Today we have something completely different to marvel at, namely the ASUS ProArt PA27JCV. This is a monitor that has its genes not in gaming – but in content creation. In other words, the focus today is more on color accuracy and not on response times or latency. This becomes clear when you look at the data of the installed panel. The PA27JCV is equipped with a 5K IPS panel that delivers a resolution of 5120 x 2880p. The pixel density is a whopping 218 ppi, making the panel so sharp that it almost burns your eyes. There is also 10 bit (8 2 FRC), an RGB subpixel layout and edge-lit dimming. But unfortunately only 60 Hz including VRR via Adaptive Sync. Ok, the technical data will come in more detail below, but at least you now have an idea of what’s in store for you today. Let’s start with the packaging:
It looks pretty neutral at first. And the inside?
It’s plastic-free and still well protected. I personally like that very much!
As always, the data sheet is available as a PDF. But a look at the ASUS homepage won’t hurt either: Click here!
Technical data
ASUS-Datenblatt_ProArt-PA27JCV_01.25-1
Three pages full of more or less important information. We’ll take a closer look at the most important ones in a moment. Perhaps some of you are already wondering how much the PA27JCV will cost? The RRP is 949.90 euros and that’s really hefty when you consider that you also get a 32-inch OLED monitor for that. So it’s time for us to find out to what extent ASUS delivers here and whether it can justify the price in the end. Let’s go…
- 1 - Introduction, Features and Specs
- 2 - Workmanship and Details
- 3 - How we measure: Equipment and Methods
- 4 - Pixel Response Times
- 5 - Display Latencies
- 6 - Color-Performance @ Default Settings
- 7 - Direct Comparison and Power Consumption
- 8 - Color-Performance calibrated
- 9 - HDR-Performance
- 10 - Summary and Conclusion
29 Antworten
