Audio Audio/Peripherals Editor's Desk Reviews
Edifier Airpulse A200 Active Speakers Review – Great Feast for the Ears at a proud Price
Edifier can certainly do a lot, from cheap to expensive, but the Airpulse A200 are so special that I just did not want to deprive myself (and thus you) a test. These active speakers are anything but riot or party speakers, but still have enough low end and level to be able to do that if need be. Only they don’t want to, because there is also a life outside of Aunt Helga’s party cellar with the obligatory dance music. It’s a music-trash-free zone here now, and that’s a good thing.
The price is set quite high with 830 to 850 Euros as an entry and street price, which also drove my eavesdroppers into the high air of the measuring rod mountain. Because exactly such a price also demands a particularly conscientious evaluation, where you not only listen closely, but also completely disassemble the test subjects once. That is simply part of a review, because you also want to get to know the inner values. Anyone can polish, the rest then always disappears into the depths of the Asian insulation wool. No chance, the tool is already waiting!
But before the covers finally come off, you first have to unpack the actual package, of course. And that’s exactly where I’ll start, because before the pleasure there is, as always, a lot of work. Whereby: the attentive reader will have noticed or still notice that the boxes are not brand new, because my smaller traces of use can be seen on the high-resolution photos then already. But I’m just going to pretend that the DHL guy has just given me a brand new box and I’m going to unpack everything with great anticipation.
Scope of delivery and accessories
And what do you get (or did you get) now as a paying customer? Besides the active box (right) and the passive box (left), there are also extra accessories in the extra box. Inside we find an RCA-to-RCA cable (RCA) with a length of 1.5 meters including a plug adapter from RCA to 3.5 mm jack, an optical TOSLINK cable (SPDIF) of the same length, the connection cable to the left speaker with a full 5 meters and two proprietary plugs, as well as a power cord for the mains connection. Although the speakers also have a balanced input, this special cable is not included, which is a pity.
Look, feel and functionality
The pair weighs a whopping 19 kilos together and that’s exactly what I meant by work too. With 203 x 355 x 295 mm (width x height x depth), the speakers are rather medium-sized for shelf speakers, so you can locate the weight mainly in the body. I’ll show it later in the teardown, but I can already spoil that Edifier uses high-density MDF with 25 mm thickness here. In addition, there is a cleanly laminated cherry veneer (real wood) and the front set off with matte black sanding varnish. I also hoisted the active box into the photo studio and had it pose for you at what felt like 30 degrees in the shade in 45-degree increments:
Visually, the whole thing makes a solid, rather classic impression. Experiments? Just don’t. When you run your fingers over the surfaces, corners and edges, you are almost captivated by the high-quality workmanship. No heels at all, neat transitions and gap dimensions like an absolute top class car. The look and feel are without a doubt in exactly the same league as the price. This fits in any case. The front is characterized by a 5.5-inch mid-woofer with quite a long stroke as well as a special metal cone made of aluminum and a very short voice coil design. In addition, there is the really good ribbon tweeter, i.e. a kind of flat diaphragm speaker with aluminum strips. I’ll go into more detail about the two chassis later in the teardown, including how they work.
The available output power per speaker is about 65 watts RMS, with 55 watts split between the mid-woofer and about 10 watts between the ribbon tweeter. Per channel, of course. A total of around 130 watts RMS is available, and the switching power supply is quite efficient. Peaks of up to about 150 watts do pass through the power cord at full volume, but in normal use it’s usually less than 20 watts at moderate volume. In standby, you stay under 0.5 watts.
Connectivity
The inputs are self-explanatory, although a balanced input is not a given. But there is, beautiful. Besides the two usual RCA jacks (RCA), we find an optical input (SPDIF) and the digital coax. However, there are no other outputs besides the connection for the left speaker and thus none for an optional subwoofer. It can be assumed that you simply don’t want any alienation in terms of sound, only I feel that this is almost paternalism. Technically speaking, the inner workings would easily do the job.
The three knobs do not give up any mystery. The volume control (digital) is coupled with a push button for input selection (source). The two tone controls for bass and treble have a very small control range of +/- 3 dB, but this is due to the deliberately neutral alignment. You can find that good, or not. But it is also something like a state-imposed hearing control, so that no mistakes are made. You can read the reasons at the end of this page.
