Audio Audio/Peripherals Bluetooth Headphones Headsets Reviews
Corsair Virtuoso Max Wireless gaming headset in test. Wireless, no frills, but unfortunately not weightless either
The Corsair Virtuoso Max tested today is a wireless gaming headset equipped with active noise cancellation (ANC) and Dolby Atmos. It offers simultaneous use of 2.4 GHz radio and Bluetooth, which enables flexible connection to different devices. The battery life is up to 60 hours, with a quick-charge function providing six hours of playtime after just 15 minutes of charging. The headset has 50 mm graphene drivers, which should deliver clear and precise sound. The workmanship is high quality, but… nevertheless, you should read the article carefully if you want to spend so much money, because as always, the devil is in the detail. Especially in the ear pads and the sounding, so this time I measured with and without EQ and also have to give a few practical tips on how to put them on correctly. But first things first…
Like the Virtuoso Wireless we have already tested, the Virtuoso Max is once again made by Horn from Hải Phòng. This is an OEM manufacturer (Original Equipment Manufacturer) that specializes in the production of high-quality electronic products and audio accessories. The company is known for producing a wide range of headsets and audio solutions for renowned brands worldwide. Horn is well known in the industry for its flexibility and innovation, offering customized solutions for both gaming headsets and professional audio applications.
You get what you pay for and unfortunately the Corsair Virtuoso Max Wireless gaming headset is not really cheap. With a current street price of around 325 euros, the bar is already extremely high and the air is getting pretty thin overall if you apply the yardstick of this price class. However, many other headsets in this performance class are no cheaper. The headset is positioned in the premium segment and comparable wireless gaming headsets from other manufacturers are unfortunately in similar price ranges.
The SteelSeries Arctis Nova Pro Wireless (test) offers decent audio quality and is priced at around €299. The Audeze Maxwell, with excellent sound, costs around 319 euros. And the Sony INZONE H9, equipped with active noise suppression, is available for around 299 euros, but doesn’t quite sound like mine. These prices can vary depending on the retailer and current offers, but there is usually always a three at the top of the price. Today we will find out whether the headset still offers acceptable value for money.
Scope of delivery and unboxing
Unboxing the Corsair Virtuoso Max is an experience in itself and leaves a solid first impression. The packaging is attractively designed and offers a touch of luxury that underlines the high quality of the product. Ok, you can expect that in the 300 euro class. After opening the box, the headset is carefully and securely presented in a hard-shell transport box with a foam holder that protects it from damage. The way the components are arranged gives the impression that the OEM has carefully planned every detail to provide the future user with a high-quality unboxing experience. As we all know, the eye is always involved and somehow you have to justify the purchase price to yourself.
As soon as the headset is removed, you can see the other accessories, which are stored in a separate compartment. Each part is securely fastened, preventing anything from moving during transportation. The USB cable is neatly folded and looks just as high-quality as the headset itself, which leaves a positive overall impression.
The scope of delivery of the Corsair Virtuoso Max Wireless gaming headset is well thought out and offers everything you need for immediate use. In addition to the headset itself, a detachable microphone, a USB-C charging cable, a 3.5 mm audio cable, a USB wireless dongle and an elegant storage bag are included. The included cables are robust and offer sufficient length for flexible use. The microphone can be seamlessly attached to the headset and ensures improved communication. Overall, the scope of delivery is high-quality and practical, allowing users to get started straight away without the need for additional accessories.
Technical data
The headset’s drivers are 50 mm graphene-coated neodymium speakers designed to provide precise audio reproduction and cover a wide frequency range from 20 Hz to 40 kHz. These drivers are designed for high fidelity and are said to capture even the finest details in audio, which is beneficial for both gaming and music playback. So says Corsair. Let’s take another look later. The headset supports a wireless connection via 2.4 GHz wireless technology with a range of up to 18 meters and also offers Bluetooth connectivity, which enables simultaneous connection with multiple devices. This makes the Virtuoso Max particularly flexible and versatile.
A wired connection is also possible, which makes it easier to use the headset on different platforms. The battery life is up to 60 hours, with an integrated quick-charge function that provides up to six hours of use after just 15 minutes of charging. Another technical highlight is the omnidirectional microphone, which is detachable and promises high voice quality. With a sampling rate of 24 bit/96 kHz, the microphone delivers a precise and clear voice recording that is particularly suitable for online communication and streaming. The headset also features active noise cancellation (ANC), which effectively minimizes ambient noise for an undisturbed audio experience. An integrated Dolby Atmos sound profile ensures immersive spatial audio reproduction, which is particularly beneficial when gaming.
