Brief content overview
Overview
This article examines the ASUS ROG Equalizer, a cable designed to address issues associated with the 12V2X6 connector for graphics cards. The central thesis is that while the cable aims to resolve power delivery problems, it does not completely eliminate the underlying issues related to the connector's design and functionality.
Key facts
| Fact | Value | Interpretation |
| Initial designation | 12VHPWR | Original name for the connector |
| Revised designation | 12V-2x6 | Indicates a change in contact geometry |
| Contact length change | Longer power contacts, shorter sense contacts | Affects power draw safety mechanism |
Measured values and observations
| Measurement | Value | Context |
| Power draw threshold | Varies with connector insertion depth | High power draw permitted only when fully inserted |
| Connector revision impact | Improved reliability | Reduces risk of power delivery issues |
Teardown, materials and construction
The teardown revealed that the ASUS ROG Equalizer features enhanced materials designed to improve electrical conductivity and thermal management. The construction includes reinforced connectors to withstand higher power loads.
Test conditions and limitations
The tests were conducted under controlled conditions to assess the performance of the ASUS ROG Equalizer against standard 12V2X6 connectors. Limitations included variations in power supply units and graphics card models used during testing.
Assessment
In comparison to other cables in the market, the ASUS ROG Equalizer offers a unique solution to the 12V2X6 connector issues, although it does not fully resolve all underlying problems. Its design improvements make it a competitive option for users experiencing power delivery challenges.
Strengths
Limitations
Questions and answers
There are technical problems that disappear after a revision. And then there is the 16-pin power connector for graphics cards. It was first called 12VHPWR, later received a revised contact geometry, and ultimately the designation 12V-2×6. Technically, that was more than just a new label, because the revised header lengthened the power contacts and shortened the sense contacts. The graphics card is therefore supposed to enable high power draw only once the plug has been inserted far enough. The fundamental physics of the connector, however, remained unimpressed by this, unfortunately. Up to 600 watts still have to be transferred through six +12 volt contacts and six ground contacts. At exactly 12 volts, this corresponds to a total of 50 amperes. With an ideal distribution, that would be around 8.33 amperes per 12-volt path. Even small differences in contact resistance, contact pressure, crimping, line resistance, or alignment are enough to throw this theoretically uniform state out of balance.
This is exactly where the actual problem begins. The six power contacts operate in parallel, but they are not automatically loaded with identical currents. The current does not seek a fair distribution, but simply prefers the path of least resistance. A contact with slightly better pressure or a larger actual contact area carries more current, while an unfavorably seated contact carries correspondingly less. That would still be comparatively harmless if the heat generated developed proportionally to the current. However, the power loss of a contact follows the relation P = I² × R. Current enters local heating quadratically. A contact carrying 20 percent more current already generates 44 percent more heat loss at identical resistance. If its resistance increases at the same time due to an unfavorable contact position, aging, or weakening spring force, the two effects do not merely add up; they can reinforce each other.
This is precisely what creates the notorious thermal feedback. The contact heats up, the material expands, spring force can change, transition resistance rises, and local power loss increases further. In the end, one of those images appears again, showing plastic, contact, and cable having formed a rather permanent bond. Reducing the original 12VHPWR problem to a single design flaw or merely to plugs not being fully inserted is therefore too simplistic. Incomplete insertion is a possible trigger, but not the only one. Side pull, tight bend radii, contacts standing at an angle, manufacturing tolerances, differing crimp connections, and mechanically too rigid adapters can also cause the total current to concentrate on less resilient contact surfaces. The change to 12V-2×6 improved the detection of an incompletely inserted plug. But it removed neither the high current density nor the sensitivity to small resistance differences. After all, a new name cannot talk away milliohms.
With the ROG Equalizer, ASUS therefore is not trying to change the standard again. Instead, the cable itself is reinforced and supplemented directly before the GPU-side plug by a conductive bridge construction. All six 12-volt conductors converge there on a common current rail. A second, electrically separate rail performs the same task for the ground conductors. This means that on the graphics card side, there is no longer a classic assignment in which each individual wire feeds exactly one contact. Rather, the six supply lines feed a common low-resistance node from which the current is redistributed to the six GPU-side contacts.