The power socket with ground potential (protective earth) connects the boxes to the normal ground circuit, which with a little bad luck can also lead to the so-called ground hum, depending on the player and its supply. Speaking of connecting cables: the included 5-meter cable has sufficient conductor cross-sections inside for a largely loss-free connection. Since the power amplifiers work separately and there are no passive speaker crossovers in the boxes, both signals have to be brought to the left box. This then leads into a multi-pin connector (2x signal and 2x ground or shield). Those who feel reminded of diode plugs here are not that wrong. However, these plugs could have been angled by 90° to better lead the rather stiff cable downwards. Thus, however, it spikes quite visibly far to the rear. The boxes stand on neat and soft rubber feet and that would almost bring us back to the end of the superficialities.
Of course, I also want to say a word about the recurring “designed by Phil Jones”. Phil Jones (or Phil Jones Bass PJB as a company) has certainly set milestones in audio history. The year 1998, for example, marked the design and manufacture of the first Air Pulse loudspeaker system, which sold for a tidy $275,000 per pair and was awarded the Golden Sound Award by the Japan Audio Society as the best loudspeaker designed in the 100-year history of loudspeakers. Despite the similar spelling, the “Airpulse” is miles away from that, but it is also clear why certain restrictions against the user’s excessive playfulness are in place. If you can’t do it, you can’t do it. Item.
A200 Sell Sheet
D
Deridex
2,204 Kommentare 843 Likes
Die Verbindung zwischen den Lautsprechern sehen mir nach handelsüblichen 5pol Diodensteckern aus. Ich glaube man findet da was passendes wenn man etwas sucht.
10,107 Kommentare 18,597 Likes
Jain. Die Masse zeigt nach Links, so dass herkömmliche Winkelstecker dann nicht nach unten, sondern zur Seite weggehen. Man hätte auch die Buchse noch um 90 Grad drehen müssen :)
Ich finde die Nubert-Stecker der SP-200 schöner und auch sicherer.
D
Deridex
Das hatte ich nicht bedacht. Ich dachte mir bloß: "Die Dinger kenne ich doch...".
Das dachte ich mir auch erst (steht auch so im Text) ;)
Ich würde da allerdings nicht mein Spulentonbandgerät reinstecken wollen :D
D
Deridex
Ich habe nur bis zu "proprietären Steckern" gelesen. Habe mir gedacht: "Glaub ich nicht." und nachgesehen, was das sein könnte.
Den Rest lese ich mir aus Zeitgründen später durch.
ssj3rd
213 Kommentare 142 Likes
Finde es immer noch sehr schade, dass die 5.1/7.1 Zeiten bei PC Boxen vorbei sind.
Edifier war damals da echt gut dabei und deren 5.1 Encore Set macht bei mir immer noch einen sehr tollen Job, vor allem das rundherum Gefühl will ich einfach nicht mehr missen wenn Stimmen/Geräusche etc von links und rechts kommen.
(Stereo ist zwar sehr cool für Musik, aber für Spiele bevorzuge ich weiterhin 5.1 und das sehr vehement!).
Was ich auch immer traurig finde:
Bei Spiele Tests wird heutzutage gar nicht mehr auf den Sound eingegangen, selbst wenn ein Game sogar mal Dolby Atmos unterstützt wird dies nicht erwähnt und man muss sich durchs Internet quälen ob dies tatsächlich nun der Fall ist.
(Die offizielle Dolby Gaming Seite ist ein Witz und da fehlen etliche Titel…). Letztens erst Resident Evil 2 Mit Dolby Atmos mit der Wohnzimmer Anlage gezockt: ein Traum!
Nemesis von den Hights Boxen zu orten war schon ein Knüller und verstärkte das mittendrin Gefühl enorm, um mal ein schönes Highlight zu benennen.
Gaming und Sound scheint aber absolut niemanden mehr zu interessieren 😫
O
Ozzy
225 Kommentare 137 Likes
Schöne Boxen, schöner Beweis dafür, das man in China auch Qualität bauen kann.
