Latest news Monitors
Corsair launches its new Xeneon 34WQHD240-C QD-OLED gaming monitor
Corsair has unveiled its latest gaming monitor: the Xeneon 34WQHD240-C QD-OLED. This monitor could convince some customers if the price and features match. Let’s be surprised, because the big end is yet to come…
Image Source: Corsair
Let’s take a closer look at the details: The monitor is 34-inch in 21:9 format and has a resolution of 3440 x 1440 pixels WQHD with a pixel density of 110 PPI. It is a curved display with a curvature of 1800R that uses a Samsung QD OLED panel. The refresh rate is 240 Hz and the response time is said to be just 0.03 ms (GtG). The monitor in a white color design is available in a standard Vesa mount.
Corsair states that the monitor achieves a peak brightness of up to 1,000 nits and offers DCI-P3 color coverage of up to 99%. DisplayHDR True Black 400 and a contrast ratio of up to 1,500,000:1 should ensure outstanding picture quality – from the brightest highlights to the deepest shadows. The XENEON 34 QD-OLED is also equipped with a proximity sensor for the on-screen display, which is activated when you move your hand close to the bottom edge of the screen, making operation even more intuitive. The rear I/O design is intended to ensure tidy cable management and at the same time provides access to numerous modern connection options. The monitor’s connection options are also numerous: 2x HDMI, DisplayPort 1.4, USB-C 3.1 DP Upstream with 15W Power Delivery, 4x USB-A 3.1 with KVM, a 3.5 mm headphone jack and USB-C 3.1 DP ALT with 65W Power Delivery.
The monitor also offers built-in protection mechanisms against burn-in. These include an image refresh after eight hours of operation and an orbit function that shifts the entire image by one pixel every three minutes to minimize the risk of burn-in effects. Of course, the monitor also supports technologies such as NVIDIA G-Sync and AMD FreeSync Premium to prevent tearing and ensure smooth motion in fast-paced scenes.
However, the device also comes at a price. According to the RRP, it costs a hefty 1199.99 US dollars, which is quite a reasonable price.
Source: Corsair
Midnight Angel
178 Kommentare 140 Likes
Xeneon, nicht Xenon!
Xenons gibbet von Intel.
Edith: Selbstverfreilich waren das von Intel Xeons; Xenon bekomme ich bei Linde...
' Der Monitor ist in verschiedenen Farbvarianten erhältlich, darunter „Stylish White Design“, „Seamless Immersion“ und „Vesa Mount Standard“. '
Ähm... hä?
Vesa Mount Standard ist eine Farbvariante?
S
Snake7
33 Kommentare 6 Likes
Und wie lange gibtsd Garantie?
R
RazielNoir
564 Kommentare 268 Likes
Es gibt keine 3 Farbvarianten. Nur eine. Und die hat einen weißen Standfuss, weisse Rückseite und eine Möglichkeit der VESA-Montage. Etwas mehr Sorgfalt bei der Artikelerstellung darf es hier ruhig sein, auch wenn die Website kostenlos ist. Sorry, aber von dem Autor sind die letzten Artikel nicht unbedingt von hoher inhaltlicher Qualität aufgefallen, im Gegensatz zu FritzHunter oder Igor selbst
T
TheSmart
537 Kommentare 293 Likes
Ich denke das ist auch nur ein Pseudonym für eine KI.
Denn das ist ja der neuste Schrei.. von der KI sich Texte schreiben zu lassen.
Ist ja auch i.O. und erspart eine Menge Zeit..nur sollte man da auch nochmal kurz drüber schauen bevor man es online stellt.
H
Hoang Minh Le
8 Kommentare 10 Likes
Ich möchte hier nur mal etwas klarstellen. Es wurde keine KI verwendet, um den Text schreiben zu lassen, sondern selber von mir.
Ich habe nur bezüglich Übersetzung einen Fehler getan und dieser ist mir dann erst nach euren Hinweisen aufgefallen und wurde auch entsprechend korrigiert.
Tronado
4,766 Kommentare 2,660 Likes
Nee, XEON heißt die Intel CPU. XENON ist ein Edelgas. :D
Midnight Angel
Hatte mich Tante Edith schon am Freitag drauf hingewiesen; ich sollte nicht kurz nach einer Zahn-OP posten... :D
'Und wenn Sie Unsyntheth sich weiterhin derart inkomparativ verhalten, dann werde ich ein Exemplar stationieren, von dem noch Generatoren sprechen, jawoll!'
Lagavulin
302 Kommentare 260 Likes
Wir alle machen mal Schriebfehlr. Schlamm drüber!
Hoang Minh Le
