What do you need for such a fancy project? Actually, it's not that much, as long as it's just the water cooling parts. These are normal off-the-shelf components. The most important and, unfortunately, the most expensive component is, of course, its own house with a cool basement. That will then probably also be the exclusion criterion for many. But watching is expressly permitted. Our community member Youngtimer was kind enough to help us out with his house, invested time and his pictures, so that I can show you the whole thing today. The idea for this project came from a new FTTH house connection and new network cables had to be laid in the house anyway. So why not drill a few larger holes and lower the water cooling? Waste heat and noise from fans and pump should be moved from the office to the year-round cool basement.
- 1 - Start und ab in den Keller!
- 2 - Der Durchbruch
- 3 - Wer steht da auf dem Schlauch?
- 4 - Voller Saft und Kraft
- 5 - Spannungsbogen
- 6 - Ankunft am oberen Bahnhof
- 7 - Der Radiator-Gladiator
- 8 - Hängeparty in der Talstation
- 9 - Alles hört auf mein Kommando!
- 10 - Infotainment pur: die aquasuite von Aqua Computer
- 11 - Abgenippelt
- 12 - Aquarium im Office?
- 13 - Tiefe Einblicke
- 14 - Nachtarbeit statt Nacharbeit
- 15 - Verhexte Gaming-Kaltschale
- 16 - Königliche Sauna mit Fernblick
- 17 - Kellermeister mit Zukunftsperspektive
58 Antworten
