The GeForce RTX 5000 series from NVIDIA has been available for some time and more and more board partners are now launching their own variants on the market. The Taiwanese company Asus recently introduced two new models from the 50 series. One is the TUF Gaming GeForce RTX 5070 Ti and the other is the PRIME GeForce RTX 5070. Both graphics cards come in a white design.
Let’s start with the slightly weaker version of the two graphics cards: The ASUS PRIME GeForce RTX 5070 White OC is equipped with 12 GB of GDDR7 memory, which is connected via a 192-bit interface. The memory speed is 28 Gbps. The graphics card offers a computing power of 1005 TOPs and has 6144 CUDA cores. Three axial fans are on board as a cooling solution. In standard mode, it achieves a boost clock frequency of 2557 MHz, in OC mode it is 2587 MHz. Three DisplayPort 2.1b ports and one HDMI 2.1b port are available for image output. ASUS recommends a power supply unit with at least 750 watts for operation. The dimensions of the card are 304 × 126 × 50 mm.
The more powerful model of the two cards is the ASUS TUF Gaming GeForce RTX 5070 Ti. It comes with 16 GB GDDR7 memory and a 256-bit bus, also with 28 Gbps memory speed. The card achieves a computing power of 1484 TOPs and has 8960 CUDA cores. In standard mode, the boost clock is 2588 MHz, in OC mode it rises to 2610 MHz. Two HDMI 2.1b ports and three DisplayPort 2.1b ports are available as connections. The graphics card measures 329 × 140 × 62.5 mm and a power supply unit with at least 850 watts is recommended.
As previously mentioned, both graphics cards come with a white design. Therefore, it makes sense for those users who prefer a white setup and need a graphics card that rounds off the whole aesthetic. Asus has not yet commented on when the graphics cards will be launched on the market. This also includes a possible price to be prepared for. It therefore remains to be seen until new information is released.
Bisher keine Kommentare
