Corsair has introduced the NAUTILUS RS and NAUTILUS RS ARGB series CPU coolers. These new models offer efficient processor cooling and are designed for easy installation and broad compatibility with current CPU sockets. The NAUTILUS RS series coolers are available in black and in 240 mm and 360 mm sizes, while the NAUTILUS RS ARGB models are also available in white and feature ARGB lighting.
The NAUTILUS RS series includes a quiet, efficient pump and a specially designed contact surface that has been factory-applied with thermal paste in an optimized pattern to maximize heat transfer. These coolers are equipped with 240mm or 360mm radiators and use CORSAIR RS120 fans to provide powerful cooling for high-end CPUs.
The RS120 fans of the NAUTILUS RS series offer a strong airflow and achieve PWM-controlled speeds of up to 2,100 rpm. The ARGB models are equipped with RS120 ARGB fans, which have eight RGB LEDs per fan. The fans can be easily connected in series to simplify cabling and can be controlled via a 4-pin PWM connector and a 4-pin ARGB connector on the mainboard.
The RS120 fans are optimized for use on radiators and feature CORSAIR AirGuide technology and magnetic levitation bearings, which enable targeted airflow cooling with low noise levels.
For users who don’t want RGB lighting, the black NAUTILUS RS models offer a discreet aesthetic without flashy details. The ARGB models, on the other hand, have eight RGB LEDs on the pump and on each fan, the lighting of which can be customized using the mainboard’s ARGB software.
The NAUTILUS RS series coolers are equipped with mounting parts for Intel LGA 1700 and LGA 1851 as well as AMD AM4 and AM5 systems and include all the necessary brackets for cases that support 240 mm or 360 mm radiators.
About Corsair:
Corsair is an American company specializing in the production of computer accessories and hardware. Founded in 1994, Corsair initially focused on high-quality memory modules (RAM) before expanding its product range to include components like power supplies, cases, cooling systems, and SSDs. Today, the company is well-known for its gaming peripherals, including mechanical keyboards, gaming mice, headsets, and streaming equipment. Corsair has built a reputation for developing products that combine high performance, durability, and sleek design. Especially in the esports and gaming sector, Corsair is a popular brand that continues to grow through innovative technologies and partnerships with the gaming community.
Bisher keine Kommentare