Technical specifications
Type of construction Headphones (over-ear)
Design Headband
Principle closed
Microphone Microphone boom (detachable, left)
Connection USB-C
Wireless Bluetooth, AAC, wireless digital
Cable one-sided, detachable
Operating time 60 h (without RGB)
Rechargeable battery Quick charge function (15min for 6h operating time)
Frequency range 20Hz-40kHz (loudspeaker), 100Hz-10kHz (microphone)
Driver 50mm
Device features active noise cancellation (ANC), ambient mode, RGB lighting (Corsair iCue)
Software features Virtual Surround (Dolby Atmos for Headphones, Spatial Audio)
Color silver
Weight 417 g
s
scotch
171 Kommentare 121 Likes
Ich hab einige Kabellose Headsets durch und bin am ende immer wieder bei der Kabelversion gelandet (zZ. MMX 330pro)
Die Kabellosen (Audeze Maxwell/Steelseries Nova Pro) hatten nur einen einzigen Vorteil: Sie waren Kabellos. Hat bis jetzt nicht gereicht.
11,315 Kommentare 21,484 Likes
Ich bin auch eher der Kabelfreak und mit dem Meze aktuell am Stalker Zocken. Die Immersion bei guten Kopfhören ist noch einmal deutlich höher als mit all dem Dolby-Geraffel.
S
SpotNic
1,203 Kommentare 538 Likes
Vielleicht hab ichs überlesen bein überfliegen aber kann das Ding über die Funk Schnittstelle Stereo und Mic Verbindung? Die Klassischen BT Funk Headsets wechseln im Sprachmodus ja dann den Kanal... Warum man das bis heute nicht hinbekommt verstehe ich immer noch nicht.
echolot
1,256 Kommentare 986 Likes
Das Gewicht spricht in der Tat nicht für einen angenehmen Tragekomfort, zumindest nicht für längere Sessions. 417g vs z.B 260g von den Meze Audio 99, die hier vor kurzem getestet wurden. 1 1/2 Tafeln Schokolade mehr fallen dann schon ins Gewicht :D.
Du hast sogar beides. Zocken und Labern und dazu BT auch mal einen Anruf annehmen. Ist zwar sinnlos, aber nun ja. Musst nur beides connecten, BT und den Dongle.
2,038 Kommentare 1,292 Likes
Interessanter KH, und scheinbar trotz "Corsair Tax" mit nicht ganz unrealistischen (aber hohen) Preis. Daß sich verschiedene EQ Profile nicht direkt im KH abspeichern lassen ist schade, denn das wäre ein echter Mehrwert gewesen. Allerdings war ich schon bei dem Satz von Dir (@Igor Wallossek ) bereits sehr skeptisch "Bei größeren Köpfen wird das schnell zur Falle..". Ich bin nunmal ein anatomischer Dickkopf, zB mußte ich zu meiner Motorrad Zeit immer nach größeren Helmen suchen. Wenn mir so ein KH auf den Kopf und die Ohren drückt, macht das schnell keinen Spaß mehr. Auch wenn er mit EQ einstellen gut klingen kann.
Ghoster52
1,576 Kommentare 1,268 Likes
Ich habe mich gestern vom Gegenteil überzeugen lassen.
Hifiman xyz mit 430g Kampfgewicht = drückt mit der Zeit auf der Rübe
KH aus CN mit 520g = kann ich über Stunden tragen und wirkt auf der Rübe sogar leichter,
weil Anpressdruck fehlt... Hier mal ein Schnappschuss. 🥰
@Igor
Danke für den Test, leider ist der KH nichts für mich, ich schwimme aktuell wieder auf der "Planar-Welle". 🤪
2 dynamische KH weggegeben und 3 Planare gekauft, ist ne schlechte Quote wenn man eigentlich "abrüsten" will.
NBSH
19 Kommentare 13 Likes
Ich hab nur generell was zu Corsair anzumerken, weil es evtl. dem ein oder anderen auch passieren wird:
Habe das Corsair HS80 Max seit einigen Monaten, es ist für mich halt sehr zufriedenstellend.
