Today we have another mini system from Beelink in review. The newest SEi Pro series uses processors from the 11th generation. Generation from Intel. How the i5 with the sonorous name 11320H and its Xe graphics unit performs is tested in the following article. A few surprises await us!
Does the design on the cuboid box remind you very much of the Windows 10 default background or is it just me? Apart from that, there is only a short list of specifications on the back, that’s it.
The solid cardboard and two layers of foam protect the mini PC during transportation.
There is nothing special to report in terms of accessories; they stick to the de-facto standard in the form of a power adapter, VESA mount and two HDMI cables of different lengths.
The power supply is a TDX-1903000E, which I have only seen on Beelink’s Ryzen models. It can supply a maximum of 57 watts at 19V / 3.0 amps.
Specifications
Here is an overview of the specifications, more information can be found on the manufacturer’s product page.
15 Antworten
