Editor's Desk PSU Reviews
Corsair RM850x ATX v3.1 power supply (2024) review – Is the latest iteration of the long-running model still an option?
The popular Corsair RMx series has received an upgrade that brings it up to the ATX v3.1 standard. This means that all new RMx units now have 12V 2×6 connectors and can deliver up to 200% of their maximum power. Reason enough for me to once again let my friend Aris from Hardwarebusters have his say (and picture) about this on our site, as he has not only intensively tested this power supply, which costs around 160 euros, but has also officially certified it through his company Cybenetics. As this will certainly be of interest to you, I am happy to offer him the platform to share his findings with you on a case-by-case basis. And don’t forget, his website and YouTube channel also offer real gems in terms of really well-founded reviews! The power supply is also featured in his article on the best ATX v3.x & PCIe 5.x power supplies.
The Corsair RMx series has been updated to meet the requirements of the ATX v3.1 standard, which requires, among other things, that a power supply can withstand up to 200% of its maximum power for short periods of time. Another special feature of the new models is the fan speed controller, which can be used to adjust the fan speed at low loads, from zero rpm to maximum speed. For example, if a fan speed of 500-600 rpm is selected at low load, this serves as a starting point and increases as the thermal load on the power supply increases. Instead of providing a switch to select or deselect the fan’s semi-passive mode, Corsair has created the ability to determine the fan’s starting speed. In today’s review, the second most powerful model of the RMx ATX v3.1 series with a maximum power of 850W is tested. The 1000W model has already been evaluated.
Call up Cybenetics test report
Manufacturer (OEM): Channel Well Technology (CWT)
Max Power: 850W
Cybenetics Efficiency: [115V] Cybenetics Gold (87-89%), [230V] Cybenetics Gold (89-91%)
80 Plus Efficiency: n.a.
Noise: Cybenetics A (20-25 dB[A])
Compliance: ATX v3.1, EPS 2.92
Alternative Low Power Mode support: Yes
Operating Temperature: (Continuous Full Load): 0 – 50 °C
Power 12V (Combined): 850 W on one single rail
Power 5V 3.3v: 150 W
Power 5VSB: 15 W
Cooling: 140mm Fluid Dynamic Bearing Fan (NR140HP)
Semi-Passive Operation: ✓ (Adjustable Fan Speed)
Modular Design: Yes (Fully)
High Power Connectors: 2x EPS (2x cables), 3x PCIe 6 2 pin (3x cables), 1x PCIe 12 2 pin (600W)
Peripheral Connectors: 8x SATA (2x cables), 3x 4-pin Molex (1x cable)
Cable Length: ATX Cable Length: 610 mm
EPS Cable Length: 750 mm
6 2 pin PCIe Cable Length: 650 mm
12 2 pin PCIe Cable Length: 650 mm
Distance between SATA/Molex connectors: 115/100 mm
In-cable capacitors: No
Dimensions (W x H x D): 150 mm x 85 mm x 160 mm
Weight: 1.79 kg (3.95 lb)
Warranty: 10 years
Power Specifications
Rail 3.3V 5V 12V 5VSB
Max. Power Amps 20 20 70.8 3
Watts 150 849.6 15
Total Max. Power (W) 850
Corsair RMx Series 2024 RM850x 850W ATX 3.1 (CP-9020270-EU)
MindfactoryBestellt, wird am nächsten Werktag erwartetStand: 11.12.24 01:28129,89 €*Stand: 11.12.24 01:29
notebooksbilliger.deBerlin, Dortmund, Düsseldorf: lagernd (keine Online-Reservierung möglich)Onlineshop: ca. 2-4 WerktageHamburg, Hannover/Laatzen, München, Stuttgart: nicht lagerndStand: 11.12.24 01:15129,90 €*Stand: 11.12.24 01:16
AlternateAuf Lager131,90 €*Stand: 11.12.24 01:26
*Alle Preise inkl. gesetzl. MwSt zzgl. Versandkosten und ggf. Nachnahmegebühren, wenn nicht anders beschriebenmit freundlicher Unterstützung von geizhals.de
116 Antworten
RedF
5,266 Kommentare 3,047 Likes
Zur Frage welches das beste Netzteil fürs GraKa OC wäre sind das dann die relevanten Werte?
oder besser unter last?
Die Unterschiede sind nicht ohne, wie ich aus User berichten von Netzteil wechseln weiß.
11,314 Kommentare 21,482 Likes
Bitte Diagramm-Überschift lesen. Das erste ist ohne Caps, also rein für die Teststatistik und Klassifizierung. :D
RedF
Megaone
1,919 Kommentare 1,832 Likes
Ich verwende seit 12 Jahren nur noch Corsair Netzteile und habe noch nie schlechte Erfahrungen. Mit 10 Jahren Garantie ist die Investition gut geschützt, die Dinger laufen absolut zuverlässig jeden Tag im Schreibbüro und Privat zwischen 8-12 Stunden. Da ist es mir am Ende egal, ob ich anderswo 10 Euro sparen kann. Sicher gibt es auch vergleichbare Hersteller die ähnliches bieten. Erfahrungsgemäß tummelt sich aber auch viel Schrott auf dem Markt.
Aus Erfahrung muss ich Igor 100% zustimmen.
"Denkt daran, ein gutes Netzteil ist eine langfristige Investition!"
Und ich würde auch noch anfügen.
