Mini-PC Reviews System
Beelink EQ14 Mini-PC in test – A first Intel N150 shows up, but not quite as expected
If you look around in the area of inexpensive small computers or energy-saving home lab centers, you will quickly come across systems with the Intel N100. With just enough power for normal desktop operation with browser applications and complex home assistant instances, it has become a real favorite. Even various NAS systems use it, some of which we have even tested. But now there is a successor in the form of the N150, which is installed in the EQ14 tested here today.
Visually, the box is the same as the other Beelink mini PCs, with a large picture of the top of the system on the front and the obligatory sticker on the back with information about the contents.
If we remove the cover, the EQ14 is directly revealed. But more on that later, of course we’ll also take a closer look at it.
Here, too, the manufacturer has integrated the power supply unit, so that only a short manual, power cable and HDMI cable are included.
Here comes a typical YouTube “call to action”: what do you think of integrated power supply units? Due to my IT profession, I have already set up hundreds of workstations with these small computers, albeit more from Dell or Lenovo, and only a handful have had problems with the power supply unit after years. A built-in power supply would definitely have saved me a lot of squeezing in cable ducts. Write it in the (forum) comments!
Specifications
Here is the usual overview of the technical details, further information can be found on the manufacturer’s product page.
2,200 Kommentare 1,405 Likes
@Tim Kutzner : zunächst einmal Danke für die Fortführung der Tests der Kraftzwerge! Der Beelink hier begeistert mich allerdings nicht; das integrierte Netzteil ist IMHO eher ein Manko, eine weitere externe PSU mit Barrel Anschluss kann im Fall der Fälle schnell gefunden werden, während ich vom Aufmachen und selbst Reparieren einer uU abgerauchten internen PSU die Finger lassen würde.
Dazu kommt noch die Abwärme, die dieses interne Netzteil jetzt noch mit ins Gehäuse bringt; bei einem größeren Kraftzwerg (Oxymoron, ich weiß 😁) der sowohl deutlich teurer und leistungsstärker ist das vielleicht ästhetisch ansprechender, aber selbst da ist mir ein externer Adapter lieber.
Der N150 war und ist in meinen Augen auch eher eine Enttäuschung - Intel hat sich hier leider kein Bein rausgerissen. Deine Bemerkung mit der besseren iGPU habe ich übrigens nicht ganz verstanden, der N100 hatte ja auch schon eine 24 EU UHD Grafik, so wie der N150 hier.
Es sieht leider eher so aus, als hätte Intel einfach an der Taktschraube gedreht und jetzt gibt's halt noch ein paar MHz mehr - schade. Der kleine 4 Kern Gracemont hätte deutlich mehr davon gehabt, wenn man ihm zB den größeren L2 Cache spendiert hätte, den zB die 4 E Kern (Gracemont) Cluster in Raptor Lake haben; nämlich 4 MB L2, statt den 2 MB L2 in Alder Lakes.
Oder auch dazu oder stattdessen etwas mehr L3, damit die CPU und die iGPU Kerne nicht so oft ins RAM müssen, aber dazu wären eben neue Masken usw nötig gewesen, und dafür gab's wohl kein Geld.
Ich hoffe, daß es auch weiterhin die N100 geben wird, denn solange es dieses SoC gibt und es auch weiterhin billiger ist als das N150 gibt's IMHO keinen Grund, sich einen N150 anzuschaffen.
S
Seriousjonny007
7 Kommentare 3 Likes
Ich will ja nichts sagen aber für ~ 200€ bekommt man bei Amazon schon einen Mini PC mit Ryzen 5 5500U Prozessor, 16 GB RAM & 512 GB SSD.
Und der zieht ja nicht nur Kreise sondern schon eher Umlaufbahnen um den N150 (laut Vergleichsliste in jedem Benchmark mal mindestens doppelt so schnell).
Arnonymious
217 Kommentare 89 Likes
Über 10% Unterschied zum nächsten N150 ist schon heftig. Da bin auch ich gespannt, was von Beelink noch kommt um das zu ändern.
Was das Thema Preispunkt/Performance generell angeht, regelt sich das sicher im Laufe der Zeit über den Straßenpreis.
Tim Kutzner
947 Kommentare 777 Likes
1000Mhz anstatt 750Mhz ist ja aber trotzdem ein erwähnenswerter Unterschied von 33% mehr Takt :D
Tim Kutzner
Das ist absolut richtig, alle verfügbaren Optionen kann man aber einfach unmöglich im Blick haben :D
Ich schaue schon immer, dass ich so ungefähr die ganzen von uns getesteten Modelle im Kopf habe, aber selbst da wird es langsam schwierig
ro///M3o
396 Kommentare 277 Likes
Fühle absolut mit dir 🙃 Bis ich den "für mich" Richtigen (R5 5600H) gefunden hatte, sind Tage vergangen an Suche und Vergleiche. Gefühlt kommen täglich mehrere, vor allem bei Temu und co., dazu, was ich aber nicht schlecht finde. Die Perlen muss man halt raussuchen. So bissle wie die Pasten geworden hahaha.
