NVIDIA has lifted the muzzle date for the GeForce RTX 5050 and, as always, the board partners are pouncing like hungry seagulls on a discarded fish sandwich. Particularly eager: Colorful. The Chinese manufacturer is presenting five new models – from serious to whimsical, somewhere between graffiti art, cosplay cat and classic card fare.
Technology meets teen aesthetics: the iGame RTX 5050 Ultra W series
Let’s start with the hip-hop counterpart of the graphics card world: the iGame GeForce RTX 5050 Ultra W OC 8GB-V is a triple-fan card with a length of 314 mm. Its little brother, the Ultra W DUO OC 8GB-V, comes in at just 243.5 mm – a “downsizing” with style. Both models offer 4 2 power phases and a boost clock of 2647 MHz – slightly above the reference value (2571 MHz). Technically not a revolution, but solid home cooking for the mid-range sector. The design? White shroud, RGB graffiti, supposedly “hip-hop-inspired”. There’s also a “One-Key-OC” button on the I/O, which unlocks performance at the touch of a button – at least in theory. Whether this is more than just a marketing gimmick remains to be seen. But hey, the trend is towards show cards for cases with a glass wall.
MEOW ORG DUO: An RTX 5050 in a cat costume
Now it’s getting absurd. The COLORFIRE GeForce RTX 5050 MEOW-ORG DUO 8GB uses a 3 2 power phase layout, but only boosts to 2497 MHz – i.e. below the reference design. Why? Probably thermal or cost-related downbinning. Or because cats prefer sleeping to running. The design is… special: White-orange color scheme with cat motifs on the shroud and backplate. What looks like an homage to anime culture on the back is actually a clever attempt to sell the low-end segment via style rather than specification. Technically nothing special, but perhaps a big seller in livestream-fixated markets.
Battle AX: The pragmatic spearhead
If that’s all too colorful for you, you can opt for the Battle AX series. Here you’ll find the RTX 5050 Battle AX 8GB-V with triple fan and the Battle AX DUO with dual-fan design. Both achieve 2572 MHz boost (slightly above reference), equipped with 3 2 power phases. The design? Black shroud, red accents – finally a GPU that doesn’t look like a streetwear experiment. The Battle AX cards are clearly positioned: low-cost performance without frills. Anyone who can switch off their RGB LEDs without losing their bearings will feel right at home here.
RTX 5050 – too little, too late or just right?
The RTX 5050 is – unsurprisingly – based on the lower Ada Lovelace drawer. 8 GB VRAM, mediocre boost clocks, known power consumption. In the 1080p field, it is ranked slightly below the RTX 4060, which makes its existence seem almost absurd – if it weren’t for the price issue. It could be interesting for entry-level PCs or OEM systems if the street price is right. But as usual, NVIDIA is keeping quiet about this like a secret service.
Colorful, loud and technically well-behaved
Colorful launches five RTX 5050 designs on the market – from a hip graffiti look to a simple combat card. Technically, everything remains within reason: easy overclocking, common VRM layouts, no ray tracing wonders. But the variety of designs shows where the music plays: in the eye of the buyer. Those who pay less attention to FPS than to style when building a PC have plenty of choice here.
Source: Colorful
5 Antworten
