oder Schleifen... mag ich.
Grüße!
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