Dank deinen Tests hier ist aber eine ziemlich genaue Einschätzung möglich, was ich genial finde. Danke nochmal! Inzwischen eine wirklich beachtliche Liste geworden. Bitte so beibehalten :cool:
Weil es so viele sind inzwischen, eventuell hilft eine Filterfunktion / Sortierfunktion für die Charts?
c
cunhell
612 Kommentare 590 Likes
Die Mini-PCs mit 5000er Serie CPUs hatte ich auch auf dem Schirm. Wenn ich mir allerdings ansehe wie zurückhaltend AMD schon bei meinem 5600g mit Grafiktreibern agiert, bin ich mir nicht sicher, ob eine 5000er-Basis mit Vega-iGPU wirklich eine gute längerfristige Investition ist.
Ich denke, dass die Vegas in nicht allzulanger Zeit zu Legacy-Treibern wandern.
Ich würde daher, wenn schon, eher zu Geräten mit 6000er oder neuer greifen, und die sind nicht so günstig zu haben.
Cunhell
ro///M3o
Hast schon Recht, die sind mittlerweile in die Tage gekommen aber wenn ich daran denke wie verbreitet die sind und dass auch Embedded Versionen verkauft werden, dann glaube ich, dass es noch ziemlich lange dauern wird bis die in die Rente geschickt werden.
c
cunhell
Naja, laufen tun die ja weiterhin, aber die Grafik bekommt halt keine Updates mehr. Bei Embeded eher verschmerzbar als bei einem Mini-PC der für Multimedia oder Gaming verwendet wird.
Cunhell
Ghoster52
1,608 Kommentare 1,286 Likes
Danke für den Test! (y)
Ich hätte in 2025 eher was am RAM (Single Modul) und (SATA) SSD Geschwindigkeit zu meckern,
finde das nicht mehr ganz zeitgemäß. Der RAM bremst das ganze System mMn.
R
RazielNoir
553 Kommentare 261 Likes
Zum Thema integriertes Netzteil:
Klar kann man ein externes leichter gegen ein anderes mit gleicher Leistungsabgabe tauschen. Aber wenn der Hersteller das Netzteil sauber zum Gerät gewählt hat und nicht gerade den billigsten Schrott mitliefert, sehe ich da keinen Bedarf. Ich habe jedenfalls noch nie ein Netzteil von kleinst PC's oder NAS tauschen müssen. Von Leistungsfähigen PC'S allerdings schon.
Dafür ist mir der Platzbedarf am Mehrfachstecker deutlich angenehmer, wenn nur ein schmaler Eurostecker oder Kaltgerätestecker sitzt und man die Leitung sauber per Kabelwicklung/Kabelkanal bündeln kann.
Tim Kutzner
Für den einzelnen Speicher-Kanal des N150 kann Beelink zumindest nix :D
Und immerhin sind beide M.2 Slots mit PCIe 3.0 angeschlossen, wenn auch nur mit einer SATA SSD bestückt
Feen-Schubser
173 Kommentare 85 Likes
Was bei solchen Geräten auch spannend wäre.
Q4OS mit Trinity und Speedometer 3.0 oder anderen
Weil CB interesiert mich jetzt nicht so, weil ich sowas nur fürs Internet nutzen würde.
Aber gibt auch Leute die das zum Vergleich brauchen.
Dankeschön für den Test.
Ich habe in A300 und mag die Minipcs allgemein.
Schöne alte Windows Theme :)
Erwähnenswert ist die Erhöhung des maximalen Takts der iGPU schon; meine Kritik an Intel ist eben, daß sie hier wirklich nur an der Frequenzschraube gedreht haben. Und das steht im Kontrast zum Namen, der ja 50% Verbesserung suggeriert.
Ein N150 mit etwas größerem L2 und/oder L3 Cache und vielleicht noch 2-3 zusätzliche PCIE Bahnen wär in der Tat eine gute Erweiterung nach oben gewesen. Der N100 und Varianten (N95/N97) sind IMHO derzeit die Stars im CPU Angebot von Intel. Billig, gut, sparsam, what's not to like?
Ich hoffe, daß der N100 trotzdem weiterhin erhältlich bleibt.
R
RazielNoir
Und was ist mit dem N300/305? Gibt es dann demnächst einen N350?
c
cunhell
Es gibt ja schon einen Miini-PC mit nem 1220P. 8-Ecores und 2 P-Cores. Kostet mit 24GB RAM und 500GB ca. 280€
Ob sich da ein N300er lohnt?
Cunhell
Lowbird
41 Kommentare 63 Likes
Hast du diesbezüglich einen Link? Das wäre ja tatsächlich sehr lukrativ mit den Specs zu dem aufgerufenen Preis.
Beste Grüße
c
cunhell
Beelink EQi12 Intel® Core 1220P €258,38​
Musst rechts oben auf German klicken, dann sollte der €-Preis angezeigt werden.
Der ist sogar billiger geworden. Als ich meinen N100 schliesslich gekauft habe, war der noch bei 282€
Für den Preis hätte ich auch den gewählt.
Cunhell
Victorbush
551 Kommentare 118 Likes
Ich frage mich, ob so ein Teil mit Office 365, Annotator, ERP Programm überhaupt funktionieren könnte.
Mein Firmensurface 7 mit I5… Prozessor kackt dabei ab.
Das Elend nahm mit Office 365 seinen Lauf….
Nur 15-20 GB freier Speicher tun scheinbar ihr übriges…..
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
