Today we will take a brief look at the revised version of the graphics card dock for special mini PCs from Beelink. As I recently reported, I was unable to establish a reliable connection with modern graphics cards from PCIe 4.0 and upwards. This problem should now be solved.
You can find the full report here:
Specifically, Beelink has now installed two “PCle 5.0 signal enhancement chips”, which are designed to keep the signal between the mini PC, dock and graphics card stable.
Here’s another look inside, at first glance there are no noticeable changes. However, two additional chips on the internal PCB are not so easy to spot, especially as they are hidden by the power supply unit and its cover.
8 Antworten