Kauft immer zumindest etwas mehr Leistung als wie Ihr braucht. Die ganzen Rechenkünstler in meinem Umfeld die gerne zocken sind beim 3 Netzteil oft da angekommen, wo ich gestartet bin.
Und Finger weg von dem Billligkram!.
Antwort 4 Likes
c
cunhell
585 Kommentare 557 Likes
@ Megaone: Der Artikel ist von Dr. Aristeidis Bitziopoulos ;)
Cunhell
Ich teile aber die Menung von Aris, dass Jonnyguru für Corsair gute Netzteile bauen lässt. Der hat sich da quasi einen Job auf Lebenszeit geschaffen :D
c
cunhell
Das will ich auch gar nicht abstreiten. Die Aussage ist trotzdem von Aris :p
Das stand damals schon in meinen "Wahren Netzteilanbietern von A-Z", als alle noch Netzteile als finanziell nötiges Übel angesehen haben. So gesehen war und ist der Spruch sicher allgemeingültig :D
Der läuft seit 15 Jahren im Dauer-Loop. Übrigens tauchte der Begriff "China-Böller-Netzteil" erstmals 2007 in meinem Q6600 OC-Guide auf. Den haben alle fleißig adaptiert. :D
Megaone
Ok, ich korrigiere mich selbstverständlich gern und Danke für den Hinweis. Wer richtig lesen kann ist klar im Vorteil.:cool:
Ich teile die Meinung der Redaktion von Igorslab, in diesem Fall von Aris.
Megaone
Nichts trifft es am Ende ja auch besser.
E
Eribaeri
153 Kommentare 61 Likes
Corsair HX1000 gehabt, das erste war schlecht, Spannungen haben nicht hingehauen. Zugegeben, das Ding wurde getreten - heiße Luft und ne 3080 Strix.
Das zweite HX1000 hatte ein mörderisches Spulenfiepen - ging zurück - Geld zurück.
Dann "downgegraded" auf RM1000X - gold zertifiziert. Seitdem alles prima.
Der Nerd in mir seht sich nach einem Superflower oder Seasonic - vielleicht passiert da noch was.
Am besten war das Phantex Revolt 1000 - da sind die periphären Anschlüsse einfach weggeschmolzen.
S
S.nase
1,648 Kommentare 551 Likes
Geringe Inrush Ströme sind ja optimal, wenn man seinen Rechner in den Pausen gerne komplett stromlos schaltet.
Aus welchen technischen Grund, sind ist der Inrush Current deutlich geringer als bei anderen NTs?
Feen-Schubser
125 Kommentare 51 Likes
Dankeschön für den Test.
Im Artikel steht was von der Einbauposition.
Netzteil ist unten im Gehäuse.
Semi Passiv mit Lüftungsgitter nach oben.
Aber was ist bei langsam drehenden Lüftern?
Reicht der Luftstrom aus, besonders wenn noch ein Staubfilter installiert ist vor dem Lüfter?
Oder dann mit Lüftungsgitter nach oben einbauen?
D
Daniel#
242 Kommentare 89 Likes
Es ist Aufgabe des Herstellers dass es in jeder erdenklichen Einbauposition funktioniert.
Der Ratschlag mit der Lüfterseite nach oben mag zwar thermisch sinnvoll sein, aber wenn es dem Netzteil zu heiß wird sollte es die Lüfter einschalten.
Ich würde es ja nie mit der Lüfterseite nach oben einbauen weil so leicht Schrauben oder andere Kleinteile reinfallen können, sei es beim werkeln am PC oder im Betrieb. Das Risiko wäre mir einfach zu groß, kann sich jeder vorstellen was passiert wenn Metallteile ins Netzteil fallen und Kurzschlüsse verursachen.
Deswegen halte ich von dem Ratschlag auch wenig die Lüfterseite nach oben zu richten.
RAZORLIGHT
367 Kommentare 278 Likes
Corsair konnte auch schonmal leiser...
c
cunhell
Früher war man auch schon ein Exot, wenn man keinen No-Name-Ram gekauft hat sondern einen mit wirklich nachvollziehbarem Hersteller.
Mittlerweile gang und gebe.
So ändern sich die Zeiten. :)
Cunhell
Ifalna
444 Kommentare 370 Likes
Naja... was ich mich jetzt frage:
Angenommen ich bau in 2025 eine 5090 in mein System ein, kann ich dann mein derzeitiges, gerade mal 2 Jahre altes RMX 850W Netzteil weiternutzen oder muss ich da ein neues kaufen zwecks ATX 3.1 Kompatibilität?
ArcusX
948 Kommentare 554 Likes
Ich weiss ja nicht ob die Überschrift "Dauerbrenner" für Netzteile so glücklich gewählt ist. ;)
2,037 Kommentare 1,292 Likes
Zunächst einmal Danke an @Aris und seine Cybenetics und HardwareBusters Seiten; stimme @Igor Wallossek voll zu, ein Besuch da lohnt sich immer!
Und, komplett OT Frage an @Igor Wallossek : hat AMD Deutschland Dir keine 9800 X3D zum Testen geschickt? Machen die jetzt den Blödsinn, den bis vor kurzem Intels Deutsche Niederlassung gemacht hat (keine Hofberichterstattung => dann gibt's auch keine Testexemplare)?
Oder hab ich die Ankündigung des Artikels verpasst?
Chief Test Engineer at Cybenetics LTD
Ph.D. in Wireless Sensor Networks
Bachelor in Computer Science and Electronics
Telecommunications Engineer Degree