Spannend auch die Innereien zu sehen, oft bleibt sowas ja verborgen.
Warum nach Europa oft nur mindere Qualität importiert wird von den hiesigen Firmen, erschliesst sich mir einfach nicht.
ipat66
1,343 Kommentare 1,335 Likes
Natürlich kann China auch Premium.....
Wenn die Menschen dann aber mit ihrer „Geiz ist geil-Mentalität“ bestellen,hilft das auch nicht weiter.
Wer sich externe Netzteile für 1,85 Euro (am besten Versandt inklusive) ins Haus holt ,
braucht sich dann auch nicht wundern,wenn die Hütte brennt !
Alexander Brose
815 Kommentare 565 Likes
Schöne Dinger und klasse Test!
Seit mein altes und klappriges Taiphoon 2.1 System durch ein paar ordentliche Nuberts ersetzt wurde, hab ich plötzlich wieder viel mehr Spaß an Musik und auch viel mehr Interesse an Hi-Fi Reviews.
Grüße!
Der Anspruch steigt beim bewussten Hören. Mittlerweile bin ich auch von Spotify auf Tidal gewechselt, trotz der eher beschissenen Playlists. Man hört den Unterschied einfach.
djrobinson
37 Kommentare 14 Likes
Die programmierer von Audirvana haben nicht ohne grund Tidal und Qobuz implementiert. 🎧
g
goch
466 Kommentare 178 Likes
Na die würde ich mir ja sehr gerne anschauen. Ich mag Bändchenhochtöner eigentlich sehr gerne und habe diese in den hannoverschen Vulkanen und Titanen lieben gelernt. Allerdings weiß ich auch um die extreme Schwierigkeit und Umstände die man Anstellen muss, dass diese sich harmoisch in den Rest einfügen und nicht zischen / metallig / auf Dauer anstregend anhören. Das Stelle ich mir in dem Preisbereich fast unmöglich vor - daher bin ich umso gespannter!
Die sind sehr weich im Auftritt, alles andere als metallisch :)
Megaone
1,703 Kommentare 1,600 Likes
Guter Test. Ich finde es sehr gut, das hier auch mal etwas höherwertige Systeme getestet werden. Während es bei Kopfhörern zuweilen ja schon mal überraschungen gibt, ordnen sich die Billig-Brüllwürfel in der Regel zwischen schlecht, schlechter und geht gar nicht ein.
Bemerkenswert auch das gute Abschneiden im Vergleich zu den Nubert.
Airpulse bzw. Edifier sind in Asien richtig feste Größen. Dass die in DE kaum einer kennt, liegt einfach nur am fehlenden Werbewillen von Edifier in Europa :D
Ich hatte vor zwei Jahren mal eine damals 10 Jahre alte Bilderstory von mir refurbisht, da sieht man auch Lackiererei und Tischlerei:
Auf dem Gelände läuft man sich echt einen Wolf und die Pyramiden-Chamber ist der Wahnsinn...
Ghoster52
1,365 Kommentare 1,029 Likes
Sehr schöner Test & Boxen. 🥰
Wenn da nicht schon über 20 Boxen 🤪 verteilt auf 2 Zimmer wären, könnte man durchaus mal wieder schwach werden.
Dark-Silent
20 Kommentare 4 Likes
Ob das ein Game für dich sein könnte kann ich natürlich nicht sagen. Falls du aber eins mit wirklich sehr guter Dolby Atmos implementierung spielen möchtest und es etwas sein sollte das für dich in Frage kommt dann sei dir die Reboot Triologie von Tomb Raider ans Herz gelegt.
MfG
Dark-Silent
Wie nicht wundern 😕??? Du gibst dafür soviel Geld aus? Lakotz die Welt an🤮 Geld spielt keine Rolex und eure Armut kotzt mich an 🤣
Scheinbar ist wer billigst kauft kauft meist auch mehr als 2x oder macht auch schon mal Wohnungseinrichtungs Barbecue noch immer nicht zu jedem Geiz ist da oft auch beim zuhören Geil Menschen durchgedrungen.
MfG
Follow Igor:
