Allgemein Fans Latest news
DeepCool introduces the FL12 series of case fans | Press release
On February 25, 2025, DeepCool launches the new FL12 series of 120 mm case fans. These fans combine high cooling performance with bright RGB lighting. The FL12 (WH) and FL12R (WH) models are equipped with 36 ARGB Gen2 LEDs that surround the frame and create a uniform illumination. A 3-phase, 4-pole, 6-slot motor ensures stable and efficient performance.
Cascadable fans with reduced cable requirements
A key feature of the FL12 series is the 8-pin cable design, which enables easy daisy-chaining of multiple fans. This system simplifies cabling, reduces cable clutter and makes installation easier, resulting in a cleaner and tidier PC case appearance.
Lighting on both sides thanks to inverted fan blades
The FL12R models are equipped with inverted fan blades. This design ensures that the RGB lighting is visible on both the intake and exhaust sides. This eliminates the usual “cross” structure on the rear, which enables uniform lighting regardless of the installation direction.
Technical features and materials
The fans in the FL12 series use Fluid Dynamic Bearings, which are designed for a long service life and quiet operation. Polybutylene terephthalate (PBT) is used for the frames, while the fan blades are made of polycarbonate. These materials help to reduce noise and increase resistance to mechanical wear.
Performance and specifications
The FL12 and FL12 WH models reach a speed of 500 to 2150 rpm ±10% and generate an airflow of 55 CFM with a maximum noise level of 32 dB(A) and an air pressure of 2.82 mmAq.
The FL12R and FL12R WH models offer an air pressure of 2.59 mmAq and a maximum noise level of 33.9 dB(A) at the same speed and airflow. All fans are equipped with a 4-pin PWM connector for precise fan speed control.
Availability and prices
The FL12 series fans are available in black and white and are offered both individually and in packs of three. The FL12 and FL12 WH models will be available from February 25, 2025, while the FL12R and FL12R WH models will go on sale from March 25, 2025.
The recommended retail price for the FL12 and FL12 WH single fans is 21.99 euros. The three-pack of these models, designated FL12 (3in1) and FL12 WH (3in1), will be available for 62.99 euros. The FL12R and FL12R WH fans cost 29.99 euros individually, while the corresponding three-pack FL12R (3in1) and FL12R WH (3in1) is available at a price of 79.99 euros. DeepCool provides a three-year warranty for all fans in the FL12 series.
About DeepCool
DeepCool is a company that specializes in PC cooling solutions such as CPU coolers, case fans and water cooling systems. It relies on innovative technologies such as liquid cooling, heat pipe designs and Fluid Dynamic Bearings to ensure efficient and quiet cooling. DeepCool is known for high performance products and a worldwide distribution network.