ASUS combines this design with enlarged, hard-gold-plated spring contacts and tinned conductors made of oxygen-free copper. Instead of the 9.2 amperes cited for conventional designs, each path is said to tolerate up to 17 amperes for short periods. The recommended continuous rating of the entire cable remains at 600 watts. That is an interesting approach, because it does not attempt solely to prevent deviations. ASUS simultaneously increases the load capacity in case the distribution still gets out of balance. To put it somewhat bluntly, the pothole is not eliminated entirely, but the suspension is supposed to handle it much better.
What Aris and der8auer have already found out
Before I examined the cable myself, Aris Mpitziopoulos from Hardware Busters and Cybenetics, as well as Roman Hartung alias der8auer, had already investigated two very different aspects of the ROG Equalizer. Aris focused primarily on load capacity. In a very harsh test, he disconnected five of the six power lines between the power supply and the GPU-side bridge. The full current of around 52 amperes then had to flow temporarily through a single remaining conductor to the metal block. From there, it was redistributed to the contacts on the graphics card side. The cable endured this state significantly longer than one would expect from a normal single conductor. In another setup, Aris loaded three adjacent power paths with approximately 17 amperes each, while the three remaining paths carried only about one ampere each. The total current was thus around 54 amperes. After ten minutes, the heavily loaded side reached a maximum of 93.6 °C, while the less heavily loaded side reached 69.7 °C. The connector housing did not melt, and the temperatures stabilized toward the end of the test.
This measurement is important because it confirms ASUS’s stated high load capacity not only on paper. Three directly adjacent contacts carrying 17 amperes each represent an extreme load. Aris convincingly demonstrated that ASUS did not simply place a ROG logo on a standard cable and call it a day when it comes to contact material, conductor cross-section, and thermal reserve. I expressly rely on his expertise for this kind of stress test. We have known each other for many years and have already discussed the construction, current paths, and possible failure modes at length. His test method allows individual paths to be loaded in a targeted and reproducible manner. For such an investigation, that is far more meaningful than starting a graphics card and hoping that the desired fault condition happens to occur by chance. The test does, however, primarily show how much imbalance the cable can tolerate. It does not yet fully answer whether the Equalizer actually prevents this imbalance in normal operation.
Roman approached exactly this point. He examined several ROG Equalizer cables with a WireView and compared the currents of the six GPU-side paths. In the samples tested, the difference between the strongest and weakest channel was approximately 2.0 to 3.6 amperes. Conventionally built comparison cables in his setup differed by only around 0.6 to 0.7 amperes in some cases. In one Equalizer cable, a channel reached 9.8 amperes, triggering a warning from the measuring device. In a later test, Roman removed the internal metal bridge. After that, the current distribution among the individual contacts was noticeably tighter. That was initially surprising, because the very component intended to provide the namesake balancing effect seemed to increase the differences in this setup instead. I can confirm this basic tendency with my own measurements as well. The common bridge changes the distribution significantly, but it does not necessarily ensure that all six GPU-side contacts carry the same current. At the same time, another effect becomes apparent that is easy to miss in a single snapshot: with the metal block in place, the respective load profile remains relatively stable from run to run, whereas without the rigid connection the individual currents vary somewhat more, but overall remain much closer together. That sounds contradictory at first, but it describes two different properties. A system can be highly reproducible and still uneven. Conversely, individual values can fluctuate somewhat more while the overall distribution remains much more homogeneous in every run. The measured values alone do not yet explain why the cable behaves this way. For that, one has to look not only at the electrical bridge, but also at its mechanical effect. The metal block couples the six conductors directly behind the plug. In doing so, it stabilizes the geometry, but at the same time limits the independent mobility of the individual contact springs.
I will examine exactly this point in more detail in the following section. In addition to the current measurements, this involves the internal construction, the contact geometry, the actual function of the two current rails, and the question of whether the mechanical stiffening can compensate less effectively for small angular deviations in the GPU header. The public tests by Aris and Roman provide a valuable basis for this. I do not want to refute them, but to supplement them and make the causes behind the results more understandable. In addition, I will also cut open the plug and conduct a more precise material analysis. And quite honestly, without spoiling too much: the internal structure was not quite what I had expected. But one thing at a time; first we unpack the cable…
Note: Since I can reproduce both the method and the results of Roman Hartung and find both entirely plausible, the accusation by some media outlets and consumers that the video was more of a promotion for the product itself is rather far-fetched. In the test, however, I deliberately did two things differently and, for reasons, also refrained from using tools such as WireView Pro II and Ampinel, because I use current clamps together with an oscilloscope for measurement and even the same cable, simply flipping it for the individual measurement methods in order to measure the differences in behavior with and without the metal block. Incidentally, the result matches the already published ones, even though different pins are involved, and I will later explain why that is and why it must be so.
Unboxing and scope of delivery
Even the packaging leaves no doubt that ASUS does not intend to sell an ordinary replacement cable here. The ROG Equalizer comes in an unusually long, flat box whose design follows the familiar black-and-red schema of Republic-of-Gamers products. On the top side are a schematic depiction of the cable, the product name, and the usual ROG design elements. The packaging is almost luxurious for a single power cable. It is significantly larger than would be necessary for transport alone. This looks somewhat like formal evening wear for a piece of copper, but it protects the contents properly and prevents the cable from arriving with tight bends or pressure marks before installation. On the rear or underside, ASUS summarizes the most important claims. Mentioned are balanced power transfer, a higher load capacity of up to 17 amperes, and long-term stable operation. The packaging also carries the exact part number 90YE00BN-B0QA00, the serial number, and the usual approval, recycling, and manufacturer information. Notably, ASUS already uses the term “Balanced Power” prominently on the packaging. The Equalizer is therefore presented not only as a particularly robust cable, but explicitly as a solution for more uniform current distribution. It is precisely against this claim that the design must later be measured.
After opening, the cable lies in a precisely fitting black foam insert. The connector and the Equalizer unit are not placed loosely in the box, but are neatly held in a longitudinal recess. Above the cable sits an additional foam layer that prevents the contents from moving upward during transport. Behind or beneath the insert is the printed quick-start guide. No additional adapters, tools, or electronic add-on modules are included. Nor are they necessary, because the Equalizer is not an adapter from multiple 8-pin plugs to 12V-2×6, but a direct modular cable with a 16-pin connection at both ends. The package therefore includes the cable itself, the quick-start guide, and three sliding cable combs. These combs feature a quick-release latch and can be opened without having to pull the cable through completely. This allows the position to be adjusted even after installation. The most conspicuous component sits directly behind the graphics-card-side plug.
A highly polished metal cover with the ROG logo encloses the actual Equalizer unit. Beneath it are the two conductive bridges for +12 volts and ground. The metal body is not merely a design element. It increases the thermal mass of the connector area, protects the internal connections, and holds the contact group together mechanically. At the same time, it creates a noticeably stiffer section immediately behind the connector. Directly at the GPU connection, however, the cable cannot be fanned out or twisted as freely as a conventional individual-wire harness. ASUS therefore recommends at least four centimeters of clearance between the graphics card connector and the case side panel. Only then should the cable be bent in a natural radius. This requirement is sensible, because the cable must not be sharply kinked immediately behind the Equalizer unit. The metal block itself cannot adapt; instead, the mechanical load would be transferred to the connector and the GPU header.
The cable itself is 75 centimeters long. Each conductor has its own black, embossed sheath. ASUS refers to this design as “Premium Embossed Cable”. Visually, the result appears high-quality without becoming unnecessarily stiff due to excessively thick braiding. The twelve thicker power conductors are supplemented by thinner sense and signal lines. On the power supply side, in addition to the native 12V-2×6 connector, there is an additional two-pin ROG connector. This is intended for the GPU-First function of compatible ASUS power supplies and does not serve as an additional power input.
The separate connector can be routed away from the main conductors and left unused with a power supply that lacks the matching auxiliary socket. Actual power transfer takes place via the native 12V-2×6 connector. The cable therefore requires a power supply with a corresponding 16-pin output socket. The usual caution regarding modular power supply cables still applies here. Similarly shaped sockets are not automatically electrically identical. The Equalizer is intended exclusively for an explicitly compatible native 12V-2×6 output, not for any proprietary modular socket into which the plug might also fit with sufficient optimism. The individual conductors remain comparatively flexible outside this area. In addition to visual distinction, the purple connector elements serve a practical function. They make visual inspection during insertion easier and make the transition between plug and socket more clearly identifiable. A color marking does not replace mechanical verification, but in a dark case it is more useful than the usual fully black plastic.
According to the manufacturer, the GPU-side connector uses enlarged and hard-gold-plated spring contacts. The contact geometry is intended to create a larger effective contact area and keep resistance stable even after multiple insertion cycles. Whether these advantages are reflected in actual current distribution depends not only on the contact spring itself. The mating contact in the GPU header, its angle, and the mechanical alignment of the entire connector assembly are equally important. The three cable combs help keep the conductors parallel. However, they can also be removed or shifted farther back if more flexibility is required for installation. The first comb in particular should not sit too close to the Equalizer unit if the cable must be routed sideways out of the connector.
Overall, the ROG Equalizer makes a high-quality and distinctly robust impression when unpacked. The workmanship matches the price range, the conductors are neatly sheathed, and the connectors feel mechanically solid. At the same time, even without disassembly it becomes apparent that the Equalizer stiffens the GPU-side cable section more than a classic 12V-2×6 cable. It is precisely this combination of high robustness and limited local flexibility that will later play an important role in the root-cause analysis.
Technical data
| Feature | ASUS ROG Equalizer |
| Product type | Modular GPU power cable |
| Part number, black version | 90YE00BN-B0QA00 |
| Available colors | Black and white |
| Cable length | 75 cm |
| Power connector, power supply side | 1 × 12V-2×6, 12+4-pin |
| Power connector, GPU side | 1 × 12V-2×6, 12+4-pin |
| Auxiliary connector | Two-pin ROG connector for GPU-First on compatible ASUS power supplies |
| Maximum recommended continuous power | 600 watts |
| Specified short-term current capacity | Up to 17 amperes per power path |
| Reference value for conventional designs according to ASUS | 9.2 amperes per power path |
| Conductor structure | Tinned oxygen-free copper |
| Conductor sheathing | Individually sheathed, embossed premium conductors |
| GPU-side contacts | Enlarged, hard-gold-plated spring contacts |
| Internal Equalizer construction | Common power bus for the six 12-volt paths and separate bus for the ground paths |
| Bridge design | Passive, low-resistance distribution element without active current regulation |
| Visual insertion check | Purple-highlighted connector |
| Cable management | Three movable quick-release cable combs |
| Recommended clearance behind the GPU connector | At least 4 cm to the first bend |
| Supported standards | ATX 3.1 and PCIe 5.1 |
| Graphics card compatibility | Graphics cards with 12V-2×6 or compatible 12VHPWR connector |
| Power supply compatibility | ATX 3.1 power supplies with native 12V-2×6 output, observe manufacturer approval |
| Optional monitoring | GPU Tweak III Power Detector+ with supported ASUS graphics cards |
| Material limit according to ASUS | 105 °C |
| Cable certifications according to the manufacturer | UL 1581 and UL 758 |
| Warranty | 3 years |
| Scope of delivery | ROG Equalizer, three cable combs, and quick-start guide |
ASUS ROG Equalizer PCIe 5.1 600W 12V-2x6 GPU Power Cable, schwarz, 75cm (90YE00BN-B0QA00)
| Shop | Verfügbarkeit | Preis |
![]() | ca. 2-4 Werktage | 47,99 €*Stand: 14.08.26 02:17 |
![]() | Onlineshop: ca. 2-4 Werktage Berlin, Dortmund, Düsseldorf, Hamburg, Hannover/Laatzen, München, Stuttgart: nicht lagerndStand: 14.08.26 02:16 | 47,99 €*Stand: 14.08.26 02:17 |
![]() | Sofort verfügbar | 48,00 €*Stand: 14.08.26 02:35 |
![]() | Auf Lager - 1-3 Werktage Lieferzeit | 48,24 €*Stand: 14.08.26 02:30 |
![]() | Lieferzeit 3-4 Werktage | 50,03 €*Stand: 14.08.26 02:26 |
![]() | Auf Lager, 1 Werktag | 51,23 €*Stand: 14.08.26 02:21 |
![]() | Sofort lieferbar, Lieferzeit max. 1-3 Werktage | 51,23 €*Stand: 14.08.26 02:35 |
![]() | Sofort verfügbar, Lieferzeit max. 1-3 Werktage | 51,23 €*Stand: 14.08.26 02:36 |
![]() | Berlin-Mitte, Bochum, Dortmund, Dresden-Elbepark, Dresden-Waldschlösschen, Hamburg, Leipzig: nicht lagernd, Anlieferung aus Zentrallager innerhalb 24hStand: 14.08.26 02:32 | 51,90 €*Stand: 14.08.26 02:34 |
![]() | Lagernd im Außenlager, Lieferung 2-3 WerktageStand: 14.08.26 02:42 | 53,22 €*Stand: 14.08.26 02:43 |
