The ASUS ROG Swift PG27AQDP is the world’s first gaming monitor with a WQHD resolution (2560 x 1440p) and a refresh rate of 480 Hz. This power is generated by an LG OLED panel. In addition, this panel has even been given a new subpixel layout – RGWB. This should have an effect on text readability. In other words, the PG27AQDP could turn out to be a real all-rounder. So it will certainly be exciting and we won’t talk about the price until the very end.
The monitor arrives at your home well packaged. The choice of packaging is ok, even if we have already seen that it is also possible without foam/plastic.
As usual, the technical data is linked below. If you would like to take a look at the ASUS ROG website: Click here!
Technical data
ROG Swift OLED PG27AQDP gaming monitor datasheet
There’s a lot to do today, because the PG27AQDP wants to be a jack of all trades. I hope that ASUS hasn’t just painted castles in the air on paper here. Let’s get started…
- 1 - Introduction, Features and Specs
- 2 - Workmanship and Details
- 3 - How we measure: Equipment and Methods
- 4 - Pixel Response Times
- 5 - Display Latencies
- 6 - Color-Performance @ Default Settings
- 7 - Direct Comparison and Power Consumption
- 8 - Color-Performance calibrated
- 9 - HDR-Performance
- 10 - Summary and Conclusion
13 Antworten