1. iCue ist mit die schlechteste Software die ich je gesehen habe. Habe den Fehler gemacht diese nach dem Konfigurieren der Kopfhörer zu deinstallieren. Nach einigen Wochen hat das Headset seinen Dongle nicht mehr erkannt, also Software wieder drauf und neu verbinden. Lasst iCue ruhig auf dem System, löscht es aus dem Autostart, setzt die Dieste auf Manuell bis auf den "Corsair Gaming Audio Configuration Service". Seitdem keinen einzigen Verbindungsabbruch mehr.
2. Firmwareupdates über das lange Ladekabel sind kaum möglich. Habe aus Taiwan ein neues Kabel bekommen auf Garantie, selbes Spiel. Lieber ein vernünftiges kurzes Kabel benutzen, dann klappts beim ersten mal.
3. iCue Updates: Anstelle dies über die Software selber machen zu lassen, ladet euch die neue Version lieber bei Corsair runter, es kam desöfteren vor das irgendwas am Update wieder hing etc. Evtl. Dienste wie unter 1. wieder einstellen danach.
4. Die LED am Mikrofon ist nervig. Passenderweise wird das USB Kabel mit einem Gummiringgeliefert der perfekt über die Rundum-LED am Mikrofon passt, somit hat man diese perfekt abgedeckt. Ob das so sein sollte oder nicht? Ich bin jedenfalls dankbar, dass ich dies entdeckt habe.
Y
Yumiko
783 Kommentare 364 Likes
Habe hier zwei von den Corsair mit Dongeln im Einsatz.
Leider stören sich die USB-Dongels:
Alle paar Minuten oder mal eine Stunde (völlig unregelmäßig) connecten die komplett neu, was gleichzeitig bei beiden Headsets mit dem üblichen bibidibu Quittiert wird, samt Reset der Lautstäre etc.
Das kommt nicht vor wenn man nur ein Headset betreibt.
Damit ist das betreiben von zwei Corsair Headsets in der Wohnung völlig unbrauchbar. Leider findet sich in den "Tests" dazu nie etwas.
Hat da jemand eine Lösung?
Jicrasu
1 Kommentare 0 Likes
Ich bin auch aktuell im Markt für kabellose Kopfhörer am PC
(manchmal muss man schnell aufstehen wenn die Katzen Mist machen, und da ist mir schon das ein oder andere Mal das Kabel der DT880 im Weg gewesen und ich dran hängen geblieben 😅)
Da ich bisher von beyerdynamic sehr angetan war wollte ich mich dort weiter umschauen. Gibt oder gab da ja lange Zeit die Amiron Kopfhörer als Wireless und seit kurzem anscheinend die Aventho 300.
Hat da jemand von euch vielleicht schon Erfahrungen mit gesammelt?
Am wichtigsten sind mir Tragekomfort und Gewicht
@Igor Wallossek : Wie gut (schlecht) ist die ANC Funktion für das rausgehende Audio (über das Boom Mikrofon), v.a. auch ohne Nvidia? Ich habe im Moment keine Nvidia dGPU in meinem Arbeits PC, daher die Frage.
Und, als Kommentar: bei Telefonaten oder in Zoom oder Teams ist es mir eigentlich wichtiger, daß die anderen Teilnehmer mich gut verstehen können, und trotzdem zB mein Tippen auf meinem Unicomp Keyboard nicht hören. Zum Musikhören nehme ich lieber meinen KH mit Strippe und ohne ANC.
P
PillePalle83
3 Kommentare 0 Likes
Ich jabe auch schon so einige Hochpreisige kabellose Kopfhörer durch und lande immer wieder bei kabelgebundenen. Da ich schon immer von Beyerdynamik angetan war nutze ich schon seit einiger Zeit und wahrscheinlich auch noch ganz lange ein DT 900 Pro X. Das war auch nicht gerade günstig aber ich bin immer wieder angetan wenn man damit hört, egal ob Musik oder Gaming.
Y
Yumiko
Ich war eigentlich vom Virtuoso Wireless SE (bzw. dem baugleichem XT mit Atmos-Zertifizierung und BT - oft deutlich unter 200) akustisch sehr begeistert (https://www.igorslab.de/gaming-head...est-nicht-ganz-preiswert-aber-den-preis-wert/).
Follow Igor:
