Cooling Reviews Thermal grease and pads
Best thermal putty, database and charts – putty versus putty, tests and suitability for memory modules and voltage regulators
What is Thermal Putty and what is it useful for?
Thermal putty is a thermal interface material that has been specially developed to efficiently fill gaps between heat-generating components and heat sinks. Unlike thermal paste or pads, it is a viscoelastic mass that remains flexible and can adapt to irregular surfaces. It is particularly suitable in situations where large or uneven contact surfaces need to transfer heat evenly without the need for high mechanical pressure. Thermal putty plays an important role in a high-performance PC, e.g. on mainboard voltage converters or especially in the cooling of graphics cards. Graphics cards often have components such as VRAM chips or voltage converters that are not mounted at the same height as the GPU itself and are also at different heights. This creates gaps between these components and the heat sink. Thermal Putty can fit into these gaps perfectly and cover everything, regardless of their size or shape, thus ensuring even heat dissipation.
A major advantage of Thermal Putty is that it generally does not exert excessive mechanical stress on sensitive components. Thermal putty, on the other hand, requires less contact pressure as it spreads extremely well even at low pressure due to its consistency. A common problem when using thermal pads in graphics cards is the variability of the pad thickness, as some cards use up to three different pad thicknesses and qualities, whereas thermal putty is one-size. If thermal pads do not have the optimum thickness, they either cannot exert enough pressure to ensure efficient heat transfer, or they are compressed too much, which can impair their performance, or the pressure then has an unfavorable effect on the components.
Putty database v1.0.1
We have incorporated the extensive feedback from the beta phase and are now finally putting the first final version of the database online. Operation has been greatly simplified once again and clarity has been improved. For the navigation and the evaluation of the results, I will provide a brief explanation of the most frequently asked questions. There are only three ranges to choose from, which prioritize a specific application, as the thermal conductivities of the individual pastes differ greatly between the respective layer thicknesses. Depending on the selected range, an average value is therefore calculated from the actual, effective thermal conductivity and used for subsequent sorting. However, all pastes are always displayed immediately, but sorted differently and adapted to the range.
Preselection by layer thickness
Memory Suitability on the memory modules with rather thin layers from 250 µm to approx. 1000 µm (1 mm). Effective thermal conductivity (λeff in W/m·K) averaged over this range. The delta is also evaluated as the measured temperature difference between the hot and cold surfaces on average for this range.
VRM Suitability on the voltage regulators and coils as well as for larger gaps with rather thick layers of 1000 µm to approx. 1500 µm. Effective thermal conductivity (λeff in W/m·K) averaged over this range. The simulated surface temperature of the hot surface, i.e. the surface to be cooled, is also evaluated. In contrast to the storage tank, this is an absolute value and not a delta.
Help for the search result
Stickyness
The traffic light rating from 1 to 3 is based on consistency, because the stickier and thinner a putty is, the more difficult it is to apply correctly. Green stands for normal to rather dry, yellow for somewhat sticky and orange for too liquid and sticky. This value has no influence on the sorting, but is a usability statement in the table.
Sticky
Sticks the desired puty and remembers it on all displayed pages. This allows you to compare a putty from page 1 with one on page 5, for example.
Selection field
If two fields are selected, a 1:1 comparison of these two putties is possible
Name
Click on the manufacturer or the name of the putty to open the detailed individual test, including material analysis (ingredients) and microscopy (particle sizes)
This database is constantly being expanded and new products added. It is therefore always worth visiting again.
Click on the designation or manufacturer for detailed information and test results.
Honeywell HT10000
10.4 53.7 9.2 18.4 Normal
Thermal Grizzly TG Putty Pro
9.5 54.2 8.4 19.5 Light Sticky
Laird Tputty 910
8.6 55.5 7.5 21.1 Normal
HunanFeihongda LTP81
7.7 56.3 6.2 23.7 Normal
Upsiren UTP-8
7.6 56.6 6.9 22.5 Normal
Upsiren UX Pro Ultra
7.6 56.6 6.1 23.9 Normal
Laird Tputty 607
6.5 58.0 5.9 24.7 Normal
Thermal Grizzly TG Putty Advance
6.5 58.0 5.8 24.9 Normal
Hardwareliebe Extreme64
5.9 58.3 5.2 25.7 Normal
Big Pinwheel CX-H1300
5.5 58.7 4.8 26.7 Light Sticky
Halnziye HY 236
5.3 59.3 4.7 27.2 Light Sticky
Thermal Grizzly TG Putty Basic
4.7 61.1 4.2 29.8 Light Sticky
T-Global TG6060
4.6 61.2 3.9 31.5 Sticky
LiPoly SH-Putty 3
4.3 61.9 3.6 33.0 Normal
Halnziye HY 268
4.2 61.5 3.7 31.2 Sticky
Hardwareliebe Value32
3.8 62.2 3.3 32.8 Light Sticky
Halnziye HY 234
3.6 63.0 3.2 33.6 Sticky
Computer Systems K5 Pro
0.5 76.3 0.5 65.7 Sticky
VRM
Memory
Test setup, measurement methods and basics
Our database is based on real laboratory values, which we have elaborately determined according to industry standards. However, many of these results contradict the manufacturers’ marketing claims and ruthlessly expose contradictions and lies, but they are all well-founded, reproducible and legally sound. These measurements not only reflect the general performance values of the pastes, but also enable an assessment of the suitability for a specific area of application (layer thicknesses, surfaces) as well as the suitability taking into account the individual capabilities of the respective user. In addition, the material analysis including digital microscopy is suitable for making your own assessment of the contents and possible durability of a putty, even if I cannot and do not want to accept any liability for this.
Test setup and methods Material analysis and microscopy Basic knowledge
Here you can find out why effective thermal conductivity and bulk thermal conductivity can be completely different in practice, what role the contact resistance between the surfaces and the paste plays and how thermal compound can be measured precisely. There is also a detailed description of the equipment, the methodology and the error tolerances. You will learn how laser-induced plasma spectroscopy works and the advantages and limitations of the measurements. There is also high-resolution digital microscopy and analysis of particle sizes. This information is also used to estimate the long-term stability of a paste. Anyone who has always wanted to know what is or is not in a paste and how these pastes are produced will find what they are looking for here. The basic article is intended to give you a better understanding of what is often sold for far too much money and sometimes with adventurous promises.
You are welcome to leave suggestions and comments in the forum, via PN or e-mail. If you would also like to contribute to the project and send me samples of thermal paste that have not yet been entered in the database, please contact me by e-mail. The e-mail address can be found in the imprint. Of course, this also applies to the manufacturers whose products we would like to test, regardless of which continent the product comes from. The scope of the database is de facto unlimited and as the methods and equipment are always the same, it can be expanded over the years and still remain comparable.
That is the advantage over measurements on CPUs or GPUs and changing environmental conditions. And that is why I will continue to test and add new pastes and publish individual tests for interesting products. My very special thanks also go to my colleagues at Berlin-based Nanotest GmbH and Keyence for their technical advice and support to ensure that such a major investment pays off in the end.
A
Aragornius
94 Kommentare 34 Likes
Bravo! *Applaus!* 🥳🎉
Antwort 5 Likes
T
Toran
19 Kommentare 9 Likes
Moin - danke für die Tabelle! Zwar sind da keine direkten Zahlen zu sortieren, aber beim Anklicken der "Klebrigkeit" zwecks Sortierung klappt danach... gar nix mehr ;-)
Bestimmt nicht so gedacht - entweder keine Funktion zulassen, oder Sortieren nach Farbe..?
DrDre
341 Kommentare 185 Likes
Sehr schön!!
Igor war ja wieder sehr fleißig :giggle:
Danke für die Datenbank. Leider geht das vergleichen noch nicht:
2,147 Kommentare 1,374 Likes
@Igor Wallossek : Zunächst einmal 🏅🎉! Toll, daß die Früchte Deiner (vielen) Arbeit jetzt auch für die Putties einfach gesucht und gefunden werden können!
Ein Vorschlag (wenn's mal reinpasst und die Datenlage es erlaubt): die subjektiv erwartete Lebensdauer der respektiven Putty usw hinzufügen, dh wann sollte man hier ans Ersetzen denken. Kann sein, daß ich hier einfach etwas faul sein will, aber ich würde zB eine hypothetische drittbeste Paste oder Putty usw der wertemäßig Besten vorziehen, wenn die (hypothetische) Testsiegerin wahrscheinlich schon nach einem Jahr wieder ausgewechselt werden muss.
11,541 Kommentare 22,227 Likes
So, die Seiten sind jetzt abrufbar 😆
Antwort 7 Likes
Rizoma
245 Kommentare 256 Likes
Nice jetzt weis ich das, das HW HT10000 richtig gut ist aber kaufen kann ich es nicht 🤪
Ich habs doch auch kaufen können. Gibts natürlich nicht in der Gehirnfabrik :D
Das ist wie mit guten Nischenparfüms, die gibts auch nicht bei den Mainstream-Dealern wie Douglas & Co.
Antwort 4 Likes
R
Roboc4t
2 Kommentare 1 Likes
Ich bin neu hier und finde die Berichte und ganzen Wissensdatenbanken echt toll. Danke dafür.
Möglicherweise hat sich jeder Neuling oder nicht so tief in der Materie Steckende schon mal wie ich gefragt, warum wenn Puttys einen teils doppelt so guten Ø λeff in W/m·K haben, man diese nicht auch auf CPUs einsetzt. Mann könnte ja den Abstand von Kühlkörper zum Heatspreader erhöhen um so auch Putty einsetzen zu können. Mir schwebt da z.B. eine 3D-gedruckte Presse o.ä. für eine möglichst gleichhohe, gleichmäßige Puttyschicht vor. Doch was spricht dagegen? Sind es die krassen Temperaturwechsel der CPU und die damit verbundenen chemischen und physikalischen Eigenschaften der Puttys, warum das (vermutlich) niemand macht?
Wie gesagt ich bin neu hier und vielleicht ist das supernaiv...
Dagegen spricht die Schichtstärke. Gute Putties gehen kaum unter 200 µm, Paste aber bis unter 20 µm. Ergo ist auch der Wärmewiderstand der Schicht um den Faktor 10 (!) niedriger.
Das HT1000 gibts übrigens bei EUGENEY_KH, wo man auch die TC-5888 bekommt
Antwort 7 Likes
R
Roboc4t
Vielen lieben Dank. Das klingt logisch. Irgendeinen Grund gibt es ja immer. ;)
w
wertzius
59 Kommentare 47 Likes
Man bin ich froh, dass ich das K5-Pro niemals irgendwo reingeschmiert habe.
Snarks Domain
40 Kommentare 63 Likes
One of the exceptions currently being Halnziye HY236 which can very easily get below 0.1mm. When I measured with digital callipers I managed to get it down to 0.03mm. It's the putty I recommend for any laptops with gaps below 0.5mm or if wanting to use putty with shims.
Antwort 4 Likes
P
Pokerclock
650 Kommentare 614 Likes
Mein Vorschlag wäre noch eine Spalte hinsichtlich der (einfachen) Verfügbarkeit und dem P/L-Verhältnis.
Es ist ja schön, dass man mit einem Produkt ganz oben in der Liste steht, aber das nutzt einem nicht viel, wenn man keine Bezugsquelle hat, mit Ausnahme eines Reddit-Users...
Das Gleiche gilt für Putties, die man nur B2B bekommt.
Demgegenüber steht TG, das man gefühlt an jeder Ecke kaufen kann, mit Gewährleistung und Ansprechpartner in Deutschland.
Antwort 7 Likes
t
trucker1963
11 Kommentare 0 Likes
Endlich mal eine super Datenbank von Putty zum Vergleichen . Habe Putty selber schon auf Grakas im Einsatz und bin zufrieden damit .
Snarks Domain
Keeping track of price/gram is very difficult. Putty prices change dialy, and have so many storefronts online offering them at different prices, shipping costs, etc. This gets even more complicated when considering all the different countries folks live in and how their marketplaces are different and/or limited. India can no longer make purchases on Aliexpress, but Ebuy7 seems to work. Amazon Canada has limited options, but Amazon USA has more options. The European Union's access to putty is more limited than other areas of the world. Then they are the trademark disputes between CSGR and Upsiren, causing all sorts of accessibility issues for the Upsiren Putties depending on which country/region you live in .
Luckily there are many putty options these days, and there will be even more in the years to come. I believe we'll see stuff from the likes of Gelid, Cooler Master, Thermalright, and other customer oriented brands.
DMHas
92 Kommentare 46 Likes
Super! Danke Igor!
Jetzt hat man nicht nur ein Nachschlagewerk für Wärmeleitpaste sondern auch für einen möglichen Wechsel vom Wärmeleitpads.
Härle'sBöckle
309 Kommentare 196 Likes
Igor hat es schon erwähnt: Eugeney_KH auf overclockers.ua
- 35g für 33,75$
- Bezahlung mit Paypal
- Versand und Zollgebühren kommen noch dazu
Über Telegram auf Englisch anschreiben, um welche Artikel es geht.
Dazu die Artikelliste heranziehen:
Über die Hauptseite gibt es auch Infos zur TC-5888, die nicht in der Liste auftaucht.
Antwort 7 Likes
Alter.Zocker
244 Kommentare 173 Likes
Finde es gut und bin Igor dankbar, dass es jetzt auch für Putty's eine Vergleichsdatenbank gibt.
Dennoch schließe ich mich hier @Pokerclock an und hätte gerne zusätzlich in der Übersicht auch eine "Spalte" o.ä. zur generellen Verfügbarkeit.
Es spielt für mich und viele Andere sicher eben doch eine erhebliche Rolle, ob ich ein Produkt nur über die Kommunikationsplattform "Telegram" von einem Privatmann aus der Ukraine bzw. mit noch obskurerer Herkunft von einem völlig "gesichtslosen" anonymen Anbieter über Ali aus China beziehen kann, ODER ob ich das bei einem in DE/EU etablierten Onlineanbieter, wo ich u.a. schon vielfach problemlos eingekauft habe, einfach per Mausklick bestelle und exakt genau das bestellte Produkt dann zwei Tage später im BRiefkasten/Packstation finde... Dazwischen gibts sicher viele weitere Abstufungen der "BEschaffungskomplexität" aus Sicht des Endverbrauchers, dem es dann auch kaum was nützt, wenn B2B-Kunden hier schon deutlich andere Möglichkeiten haben....
Antwort 5 Likes
geist
14 Kommentare 13 Likes
In welchem Verhältniss sind diese Puttys zu "normalen" Pads? Ich meine ist das schlechteste Putty dennoch besser als "normale" Pads?
Oder wie ist das einzuordnen? Dies meine ich rein Leistungsmässig und nicht mit den vor oder Nachteilen der Pads bzw Puttys.
Follow Igor:
